jdjonny said:
Do you mean the netsend.bat commands? The ones that spammers use? If so, the message box subject is "messenger", which often leads to confusion making people think msn messenger is guilty.
Oh, I see what the fuss is about.
That doesn't affect me as I'm behind a firewall/server.
Also, to clarify, there is no netsend.bat as standard in Windows (AFAIK). If you have a netsend.bat file that you use you should check out what is in the batch file.
Batch files can be dangerous!. Never run, or download any batch file unless you're sure it's safe.
You probably mean the 'net send' command though.
