Barrow to Manchester airport
kev23a
15 May 2012
Hi, I hope somebody can help me here. We have booked the 12-25 train this coming sunday ( 20th)
The 2 earlier trains involve buses to lancaster because of engineering works. these works are supposed to be done by 12-00.
If the works arent done in time, and our train is delayed, we could miss our flight. Should i be worried ?
dangie
4 May 2011
Rugeley Staffordshire
How much lee-way have you built into the time you reach the airport and check-in time?
My advice will be, if in doubt catch an earlier train (or bus). Hopefully worry sorted.
sonic2009
19 Jan 2010
Crewe
What type of ticket do you hold?
Sent from my GT-I9000 using Tapatalk
kev23a
15 May 2012
train due to arrive at man airport just less than 2 hrs before flight,but we only have hand luggage so we go straight through to security.
we have open return tickets.
Chapeltom
23 Feb 2010
Tainan, Taiwan.
Go earlier. Even if you arrive 3-4 hours early at the Airport it is better safer than sorry. You will be allowed to go earlier with those tickets.
cuccir
18 Nov 2009
open return tickets
Just to check, are they Anytime tickets? Open return is the old name for those. Just making sure we know that you definitely have the sort of tickets we're thinking of!
I'd also travel early. Would you rather be a bit bored at the airport for a few hours or miss your flight? If you have Anytime tickets you can get off at Piccadilly in Manchester and then catch another train to the airport later on if you want.
142094
7 Nov 2009
Newcastle
Go a few hours before hand - always better to be safe rather than sorry.
TPE have a good scheme from Manchester Airport and Liverpool John Lennon whereby you can travel on a TPE service with an Airport Advance if your inbound flight is delayed (upto 3 hours after the advertised departure time on the ticket).
Sammy h
25 May 2011
I would be going as early as possible on a Sunday. I work at Lancaster and it isn't unusual for the engineering works to over run.
kev23a
15 May 2012
Thanks everybody,because of your feedback my mates taking us through to lancaster.
problem solved.
