From memory one of the recent prosecutions involved someone being injured after doors were reopened.
Beyond that:
- it creates further delay;
- the person you’ve re released for will often then hold the doors open for others, or realise it’s the wrong train and amble away.
- they often don’t realise you’ve re released and remain standing on the platform despite BIL lights glowing into their faces!
Besides that, what happens when it's a platform dispatcher? Should they instruct the guard to re-release the doors for late passengers, which in the eyes of procedures isn't a reasonable reason. The guard may refuse to re release just for late passengers and if the dispatcher won't tip them and thinks they ought to re-release you'd end up with a bit of a quandary. Better if both follow procedure and instruct to stand clear. After all, they're late.
once the guard has closed their local door, they cannot see what is going on outside.
Absolutely, and it is better where there's either a drop light or a dispatcher on the platform, or both, for more reassurance. However, the case at Bishops Stortford from a few years ago seemed to demonstrate that as far as the law is concerned, if the person in charge of dispatch carries out a full and accurate train safety check, and everything is clear, if someone gets trapped after that and injury is unable to be prevented then the indication was that the person in charge of dispatch is not responsible for causing the injury. Which seems absolutely right imo.
Can you elaborate? Why is that more likely compared with releasing the doors the first time?
Because re releasing the doors for running panicing passengers may potentially be done hastily so as to avoid delay, and rushing potentially causes mistakes.
