Ardwick to get new footbridge
21 Oct 2012
Wilmslow
A housing development (with some potential passengers maybe) is now under construction - the containers have gone. For many years the yard was used as a training circuit for the bus garage and before that many of the first generation trams were destroyed and burnt here.
dggar
16 Apr 2011
Calls in addition to, or instead of terminating at, Piccadilly?
Wouldn't it require re-instatement of the Buxton to Matlock line as well though?
Is this a serious question? Do you envisage a demand from the Peak District/Backewell area to Ardwick?
Purple Train
16 Jul 2022
Darkest Commuterland
Pedantic diversion, but if it went via Guide Bridge and Chinley then I think it can be done using the Dore south curve.
Aren't most of the new NR footbridges provisioned for potential lift installation in future if one is needed too?
Stupid question, but if it is a like-for-like replacement, would there not be no room for a lift shaft? (Plus issues with the narrow platform.)
You'd be able to put a lift fitted footbridge in easily enough, particularly if able to demolish the decrepit old ticket office building, but the rest of the access isn't accessible either so it'd be a bit pointless. It's a bit like say Aughton Park in that regard (no sensible way to make it accessible unless it was relocated) - the only real hope is to bridge across from one of the tower blocks that will inevitably pop up around there within 10 years or so directly onto footbridge level and just have one lift at that end of it, or build an entirely new access funded by planning gain further down the road.
For now, to keep it open, a normal footbridge probably makes sense. Hardly anyone uses it anyway, let alone wheelchair users.
See also Cheddington, which got a new non-accessible footbridge even though lifts there would have been totally feasible! I reckon if they ever build housing around it (amazing they haven't) that will fund a lift fitted footbridge.
Baxenden Bank
23 Oct 2013
I was replying to the comment by @185 which I took to be humorous (or at least the second part was). The comment being fully quoted in the post.
Does seem an expensive waste for a truly derelict, near zero usage station... although I do believe Ardwick, my local station deserves a 20-minute London service, plus Eurostar.
Yes, indeed. I just jumped in thinking of the existing Avanti service (which is every 20 minutes) which would either require new 'mainline' platforms at Ardwick or diversion of the service, but then didn't think of the full routeing. Plus there are lots of threads, and real-world proposals, for the reinstatement of the line through Millers Dale to Bakewell and Matlock.
plugwash
29 May 2015
I think it would be very difficult to add lifts.
At the platform end I think the issue would be less finding room for the lift shaft itself as providing a route from the bottom of the lift shaft to the platform. The platform is pretty narrow at the place where the staircase joins it.
At the non platform end you also have space issues and you have the issue that the footbridge doesn't end at street level or carpark level of anything useful like that. To get to street level you have to go down an aditional set of steps and then along a fairly narrow footpath to reach Blind lane..
As beltchleyite says, I think if you wanted to create disabled access to Ardwick station you would be better starting again with a new access route.
Meerkat
14 Jul 2018
on Google Maps Streetview you can ‘walk’ the route from the platforms to the road……what a scary route - multiple blind corners in the middle of a high fenced wasteland!
Close it or move it a bit East, ease the curves and build an access to the south and via the bridge under the lines south into what looks a future redevelopment opportunity.
Trouble is there isn't the money for redeveloping it now, and it's easier to keep open/move a station than close it and reopen. So the pragmatic line is to spend the minimum required to keep it open, which is what's happening.
With the inevitable flats developments within 5-10 years, planning gain could then fund doing it properly.
Curiously last time I went through it there appeared to be a couple of prospective passengers on the platform! They didn't look like spotters.
Meerkat
14 Jul 2018
True - I was thinking more about close/move at any point where expensive improvements are suggested.
I assume dense buses mean developers could get away with lots of flats offices without being forced to sort the station - s106 type payments aren’t big (unless one developer is doing a serious area), not in station building cost terms.
Chester1
25 Aug 2014
The point is that in 10 years' time it likely won't be that, it'll be surrounded by residential and commercial tower blocks as the city centre's expansion marches relentlessly on. And because it would be incredibly expensive to make it accessible and compliant to modern standards e.g. wide enough/non curved platform, if you close it now it's gone for good.
Ardwick is not part of the designated city or regional centre zones. The latter is Salford Quays to Ethiad Campus, including all the area within the ring road. Development outside of the ring road is now limited to 15 floors. Its unlikely Ardwick will have many buildings at this level. Its suitable for town houses and low rise blocks of flats. I doubt the station will ever be popular but it may justify its existence.
185
29 Aug 2010
There's a 50-storey tower planned for the east end of the Mayfield site so the big ones are spreading further east, creeping glacially towards Ardwick station.
