France?No more of a head start than for the AGV or the Velaro. AFAIK the UK is the only country in the world where high speed lines have the same track gauge but a more generous loading gauge.
Did the Oaris really place second? Scary.From the third placed bid?
Zefiro was what was bid
I dread the thought of Pendolino claustrophobia at 140mph. Let alone the cost of retrofitting ETCS at such an advanced stage of their lifespan.Much as I love 390s, what an underwhelming open it would be to launch 125mph trains on a 225mph (formerly planned 250mph) railway!
(140mph requires in-cab signalling that they don’t have and even if they did it’s a huge difference from 225mph still)
Given that they're likely to be used on the WCML for some time and certain parts of that are down for ETCS migration, also that there is already an EVC rack and several ETCS components fitted to implement TASS, it won't be that hard to fit ETCS to the Class 390.I dread the thought of Pendolino claustrophobia at 140mph. Let alone the cost of retrofitting ETCS at such an advanced stage of their lifespan.
Long story short; pretty much nil chance of 390s on HS2.
Ah. I didn’t realise that TASS uses Eurobalises. Still can’t see a retrofit coming in cheap - whether they use Alstom kit or otherwise.Given that they're likely to be used on the WCML for some time and certain parts of that are down for ETCS migration, also that there is already an EVC rack and several ETCS components fitted to implement TASS, it won't be that hard to fit ETCS to the Class 390.
You would hope that anything built new in that timeframe was.They were specified ETCS ready.
A lot built since isn't. Including some very contemporary locomotives.You would hope that anything built new in that timeframe was.
Interesting, TY.To be honest, I think these were the first.
That is poor.A lot built since isn't. Including some very contemporary locomotives.
One other factor: NR is reported to be planning to install ETCS sections on the WCML during the resignalling from Crewe northwards (Warrington, Preston, Carlisle etc) in the next decade.Ah. I didn’t realise that TASS uses Eurobalises. Still can’t see a retrofit coming in cheap - whether they use Alstom kit or otherwise.
I'm waiting with interest to see how the 325 fitment goes - they'll be fitted as part of the freight programme!One other factor: NR is reported to be planning to install ETCS sections on the WCML during the resignalling from Crewe northwards (Warrington, Preston, Carlisle etc) in the next decade.
If that happens, all traffic using the northern WCML will need to be ETCS-fitted.
No doubt that will determine which fleets are converted and which are moved away (or die).
They will continue as they are until they need replacing.What will happen with the 390s when the trains for high speed two are built?
Velaro second, hence Siemens going legal...Did the Oaris really place second? Scary.
Look at the cross-section especially floor height to top corner not top middleWas width rather than height the reason?
ICE 3: 3.89 m high, 2.95 m wide
Velaro TR: 4343 mm high, 2924 mm wide
Frecciarossa 1000: 4080 mm high, 2924 mm wide
a) How narrow will the coaches need to be to meet UK classic requirements if you have 25m bogie spacing?Jacobs seem to be acceptable on the continent. I accept there's differing views either side of the channel regarding what is acceptable and what is not.
With an 8x25m configuration 6 cars of powered bogies with traction motors rated like those from Stadler's Flirt could give an installed power rating of 12MW/16,000HP. That would work quite nice![]()
Why do Jacobs bogies preclude end doors and/or equipment above floor level? [Asked as a complete layperson, not aggressively!]b) HS2 puts a big premium on (floor) space efficiency and maximising passenger numbers, to do this you need the doors as close to the end of vehicles a possible and no equipment above floor height (which wastes spaces) - Jacobs bogie arrangements fails on both accounts.
The Jacobs bogie vehicles in TGV family vehicles are typically 18.7m long with Bogie spacing of 18.7m which is slightly longer than the typical conventional bogie spacing in the UK (17.0-17.6m) for 22-26m vehicles. A 25m vehicle with Jacobs bogie vehicle would have to be very narrow to deal with the 25m pivot centers and would be very heavy needing even larger secondary suspension systems than TGV examples.Why do Jacobs bogies preclude end doors and/or equipment above floor level? [Asked as a complete layperson, not aggressively!]
Sure, I can think of various continental designs with shared bogies that have equipment in the car ends / higher floors over the bogies, but these are mainly low-floor designs (eg. Stadler) or tilting (eg. Talgo). Could a high-floor non-tilting train not have Jacobs bogies *and* end doors?
Ah. I had assumed given their legal claim some time ago that they had departed from the running earlier, leaving it a three horse race. Fair enough!Velaro second, hence Siemens going legal...
There's a detailed article about the legal challenge in this month's Modern Railways. Somewhat overtaken by events now of course.Ah. I had assumed given their legal claim some time ago that they had departed from the running earlier, leaving it a three horse race. Fair enough!
