tiptoptaff
- Joined
- 15 Feb 2013
- Messages
- 3,029
Recruiting for talent pools. Chester, Holyhead and Shrewsbury.
Good luck!
Good luck!
I'm assuming you can only apply for one position
Hi all, a bit of advice would be appreciated please: I currently live in South Wales but I have family within an hour of one of the locations. I’d relocate if successful, so what’s the best way of demonstrating that on the application? I’m guessing if I put my current address then I’m not going to make the sift as I’m nearly 3 hours away as things stand.
Hi,Recruiting for talent pools. Chester, Holyhead and Shrewsbury.
Good luck!
I am not actually sure what ATW's policy on this one, sorry.
When I applied for East Midlands Trains up in Derby recently, there was a space for noting down any reasonable adjustments that might be made. I stated that I had a residence immediately available in this space (as well as my Asperger's) and got past EMT's sift. ATW also used to have space for a cover letter, not sure whether this still exists on the new website. Might be worth mentioning it on there if it is!
Surprised I didn't get a job alert about this one. Applied to Shrewsbury as a fresh start. Good luck, all.
Internal candidates will automatically score maximum points on certain categories that Arriva mark on. For instance customer service (depending on your current role).
However it doesn’t necessarily mean you have an advantage no. As someone from the street could demonstrate those same abilities and score maximum points too.
Perhaps where an internal candidate may have a slight edge is simply being able to chat to other drivers and gain a more thourough feedback from the driver manager on event of previous failures etc. At least this is how it was when I was there.
At the end of the day anyone can research and prepare for the interview and tests. I believe it to be a level playing field overall.
Just got the thanks but no thanks email.
Same - Titled unsuccessful after short listing?
Which depots did you apply for? I
applied for Chester, no email as yet and status says ‘submitted’ on the website