Chester1
25 Aug 2014
Mayfield is within the ring road. There has been a lot of effort by the city council and combined authority to prevent uncontrolled sprawl of the city centre. A Garry Neville backed development just on the other side of the ring road was one high profile rejection caused by the 15 floor rule. There are designated city and regional centres. Ardwick will not become part of either, at least until the current spatial planning period runs out in 2034. The development of the container site into housing is indicative of the plans for the area (high density, low height housing). There will be more demand for rail services but lets not carried away.
Meerkat
14 Jul 2018
If a development doesnt put in a new access to Ardwick station then can’t see anyone from there using the train - it’s a long grotty way round, you would just jump on a bus.
Sounds like the only thing keeping it open is the difficulty of closing it. What impact does it have on performance and capacity, and does the platform materially affect through line speeds?
flitwickbeds
19 Apr 2017
I understand the arguments about not formally closing a station which might be useful in the future should development of the area occur down the line.
However I don't understand the difference between IBM (Halt) or Redcar British Steel, and somewhere like Ardwick. If you can temporarily mothball IBM/RBS, awaiting further development and potential future custom when planning gain would allow you to refurbish and reopen the station, why is the same not being done at Ardwick?
Likewise, if there is money to replace the footbridge at Ardwick because it is unsafe, why is the same not the case at Teesside Airport, or Stanlow and Thornton, or Polesworth, or Pilning?
Baxenden Bank
23 Oct 2013
The difference is that IBM and British Steel Redcar were built to serve specific premises and were restricted to legitimate users of the adjacent premises. Now if Ardwick had been 'Ardwick GUS Halt' the same would apply. Polesworth and Pilning are still open. Norton Bridge was (eventually) closed through the proper procedure following a long period being served by rail replacement bus. Stanlow serves a specific premises as per IBM.
The odd one out is Teesside Airport, perhaps someone is prepared to mount a legal challenge (at great expense) just for DfT to put on a rail replacement rickshaw at the eleventh hour as they enter the hearing!
The question therefore is why have Network Rail chosen to invest the money this time around?
flitwickbeds
19 Apr 2017
The same question but in reverse.
Ultimately we're all asking what's special about Ardwick receiving investment, or what's special about the others not receiving investment.
It might be relevant that making Ardwick accessible would be really hard but making Polesworth or Teesside accessible would just be a case of building a conventional lift-fitted bridge. Thus if you close it it can't reopen.
flitwickbeds
19 Apr 2017
But, for IBM at least, it's just awaiting development of Spango Valley before reopening as a commuter station to Glasgow. Are you suggesting that there would need to be some legal ownership transfer when this happens to remove IBM from some kind of ownership or control of the station?
Barely. Just like Ardwick.
Baxenden Bank
23 Oct 2013
Not necessarily ownership/control of the station, access to the station without trespassing through private land.
323235
8 Dec 2007
North East Cheshire
They would have been best off just removing the footbridge at Ardwick and replacing it with a taxi as the platforms are far too narrow to cater for any meaningful footfall increase if they did decide to increase the service - the way things are going with safety you wouldn’t have a lot of space to stand behind the red line.
Demolishing the platforms and re-aligning the platforms would have been a reasonable prospect.
Not as a renewal it wouldnt have been, there isnt the money for that.
The exile
31 Mar 2010
Somerset
Even though IBM no longer exists on that land - do they still own it?
Whether or not IBM still own it or not, if it is private land with no public access, then Operating a public railway service would presumably create additional liabilities for the landowner for no benefit (except to shack bashers). At a location like Ardwick with short to medium term growth potential, it makes sense to keep things going until growth forces a rebuild. Close it now and it’s gone forever.
Deafdoggie
29 Sep 2016
But then there is the Norton Bridge.
Whilst originally the case at Norton Bridge, subsequent track alterations mean the platform faces are on the fast lines and no longer on the Stoke line. And Norton Bridge was officially closed too.
jfollows
26 Feb 2011
Wilmslow
Ardwick used to have a small up platform which didn’t require the footbridge to access, and the island platform was two down platform faces with a down loop. The layout was changed around 1980 at a guess. The former up platform was quite short and not very good.
EDIT Old layout (post WCML electrification, though) at https://www.railforums.co.uk/threads/line-pairings-on-a-4-track-railway.241547/#post-6003988
The former up platform is probably still just about visible although it’s become more and more weed infested over the last 40 years or so.
https://en.wikipedia.org/wiki/Spango_Valley states that IBM sold its site in “around“ 2009 and leased the space it needed for its remaining operations until 2016. I went there in early 2008 when I worked for IBM to visit someone, it was interesting to use.
flitwickbeds
19 Apr 2017
Presumably the leased space didn't include the station or its access?
Was the station sold to another private owner or back to the railway, I wonder?
