Bletchley remodelling question
MK Tom
31 Aug 2011
Milton Keynes
Does anyone have plans or a link to plans for the final layout of Bletchley after the remodelling is completed? The work seems to have picked up pace in the last few weeks but I have yet to find an actual impression of what's going to change. Any help would be greatly appreciated!
ole man
6 Jul 2011
LEC5
I'm working on there from time to time will get you a final layout this week and post it up here.
New signal gantry's south of Bletchley and new OLE to suit going up,There is a lot of remodelling work at Christmas this year
I found a written description of the work in the CP4 enhancement plans, there doesn't seem to be a great deal in passenger areas that will look much different. Hope it helps anyway:
The scope of work includes:
removal of the fixed diamond from Bletchley South Junction (early delivery in conjunction with the Infrastructure Maintenance Delivery Manger (IMDM));
recovery of out of use track and OLE assets;
implementation of 3600m of drainage associated with the remodelled track;
transfer of signalling control to Rugby SCC;
provide 775m goods loop for regulation and hot axle box detector inspection;
platforms 4 and 5 extended to accommodate 12-car standage;
provide bi-directional signalling on platform 5;
turnback facility clear of the Slow lines from the bi-directional signalling on platform 5;
bi-directional loop for regulating a 775 metre freight train; and
turn back in platform 6 for trains up to 4-car length.
The following functionality will be provided:
125 mph line speed throughout on the Fast lines including through Bletchley South Junction;
12-car platform capacity provided on platforms 4 & 5;
access to train maintenance depot and adjacent civil engineering freight sidings to be preserved;
direct access to the Bedford lines from the Slow lines independent of whether platform 5 or 6 is occupied;
route for 775 metre freight Up Slow to branch via flyover and vice versa;
the Drayton Road Junction will allow an Up Slow to Up Fast and parallel Down Slow to Down Fast move;
enable entry and exit to the carriage sidings from the north and south;
12-car shunt through carriage sidings washer, remaining clear of running lines;
retain existing stabling for NDS trains;
retain existing stabling facilities in carriage sidings; and
retain stone terminal (CEMEX siding) existing standage (437m).
eMeS
12 Jun 2011
Milton Keynes, UK
Is the carriage sidings still in use? I thought this work had gone to the Siemens facility at Northampton.
Will the changes allow Bedford St John's & Midland to be accessed from Milton Keynes Central without the need for changing trains?
DarloRich
Fenny Stratford
carriage sidings in constant use! Depot mothballed since siemans facillity at northampton
The driver would still need to swap ends, there won't be a direct link.
MK Tom
31 Aug 2011
Milton Keynes
London Midland have said they expect direct Bedford-MKC services by 2013 - it seems to me these works would make that possible by allowing ex-Bedford services to run into platform 3 and out of platform 4... The remodelling and capacity issues on the WCML were their reasons for not doing it sooner.
cle
17 Nov 2010
Are these expected to be more popular? It's a baby step towards E/W rail I suppose!
How did the vegetation clearing go on the line towards Bicester?
No longer here
I'm pretty sure that a direct Milton Keynes - Bedford link will drastically improve the fortunes of the Marston Vale line. It's just a shame that trains will have to reverse at Bletchley. However, I really can't see an alternative given the siting of Bletchley station.
Just comparing the drawing with the text I quoted above, I reckon NR have made a typo in their description.
This line:
"the Drayton Road Junction will allow an Up Slow to Up Fast and parallel Down Slow to Down Fast move"
Doesn't actually make sense. Should it really end with:
"...an Up Slow to Up Fast and parallel Down Fast to Down Slow move"
