Thought I would chuck this in to avoid too much speculation in the main thread.
Obviously "buses" are one option, but this is to look at other options.
As a start, I've found the relevant Sectional Appendices:
...and here are the platform lengths and other relevant information with possible issues in bold. Up is towards Bletchley, down is towards Bedford.
Bletchley P6 - 129m - not an issue
Fenny Stratford 76m - not an issue
Bow Brickhill - 37m both ways. HOWEVER there is no signal at the end of either platform, so I'd imagine the S board could be moved to overhang away from the crossing and local door or ASDO be used.
Woburn Sands 68m down, 62m up - not an issue
Aspley Guise - 37m down, 50m up. There is no signal on the down platform thus presumably SDO/local door could be used with the front overhanging here too.
Ridgmont - 61m down, 61m up - not an issue
Lidlington - 66m down, 51m up - not an issue
Millbrook - 73m down, 73m up - not an issue
Stewartby - 37m down, 51m up. There is no signal at the down platform end - it's quite a way further along. So again, I can't see an issue with SDO/local door on a 2x24m unit.
Kempston Hardwick - 45m down, 37m up. Both platforms on the same side of the crossing, so down isn't an issue that I can see. Up may be a problem - I can't see how far past the platform end the signal is from Google Maps. However usage at this station is incredibly low, so temporary closure pending housing development which could pay for improvement by planning gain, or unidirectional operation could be an option.
Bedford St John's - 41m. However there is no level crossing at either end of the station, so again I can't see why SDO/local door couldn't be used. Or even temporarily close the station; the students who mostly use it won't stop travelling just because they have to walk over from Midland.
Bedford Midland P1A - 81m - not an issue
So what's going on here? It appears to me that there is only one platform which might actually be an issue for a 2x24m unit if S boards could be placed past the platform end, and that's at the least used station on the whole line, which could be long term taxistuted if moving the one (1) potentially affected signal a few metres along wasn't affordable.
Looking at unit clearances, obviously 153s are permitted (used before), and from reading the Sectional Appendices (I'm admittedly not used to reading these) it looks like 156s are also OK though not 158s, and 172s are permitted with the steps removed (which suggests that the modifications required to accommodate them would be minor), and - and this is the surprising one - 196s are permitted throughout other than into the platform at Bedford, which I guess would again be a small mod because they presumably clout something.
So why do these 230s exist again, then?
