nlogax
Good to see it getting a new lease of life, although chances are rooms will be at least £200+ a night so out of reach for many.
At least double that.
And probably in the old Telephone Exchange building, not the Tower itself!At least double that
I think the revolving restaurant doesn't work anymore ( apart from the restaurant is closed) is that the IRA blew it up and the mechanism doesn't work anymore.
Slough is however a major site for IP connectivity and data centre space, and so much of modern broadcasting is just servers and video over IPI believe switching is no longer the exclusive domain of BT anymore. I came across an early morning tone and bars that proclaimed “ITV Hub - Slough”. From memory, there was never an ITV network hub in the town, but after buying up much of the transmission network, Arquvia (sp?) would clearly manage their own feeds - taking in C&W/Mercury who boasted of their backbone up the Grand Union Canal towpath to ‘the North’ so it makes sense to wind down a system that was primarily analogue and due for full digitisatio.
About 20 years ago the London Hilton was charging in the region of £800 a night for the Park Lane Suite ( i.e. high up in their tower, one floor below the Presidential Suite ), so given we are 20 years on from then and the BT Tower is more centrally located, is somewhat higher and would be much more exclusive, I'd expect any room installed in the BT Tower itself would likely be around £2500 a night...And probably in the old Telephone Exchange building, not the Tower itself!
Originally built for 'horn' antennas. These were later replaced with the more compact dishes.It was built to carry microwave dishes* in the days when that was a more economical way to carry TV and telephone traffic than digging up the streets to lay copper wires. Fibre optics have changed all that, of course.
I think you're probably nearer the mark, but there'll be plenty of discounts, offers and other inducements meaning only a proportion of the clientele at any time will be paying top whack.About 20 years ago the London Hilton was charging in the region of £800 a night for the Park Lane Suite ( i.e. high up in their tower, one floor below the Presidential Suite ), so given we are 20 years on from then and the BT Tower is more centrally located, is somewhat higher and would be much more exclusive, I'd expect any room installed in the BT Tower itself would likely be around £2500 a night...
Rooms in the old exchange building would likely be around £500 a night at least - if not more.
Think again - there have been multiple charity runs up and down the stairs - they encircle the lifts. Even when designed in 1962, they wouldn’t have been that stupid! Further, the lifts did not serve every floor, so you did need to use them!My understanding is there are no stairs in the tower, only lifts
There's supposedly well over 800 steps, anyone got the actual number?My understanding is there are no stairs in the tower, only lifts, due to the limited space.
The BT Tower has 1,037 steps from the bottom to the top observation deck. Another 36 to the topmost gallery but that’s only for maintenance crews!There's supposedly well over 800 steps, anyone got the actual number?
As above, there most certainly are. That said, legislation was passed in the 1960s to permit evacuation plans to include egression using the lifts rather than the stairs.My understanding is there are no stairs in the tower, only lifts, due to the limited space. I would expect this will impact on any plans to convert the tower itself into bedrooms.
Wasn't the record about 5 minutes running to the top?The BT Tower has 1,037 steps from the bottom to the top observation deck. Another 36 to the topmost gallery but that’s only for maintenance crews!
How do you get down then, in a fire, with no stairs? ( Towering inferno anyone)?My understanding is there are no stairs in the tower, only lifts, due to the limited space. I would expect this will impact on any plans to convert the tower itself into bedrooms.
It's been confirmed now that there are, in fact, stairs. That said, modern building regulations allow for fire-rated lift doors and shaft construction which, if in place, let the lifts be used even in the event of a fire. I believe they also have to have duplicate independently-routed power supplies.How do you get down then, in a fire, with no stairs? ( Towering inferno anyone)?
Entirely coincidentally, I'd been doing a bit of reading about the GPO Tower a few days ago, plus watching various videos on YouTube, and from one I discovered that special dispensation had been given to the use of lifts in an emergency. Whether this was after the IRA attack, I don't know.It's been confirmed now that there are, in fact, stairs. That said, modern building regulations allow for fire-rated lift doors and shaft construction which, if in place, let the lifts be used even in the event of a fire. I believe they also have to have duplicate independently-routed power supplies.
Pur Down (or Purdown). Still in use for VHF and DAB radio broadcasting and mobile phones.Northern suburbs of Bristol....East of the Temple Meads-Patchway/Parkway line.
I should have remembered the one near the M40, I've driven along that loads of times. I don't think I've ever noticed the one near Bristol, though, either from the M4 or from a train ... I'll look out for that next time I'm down that way.Other ones I can think of - with approximate locations - are:
Near Stokenchurch, Buckinghamshire....on the top of the Chiltern escarpment just East of the M40.
Northern suburbs of Leeds (Cookridge?)
On Cannock Chase....visible from both the WCML and Wolverhampton-Stafford line.
There are a couple of dubious facts in the rest of the article:These are Stokenchurch, Charwelton, Pye Green, Wotton-under-Edge, Heaton Park, Sutton Common, Tinshill, Emley Moor, London, Birmingham, Morborne, Purdown, Tolsford Hill and Turners Hill.
andThe towers were initially built to deliver television, internet and telecommunication ...
whereas I think it was actually built in the 1960s.Birmingham BT Tower is the UK's third largest and was built well before the London tower in 1949
Yes, apart from one mast in the south that was at least part owned by the MOD and possibly the odd relay site share the broadcasters basically owned half each of the TV transmission stations when UHF/625 line came along. Previously in 99% of cases the ITA/IBA and BBC owned their own sites but as the UK was to use Band 4 and 5 (UHF) exclusively for colour TV it made sense to consolidate sites so most people would only need the one aerial, naturally most sites used were existing ones, normally using whichever site was best placed.Emley Moor was never a BT Tower. It was originally owned by the IBA and is now owned by Arqiva.
I believe the Tower has only 37 floors.I liked a story in the paper today confirming the restaurant continued operations on the 57th Floor until at least the end of 1977 when Butlin’s contract expired and the lease was not renewed.
It also noted that the restaurant toilets were actually on the 58th floor, and the main bugbear was that on your return, your table was never where you had left it!
