Grumpy Git
I fly maybe 25 times a year. As an engineer there is no way I'll be booking anything on a 737 Max8 when (if) it gets re-certified.
The Channel4 documentary on the 373 Max is worth a watch particularly as they have some pilots recreating the flights to show what it would have been like for the pilots of the doomed planes:
As times goes on and more information about what Boeing knew and how the plane was certified it gets a lot more worrying.
I find it more worrying that the media narrative is focused on Boeing, and particularly on the design and engineering. These accidents were just symptoms of far wider and deeper issues within the worldwide aviation industry.
Two 737MAX aircraft have crashed in similar circumstances with the loss of hundreds of lives. If this isn't about Boeing and their engineering and design then what is it about? If they are symptoms of "far wider and deeper issues within the worldwide aviation industry" why are other aircraft still flying (and not crashing) whereas 737MAX are grounded?
surely If that was the only reason it would have the opposite effect as someone put earlier I.e the nose wanting to pull down all the time ?
It would, but they tried to counter that by introducing something else which the MACS was supposed to keep an eye on. I've forgotten what the counter measure was, but I think it's described in the documentary someone else linked to this afternoon.
If the engines have changed the balance of the aircraft then the solution is simply to move something else (or add ballast) to restore the CofG. Once that is done then no further action is required. (notwithstanding changes of CofG per flight resulting from passenger/luggage/freight/fuel loading)
As I understand it the issue is that, at high angle of attack (approaching the stall), the airflow over the top of the engine nacelle creates aerodynamic lift. Because the nacelle is so far forward of the centre of gravity, this lift creates a substantial nose up pitching moment, additional to, and independent of, the effect of the engine thrust. This pitch up moment opposes the natural tendency of the wing to pitch nose down as the stall is approached. The nose drop tendency is needed to identify the stall as required by the airworthiness regulations - the aircraft will recover from the stall by itself unless the pilot keeps pulling back hard on the stick.I've not yet seen a definitive explanation (I don't think Boeing have released full details) but some sources I believe to be reasonably reliable suggest the issue is a combination of the engine size and position causes a different aerodynamic response compared to the older models. It appears the larger engine nacelles and a longer lever arm generate unhelpful nose-up forces which increase as the angle of attack increases.
But they didn't only change the balance (though they did change that). They also changed the rotational force around the wing that is exerted by them not being in line with it due to their different position. <Snip>
Some good questions there. My initial response would be why do you think other aircraft are not crashing? Is that based on a statistical analysis, or that you've not seen/noticed any others on the news? (That isn't a criticism directed at you btw, it is a reflection on the way the media produce news and how we consume it).
To get a more rounded view of the problems I'd suggest the starting point should be reading the accident report for the AF447 crash in 2009. That wasn't a Boeing, but gives insights into human factors and how pilots deal with situations in the cockpit. It illustrates the 'battle' humans can have trying to understand what complicated computer driven systems on aircraft are doing, especially in situations of stress. Also worth noting that despite the cause of the aircraft loss being unknown, the A330 fleet was not grounded.
https://en.wikipedia.org/wiki/Air_France_Flight_447
The issue is not that other aircraft don't crash, the issue is that they don't crash at the same rate. Almost 1500 A330s has been built and it has been in service since 1994. When AF447 crashed, it was the first fatal accident with an A330 in commercial service (one crashed in Toulouse during a test flight). There was a 2nd fatal accident a few months later but that is two fatal accidents in 25 years with 1500 planes. And the "sister model" A340 with 380 built has never been involved in a fatal accident during its 26 years of service.
The 737MAX however has crashed twice in less than two years of commercial service with 387 aircraft delivered.
That's almost true. The real issue was that MCAS v1 turned itself back on after being turned off in the usual way. In addition, the raison d'etre for MCAS (making the Max fly the same as the NG) meant that many (most?) pilots were never even told it existed.If the 'computer' had been switched off at the correct time the pilots would have had a perfectly flyable aircraft in all three incidents.