They came second but with lowest risk profile. The later bit they wanted greater consideration of...Ah. I had assumed given their legal claim some time ago that they had departed from the running earlier, leaving it a three horse race. Fair enough!
I need to find time to actually open it!There's a detailed article about the legal challenge in this month's Modern Railways. Somewhat overtaken by events now of course.
That means no luggage spaces between seat backs. According to a Swedish study, preference for facing bays is about 2/3rds. Airline seats are not what are wanted when passengers are travelling in groups of more than two, and not much good if you prefer to face someone you are trying to talk to.Um, 895 * 2 = 1790. If it is mostly airline seats, then that's going to be pretty close to fully aligned, though the bays muck it up a bit.
That's what I was thinking.In Sweden perhaps, but British people are perhaps more reserved, and while most people prefer a table to themselves, likely airline seats are preferred if you have to share the table.
The Swedes are much more reserved than the English. People in Scotland don't seem to be at all reserved. I noticed that once when the train stopped. Yakety-yak all over the carriage.It does, but that space isn't lost and can instead be used for dedicated racks which are better anyway. Also the UK trend is towards good sized overheads rather than the small ones that seemed common on early 2000s units.
Which also means that the three friends cannot sit together and gas away the whole trip.That's what I was thinking.
"Would you prefer a table seat"
"oh yes, definitely"
"there will be three other people at the table"
"oh, hang on....."
The worst being if the other three are all friends and are gassing away the whole trip. No actually the worst is if they are three business people having a meeting and ranting extremely dull office gossip.
Pendolinos induce claustrophobic even when standing at the station. The amount of glazing would be OK for parcels vans, though.What difference does ‘outdoor’ speeed make to claustrophobia? How odd.
The dedicated racks are near the doors where owners cannot watched their property.
They can, but are normally next to the doorways, where they lead to delays as people block the gangways when taking their luggage off the shelves. They also mess up the seating layout. In the case of the 800 series, the main spaces are between the doorways and the vehicle ends, in the part of the vehicle which is too narrow to be used for seating. Some mark 2 stock had a seating bay in the centre removed and replaced by luggage shelves. A further problem with luggage shelves is that the floor space gets used up first, then you have to lift up what can be a heavy case.Dedicated racks can be placed in various locations, often they are spaced out through the saloon.
BR sorted this problem out over fifty years ago when the XP64 project was developed, following a lot of careful research, including doorway widths, seating ergonomics and other requirements including passengers' luggage. The prototype vehicles had a mixture of bay unidirectional seating, to cater for passengers' preferences (which were also the subject of research). Then the BR engineers sorted out bodyshell design and came up with the fabricated steel bodyshell optimised through FE analysis, which was no mean feat given the state of computing at the time. Then the came up with the BT10 bogie which performs well up to 125 mph. Later on the BR engineers came up with the International train which was a revision of the mark 3 to address the unsatisfactory features of those vehicles, including improvements to the windows and a better bay spacing. Then all the expensively won knowledge was gradually left to moulder on library shelves. Meanwhile, the BR designs gave 50 years of good service.
Good points, about vehicle length and the use of door pocket spaces. Pocketed sliding doors are not a bad thing as long as the reduced width space inside is used sensibly.In 80x, they are progressively fitting racks in the door pocket spaces which have no-view and narrow seats which are very undesirable. I would expect all four of those spaces to be taken by luggage racks in all the 80x before too long.
In all other post privatisation UK stock I can think of they are inside the saloon. The 26m vehicles of the 80x do unfortunately cause a disadvantage in creating those narrow areas (though they are fine for toilets and bicycles). 23-24m is really the optimum length for non-articulated UK spec vehicles.
The sad thing about XP64 was the failure to adopt the European style folding door with 5km/h door blocking and autocloser. This (the door, not the other two features) was trialled, but was abandoned. Had it stayed into the Mk2 and Mk3 era, considerable lives (and delay minutes) would have been saved.
But back to seating, I have yet to see a better layout than the as-built Class 158, where you have alternation between 2 rows of airline seats (taking up a window width) and a table (taking a window width and both pillars). It's a shame HS2 seemingly won't use this. It is fully aligned and gives a good mix. They seem to have picked a spacing based on airline seats, which means tables will mess it up and so a lot of seats will be unaligned in both classes.
There is no excuse for uncomfortable seats. It is just a matter of getting the profile correct, using the information that was obtained from research in the 1950s. It requires a reasonable depth of cushion and adequate support for the lower back. Even wooden seats can be comfortable if they are correctly profiled.Any news on how comfy the seats will be?![]()
(hint 2+1 seating in standard... so epic fail)
If you have GB+ or GC loading gauge and are going for double deck then Jacobs is potentially interesting else not. It also largely existed for a while to keep Alstom Belfort (politically sensitive to put it mildly) in business building power cars.
