All are four car.Using Skipton as example, am I right in thinking that the class 333s normally work in multiples of two? Can they operate as 12 car? By the way, also thanks to Starmill (where are my manners?).
Bolton Manchester shuttles get 6 carriages. Definitely more than regular services (2-4). Can use this website to check the number of carriages under CIS Summary Widescreen (but only on the day of travel)Are there many chances to double up units on the various lines? I'll admit I am very ignorant about Northern services, but I am interested of course.
Fairly typical for the last few weeks. For the first couple of months services had run till about 1900.Is this typical of what's been provided up until now? You get an hourly service from cities to surrounding towns and "the shop shuts" at about 1700 (last trains)? I suppose you can get Saturday shopping done, but it's too tight if attending the football (for instance). (l looked up Skipton, Macclesfield and Buxton as examples).
I believe all 333s are only ever run as single units.Using Skipton as example, am I right in thinking that the class 333s normally work in multiples of two? Can they operate as 12 car? By the way, also thanks to Starmill (where are my manners?).
Thanks to all answers. My point I suppose was obvious, but it was that if there is a much reduced frequency of service, it would be very useful if units could double up, so as to reduce overcrowding. Those last trains on the Saturday afternoon are going to be cosy aren't they?I believe all 333s are only ever run as single units.
Coupling up 333s is risky business, they often throw wobbles.Thanks to all answers. My point I suppose was obvious, but it was that if there is a much reduced frequency of service, it would be very useful if units could double up, so as to reduce overcrowding. Those last trains on the Saturday afternoon are going to be cosy aren't they?
Only for some stations, and not even for every service from those stations.Can use this website to check the number of carriages under CIS Summary Widescreen (but only on the day of travel)
Apart from Leeds, I doubt that there are many stations with platforms long enough to accept 2x333 formations.Coupling up 333s is risky business, they often throw wobbles.
Something you definitely don't want on strike days.
Sam
To be honest on the Airedale line (Skipton - Leeds) I don't think there have been overcrowding issues.
I got the penultimate train on the 15th and there were spare seats - the strikes have simply decimated the trade
I believe they run off what it is booked to be.And it's not always right - this train had 2 overcrowded coaches and passengers were being told to get the next service. Display says it has 4.
It would rely on someone manually changing it in control for instance.
Sam
