Bury St Edmunds to London Liverpool St Ticket Validity
Pugwash
17 Nov 2011
Hi,
It is virtually the same journey time to get to Liverpool Street Via either Cambridge or Ipswich to Liverpool Street, both journeys are with Greater Anglia can I use my ticket for either routing.
Thanks in advance.
greatkingrat
20 Jan 2011
If your ticket says "Any Permitted" then you can go either way. There are also cheaper tickets routed "Via Cambridge" which are only valid via Cambridge.
If you are travelling via Cambridge you can also travel on Great Northern services to Kings Cross, you don't have to go to Liverpool Street.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
If your ticket is routed Any Permitted, then yes you may travel via Ipswich or Cambridge (or Ely then Cambridge). There is a cheaper ticket routed Via Cambridge which is, unsurprisingly, valid only on the latter two routes - this can be excessed to travel via Ipswich at the difference between the fares (or half the difference, for one leg of a return).
10 Mar 2015
You must follow the instructions given above, there were some quite serious issues with people attempting to regularly use via Cambridge tickets on the more expensive GEML route so the validity is quite strongly enforced.
Hadders
27 Apr 2011
There is no penalty for purchasing a change of route excess on board.
Starmill
18 May 2012
Bolton
I can't imagine there are any 'quite serious issues' as you say, because most of the trains between Ipswich and London will have an onboard ticket inspection carried out, no? It's a very easy process to charge the excess and this will correct the position.
And, looking at Off-Peak Return Fares the Any Permitted is a whole £2 more expensive than the Via Cambridge fare. Wow.
10 Mar 2015
Not a case of imagining it when you're talking to someone who deals with it. Not going to go through issues of ticket validity as you're more than well versed with that.
There were several issues of people boarding the stopper to LST with Via CBG tickets and being dealt with for it by RPIs etc.
When you also consider how busy guards are between BSE and SMK/IPS it's actually more than likely that said excess won't actually be available.
Getting back to the point of the topic just buy the Any Permitted, as you say, it's a whole £2.
Hadders
27 Apr 2011
I trust those being dealt with by the RPI were sold a change of route excess which would be half the difference in fare for one leg. Anything else would be concerning.
10 Mar 2015
Couldn't answer that, was never present when said dealings took place.
10 Mar 2015
Your posts suggest that you have first hand knowledge of this? Is that not the case?
Not of the conversations between passengers and revenue protection and the results of that no, advising and rectifying the issues as best I can on board my services yes.
Hadders
27 Apr 2011
You said there were 'serious issues' and 'cases being dealt with by RPIs'. I hope the advice you gave included saying that a change of route excess was available if a passenger wished to travel via Ipswich with a 'Via Cambridge' ticket.
10 Mar 2015
Today as I and my colleagues have done many a time I issued the excess and advised of the error yes.
The "issues" were more of an internal nature than in regard to treatment of passengers and would therefore be inappropriate to elaborate on publicly.
As I stated in my original comment (which I wouldn't have posted had I known it was going to be forensically examined....) the better option is the Any Permitted routing to avoid any undue concern.
If you're unsure of the route you will take, you buy the cheaper fare and excess the relevant portion(s), to avoid overpaying.
10 Mar 2015
Yes you or I would, but I would honestly (personally) suggest that given the small difference £2 is worth it for the ease/peace of mind of someone perhaps less versed in the complexities of ticketing.
Starmill
18 May 2012
Bolton
The passenger doesn't need to be versed in the complexities though. The procedure for excessing is simple, routine and easy.
10 Mar 2015
95% of people will have no idea the concept exists. You must remember those of us on this forum have either been trained in ticketing or take a personal interest. Joe public doesn't have a clue because most of the time they don't need to.
Any time spent on the front line of this country's railways will teach you that. While I again agree with the principle of your comment the day to day application is often different.
Starmill
18 May 2012
Bolton
I agree entirely. None of this was ever in dispute. Staff all know how to do the excess and anyone properly trained would get something so basic right. You are correct people will never have heard of it. And they don't need to have. I just don't see how it can be a 'serious problem' given the solution is so easy.
10 Mar 2015
It was a turn of phrase, nothing to be taken too....seriously...:lol:
