- Joined
- 14 Jul 2011
- Messages
- 16,751
Two in a matter of.... (was it weeks?)
Are these common or is something odd happening?
Assume you're referring to Nine Elms?Two in a matter of.... (was it weeks?)
More than likely.Climate change the driver possibly?
I'm hoping Scotrail decide to keep up ticket acceptance with the Citylink buses for next week then. Their replacement bus schedules time around (only shuttling between Stonehaven and Montrose) leaves some quite long waits for connections, though lockdown is probably affecting coach/driver availability in addition to passenger numbers.Now closed until end of service 31st January.
Local radio report this afternoon of some road closures early next week (Mon-Wed) to allow Network Rail to carry out other bridge inspections in the aftermath of this incident.I'm getting nightmares of a Hatfield esque fallout from these failures.
Sounds like a thorough investigation is taking place as that tweet mentioned removing one track and ballast.Network Rail are now tweeting that it will be closed until February with a clearer idea next week. It seems that they are still deciding what has to be done and how to do it.
Until 7th of February the line is confirmed as being closed by Network Rail.Now closed until end of service 31st January.
That’s what I was thinking too, but I wasn’t so sure as to suggest it. Makes you worry where else is the same?If, as has been suggested, the problem arose from pressure from the increased depth of ballast on the outside of the bend, then the whole length of parapet would be vulnerable and need replacement and reinforcement.
If so would that necessitate a reduction in line speed in the future to mitigate against the effect of the pressure building up again?If, as has been suggested, the problem arose from pressure from the increased depth of ballast on the outside of the bend, then the whole length of parapet would be vulnerable and need replacement and reinforcement.
The solution is probably to replace the whole parapet with something strong enough to withstand all the forces it has to bear. The parts of the parapet that didn't fall might only have been in marginally better condition or experiencing slightly less force for some reason, so would most likely have fallen sooner or later if not dealt with.If so would that necessitate a reduction in line speed in the future to mitigate against the effect of the pressure building up again?
Apologies if this is a completely daft idea, my understanding of civil engineering is somewhat lacking...
Interesting thought - then retrofit to all higher risk locations of similar type presumably?Well if the depth of ballast started causing issues, wouldn't the obvious solution be to install slab track over the bridge?
I think that would be classed as Enhancement and would need separate funding steam from DafT as it wouldn’t be a maintenance RenewalWell if the depth of ballast started causing issues, wouldn't the obvious solution be to install slab track over the bridge?
you could argue it's preventative maintenance, for the avoidance of catastrophic failure.I think that would be classed as Enhancement and would need separate funding steam from DafT as it wouldn’t be a maintenance Renewal
I'm guessing from the (pre-existing, I believe?) dirt road on the left hand side that access doesn't appear to have been as much of issue as it was with the derailment site over the summer.There is an updated photo of the bridge repairs from Network Rail
at https://twitter.com/philatrail/status/1356285666418716678/photo/1
To increase linespeed the track has been canted up on the outside of the curve so you have more ballast pushing up against the wall potentially exerting sideways pressure on it through the passage of trains and creating an overturning moment causing failure. As RAIB seem disinterested in this and Nine Elms doubt we will every really know but maybe and FOI would liberate an answer.If so would that necessitate a reduction in line speed in the future to mitigate against the effect of the pressure building up again?
There’s no obligation on RAIB to issue a quick public statement about whether or not they’re investigating a particular incident. You cannot really say yet if they are “disinterested”.To increase linespeed the track has been canted up on the outside of the curve so you have more ballast pushing up against the wall potentially exerting sideways pressure on it through the passage of trains and creating an overturning moment causing failure. As RAIB seem disinterested in this and Nine Elms doubt we will every really know but maybe and FOI would liberate an answer.
Given that there was no accident or near miss there isn't really anything for them to investigate.To increase linespeed the track has been canted up on the outside of the curve so you have more ballast pushing up against the wall potentially exerting sideways pressure on it through the passage of trains and creating an overturning moment causing failure. As RAIB seem disinterested in this and Nine Elms doubt we will every really know but maybe and FOI would liberate an answer.
