Ascot
I just treat it like an airport, wait in the departure lounge until the boarding announcement appears then walk to the "gate" with my ticket/boarding pass ready. If only they did fast-track!
Why can people just not be patient
Never understand people like you, why there is always such a flap and panic about being at the platform ages before hand, 15 minutes is plenty to board a train.
They are held back because there are so many platform alterations due to set swaps, delays etc and also to allow trains to undergo maintainance, cleaning and loading of stores. If you'd like to get on a dirty train, with no catering, that doesn't work and then it may be replatformed at the last minute so you miss it then please complain.
Interesting last night as there are departures to Manchester at 18.57 and 19.00, and the 19.00 showed its platform on the departure boards before the 18.57. In the event the 18.57 was flagged up with about five minutes to go and they got everybody on but I wonder how many had opted for the 19.00 on the grounds that the 18.57 might be delayed.
Not me, as the 18.57 is declassified and gives the opportunity of a first-class seat for a second-class fare, and the 19.00 is always packed. In the event the 18.57 had lots of spare seats.
2. I'm perfectly aware that incoming trains require servicing [I spent 20 years working for the railway], and that late alterations may - rarely - be needed, but I still don't see why passengers cannot wait on the platform ramp rather than the concourse.
I doubt it would make much difference. I was recently watching a load of people queuing at the unstaffed (and locked) gate for a KLM Flight at Schiphol for about 20 minutes before the staff member arrived. She only opened the gate and started letting people through when the airside bus out to the Fokker Farm pulled up. And then it was a scrum to board the bus.
I have no idea why they were queuing and rushing given that A) they were boarding a bus and B) all seats on the aircraft are allocated at check in.
I thought the theory about the frequent 3tph departures (MAN and BHM from Euston) was that there would always be a train ready for boarding.
So the stream of people wandering up to the departure board simply diverts to a different platform when the previous one closes. Should be a gentle flow.
Doesn't work if everybody is on Advances, obviously, or for the 1tph Liverpool/Preston/Glasgow.
I don't have any trouble locating the xx10 to Chester - just find the only Voyager at the buffers.
This is why I am all in favour of regular pattern services having designated platforms at terminals, to make life simpler for staff and passengers alike. When these are every twenty or thirty minutes there should be no reason (remember- where there is a will, there is a way) why they can not allocate a pair of back to back platforms to the departure of such services.
For example:
At Paddington use 2 & 3 for Bristols and 4 & 5 for Cardiffs
At Kings Cross use 2 & 3 for Leeds and 6 & 7 for Newcastles
At Birmingham New Street use 2 & 3 for Euston Pendolinos
the train needs to be cleaned..
For example:
Indeed, your point about mobility impaired people is an excellent one - I frequently travel with my grandmother as she requires support when travelling and getting from Eustons concourse to 1 or 18 when she can't move properly, your on an advance ticket and the train leaves in 5 minutes isn't easy... Luckily I normally check the booked platform prior to going to the station so we always sit nearby the booked platform and 9/10 times it's correct.. They should really give out information sooner.
The railway companies should be doing every thing they can to ensure that passengers arrive on the train early and without a mad dash for it.
I would hardly call announcing a platform 15 minutes or even 10 minutes before departure a mad dash for it. Passengers can either reserve a seat in advance or take pot luck with getting a seat on that service or the one running 20 minutes later. As already mentioned, passengers with mobility issues can book assistance in advance and be taken to the train on a cart.
Euston is an awful station in almost every respect and the sooner it is redeveloped the better.
If it's a typical airside bus where there are vastly fewer seats than passengers, perhaps they were queuing/rushing to get a seat on the bus!
If you book assistance at Euston you get a ride to the platform and generally in advance of the platform being displayed on the boards.
Enthusiasts know best eh? When would you like a member of staff to have a break as I have to take mine out of view of customers ie when the train is in and between trips.
Twenty mins is the usual boarding time at Euston, dont see why its an issue
Maybe not 15 minutes, but 10 minutes is. Remember, at Euston, the distance from the concourse to most of the standard class seats on the train can easily take several minutes even for a healthy able-bodied person to walk. And with everyone trying to get on at once it can take several minutes more to get to your seat and find somewhere to put your luggage even once you've found the right coach.
What an arrogant and condescending comment. You need a break - go and sprawl out in a staff mess room, not a 1st class carriage of a train. The passenger accommodation on trains is, surprisingly enough, for passengers.
So when is an acceptable boarding time on a train that has a half hour turnround then?
So what you are essentially saying is that, in the case of the current VT and the 390 fleet, the fleet is too small and the amount of trains has to double to accomodate an extended turnaround time due to 10-15 minutes being too short for people to board after the train has been serviced? And the amount of platform space at Euston presumably has to grow to accomodate more trains staying there for longer?
Or are you saying that trains should not be serviced upon arrival so passengers can effectively board at the same time as passengers getting off the incoming service?
No, I didn't say either of those. I don't have enough knowledge to know what the solution is. My guess is the cheapest way would be to find some way to let people wait on the platform while keeping the train locked until it's ready, and I think that's the solution I'd prefer (it would also have the bonus of freeing up a lot of space on the main concourse). Remodelling the station would probably be ideal, but obviously very expensive and there's arguably much better uses for the money. Longer turnaround times - I'm guessing that would require one or two more trains at most, certainly not doubling the numbers of trains. But again if more trains became available, I'd probably be the first to argue for using them to provide more trains somewhere, not keeping them waiting at Euston!
I certainly would not advocate not servicing trains on arrival.
