dangie
If a wheel has to be machined to get rid of a wheel flat, does the opposite wheel on the same axle also have to be machined as well? Otherwise both wheels will be different diameters. Thank you.
The new depot has a programmable autolathe that works on both the heritage trams and the new flexities. It turns the wheels of a new tram in 7 hours and a heritage tram in 4 hours, the heritage tram wheel turning used to take four weeks as they had to be dismantled first.
http://www.dailymotion.com/video/xnlpgn_blackpool-starr-gate-wheel-lathe_tech
Most certainly. The tolerance between wheel diameters on the same wheelset is +/- 1mm
