The stuff that I’m aware of
Replaceing Balcombe Tunnel Junction with a modified layout,
Relining Clayton Tunnel
Replacing the signaling controls Keymer Junction to Preston Park (the FDM system)
Replacing the signalling controls for Preston Park interlocking (the TDM system)
Work on Ouse Viaduct
If the bus driver is not competent to manage dispatch requirements (aka to get off his backside and go and look if the train has arrived), then yes, there needs to be one at each point where there are connections to be maintained, or if not a marshal as a "conductor".
This is the exact problem. It's all done on the cheap. Hired bus drivers just drive, there needs to be someone with the appropriate authority to dispatch and direct passengers either on board the bus or at each station, whether they would normally be staffed or not. The number of times I as a passenger have ended up doing this over the years is an absolute and utter disgrace.
But that'll be leisure travel, and leisure travel is voluntary unlike going to work. I suspect parents will find out there's buses, and decide not to go to BrightonWith the kids on holiday, parents may decide to take them to Brighton and the situation could be worse than a normal week.
I would have thought soYes, could put them off a bit then?
RTT has buses from Brighton calling all stations to Balcombe (but not beyond) and another bus to Three Bridges only. The all stations bus to Three Bridges starts from Preston Park. But will any of these actually show up?
It would be fantastic - and there have been murmurings for a very long time about the traceability and transparency of rail replacement. Some of the bus controllers on GTR operations do now have a bit of a better idea about where their buses are, and some of the bus companies have GPS tracking, but on a large operation it’s more than a bit piecemeal, and any such data certainly hasn’t made it back to customer facing apps/websites/station CIS screens.
Also, a number of the companies who supply replacement bus services during major operations are quite small, not large well-established city bus companies with sophisticated IT arrangements. So if you wrote this sort of infrastructure into their contracts, there’s a good chance they might just pull out, or else submit poor quality and misleading data to the rail companies and the public. It doesn’t entirely excuse the lack of information, but the reality is that rail replacement is quite complex, and can barely ever cope as it is, so any complications like this really can become quite lengthy and tortuous.
Try telling a 6 year old their trip to the seaside is cancelled.
Took me a while to fathom out what all this means. Then I went to NationalRail.com which showed BTN as Brighton, BAB as Balcome but draws a blank on PPR! I can only assume that PPR stands for "Park Preston".Also you will note that the BTN - BAB buses run at exactly the same times as the PPR - TBD buses between PPR and BAB, as I discovered yesterday (Sat 16th) they are same service running through all the way from BTN - TBD, but don't tell anyone.
Sutton is in London, not Surrey. Besides, there wouldn't be the pathways in between all the other trains on those routes. Then there's driver route knowledgeAre the present Victoria - Brighton via Gatwick limited stop (the green trains I am referring to, not the red "Gatwick Express" branded trains) still running?
A thought that has come into my mind is that these could be (if this is not the case already) diverted to call at Clapham Junction, Mitcham Junction, Sutton (Surrey), Epsom, Horsham, Littlehampton, Worthing, Hove, and Brighton, thus making it the shortest route solely by rail.
Also i must say i am always surprised that they are still using coaches on rail replacement these days. I have seen quite a few coaches on these services. The bus company i work for has a fleet of 100% low floor buses but many other operators are running coaches. I am surprised that they still allow this. I am surprised that the DDA compliance rules do not apply to rail replacement as well. It is not very good for the disabled or OAPs or those with lots of bags.
Who is going to give the bus driver that authority?
Trip to the seaside in February?
At the end of the day if the work has to be done some time then inconveniencing a few 6-year olds on a discretionary day out at the seaside is the lesser of two evils. And, of course, Brighton isn’t the only seaside in southern England, nor is seaside the only leisure pursuit available.
Anyone unable to tell a 6 year old that is someone who shouldn't be in charge of a 6 year old.
Route training levels will primarily be at the discretion of the bus company’s who are employing the drivers rather than GTR or any other TOC using RRBsWe do not receive any route training or any form of training. Luckily i have very good knowledge of all the roads in the area but many other drivers from further away do not. All they normally give out to those drivers is a simple basic map printed out on an A4 sheet for them to follow and some don't even get that. There is certainly no route training being provided (.
