Constructive criticism is what I am looking for Strat, so don't feel that you are ever being too critical as long as it is constructive
Simply telling me it is rubbish and a waste of time would hurt a little more
Onto the main parts of your post and I have yet again been working behind the scenes having read your post above. With regards to the first bit you mention about the GBRf search bringing up 73s first - this is now corrected so that a GBRf search now brings up GB locos in class order (and hopefully this occurs with any search now). Unfortunately, I am still working on solving the issue of the search seemingly resetting itself when bringing more data up unless a filter is applied (ie a GB search will show 12 results but if you go through the load more process without having used the filter dropdown it then shows everything from Class 01 onwards instead of just continuing to show the next batch of GB locos). Until I have sorted this, you will just have to ensure you use a filter when you have searched.
I can also see how the 'New Search' button could be misconstrued as the button to activate search after using the dropdown filter so I have moved it to above the search bar/dropdown menu - if you have any suggestions with regards to better wording of that button to avoid further confusion then please feel free to suggest as I am struggling to think of anything - "Return Home for New Search" is as good as it's got in my mind.....
I take your point regarding the number of clicks using the 'Load More' button so I have removed it altogether. I have now set it up so that the load more occurs as you scroll, so now when you reach the bottom of the page you should see it start to load and then show the next batch of data - if you can spare some time to offer feedback on this change then it would be appreciated.
The data shown is currently limited to batches of 12 and I have kept it at this at present to maintain a sound speed within the search function - I've seen a few comments mentioning that this side of Wix can be slightly problematic, although I've not fully researched what sort of expectations these people having the speed issues have on their particular site - for all I know they could be wanting search results in the hundreds at a time! The issue I have is that I don't have broadband at home, instead choosing to make use of an unlimited 4G plan and hotspotting my internet from my phone. This works well for what I require of the internet but it does mean that I lack the ability to do any serious stress testing with regards to speeds. If 12 results is appearing quickly for everybody, then I am happy to increase that to batches of 24 and see if that affects speeds any so just let me know on that.
I think I have covered all of your points here and hopefully the changes make the site more user friendly