They more than likely didn't leave the throttles on full thrust, that would have been the autothrottle system. It has a "glitch" where, if you level out early during the climb, it will maintain TOGA.As far as I recall the Ethiopian pilots did deactivate MCAS but they'd left the throttles on full thrust, were going too fast and the forces on the control surfaces were too great to operate the manual trim so they switched the automatic system on again.
This isn't something I've heard of before, although that obviously doesn't mean it doesn't exist. If you can find a source for that information it would be really interesting.
The basic architecture of the 737 family is over 50 years old and reflects a now outdated design priority for an aircraft that sits low to the ground. The improvements in jet engine technology have led to much larger diameter engines which have always posed something of a design problem for Boeing even before the MAX. As such Boeing really should have come up with a clean sheet replacement design instead of another 737 iteration.
So yes, had the pilots completed an untrained procedure to turn off a system that they had never been told existed then they would have had a perfectly flyable aircraft.
It's a known issue so, you could argue, they should have been able to recover it, but at what point do you stop blaming the pilots for not being able to apply workarounds?
The impression I'm getting from this thread is:
The pilots were at fault
Boeing did nothing wrong
Other planes crash (but are not reported in the media)
The air transport industry as a whole is to blame
Is the usual ballast DU ( depleted uranium) or is that just internet folklore ?Yes, moving the centre of gravity forward would have a nose-down effect. It could also be dealt with by making other changes to restore the centre of gravity (E.g. adding some ballast at the rear of the plane) rather than adding complicated control systems.
Where did you read that?
The Max can be flown manually using pulleys and cables. And the appropriate action to take if this system misbehaves is to turn the 'computer' off (strictly speaking, isolate its output). If the 'computer' had been switched off at the correct time the pilots would have had a perfectly flyable aircraft in all three incidents.
I find it more worrying that the media narrative is focused on Boeing, and particularly on the design and engineering..
I did 107 flights this year - lowest for 10 years btw- and there is no way I will willingly get on one eitherI fly maybe 25 times a year. As an engineer there is no way I'll be booking anything on a 737 Max8 when (if) it gets re-certified.
I think this gets to the nub of the issue. A perfect pilot in perfect circumstances might have been able to recover the situation, but if the pilot is less experienced or less trained, and something else is causing a distraction? Do you blame the pilot or the company? Particularly pertinent is the issue that Boeing were trying to avoid requiring the pilots to take extra simulator training, which might have given them that extra knowledge and confidence about how and when to intervene if the system let them down.There is also an increasingly significant cultural issue which seems to be much worse for Boeing, as an American company compared to Airbus, which relates to the flying experience of pilots before they get near the airline industry. In the US there is significantly more private flying than anywhere else in the world so that some people are learning to fly at the same age as they learn to drive. This is inevitably reflected in the attitude shown both by Boeing and many US commentators to pilot training requirements given that most budding US airline pilots already know all about basic stick and rudder flying. But in less developed parts of the world, which are experiencing massive growth in demand for air services, very few pilots have done any flying at all before starting with an airline. And this is arguably also a problem for the certifying authorities when it comes to the enforcement of consistently high safety standards on a global basis. The continued delay in re-certifying the MAX may well be related to this as much as the obvious technical issues.
The Bay Area pilot who orchestrated the dramatic plane landing in the Hudson River 10 years ago told a congressional panel Wednesday that he can “see how crews could have run out of time” during the recent Boeing 737 MAX crashes after he struggled to recover the plane in a simulator running recreations of the doomed flights.
“We must make sure that everyone who occupies a pilot seat is fully armed with the information, knowledge, training, skill and judgment to be able to be the absolute master of the aircraft and all its component systems and of the situations simultaneously and continuously throughout the flight,”
As I said it is an impression I have received from posts such as:
Exactly and imho the whole crux of the issueBasically Boeing gave pilots (and the FAA) the impression that flying the Max8 was exactly the same as flying any other 737 and this is clearly far from the truth.
