Buxton Line
tonysk14
24 Apr 2016
Due to a landslip caused by very heavy rain, the Buxton Line is closed between Hazel Grove and Buxton until at least Wenesday morning.
lincolnshire
12 Jun 2011
Wondered why it was rail replacement today.
or
Is it a new automatic ballast cleaning system then?
NorthernSpirit
21 Jun 2013
Anything to Buxton is starting / terminating from Hazel Grove with rail replacement running from Hazel Grove to Buxton.
There's a 156 trapped at Buxton (along with probably one or two others), so I very much doubt that Single Line Working could be used as far as New Mills Newtown and then work back to Buxton.
185143
3 Mar 2013
Visited Middlewood today.
30907
Sorry, don't follow your train of thought :)
Surely, having the units means that a shuttle could be introduced?
Signal Head
26 May 2013
Are there any refuelling facilities on that section? Otherwise it could be a short term service.
Not since the depot at Buxton shut years ago, I suspect. Anyway the layout and signalling at Buxton doesn't make for easy access to the Peak Forest line from the station, it needs a reversal in the sidings, by the time you've faffed about with that, it's probably quicker to use a bus.
Signal Head
26 May 2013
From Northern's website:
"Due to a landslip between Disley and Hazel Grove all lines are blocked.
Impact:
Train services running through these stations have been cancelled. Disruption is expected until the end of the day on 19/06/16.
Customer Advice:
Due to a landslip services between Hazel Grove and Buxton, in both directions, are suspended - Network Rail staff are on site it is estimated that five to six tonnes of debris are currently blocking the line an estimate for repair is not currently available.
Rail replacement road transport is in operation between Stockport & Buxton."
So it's going to be shut for a week. What is interesting is that this mentions tons of debris blocking the track, which suggests a slip onto the track from above, whereas the photos from Middlewood clearly show the track undermined by a slip out from under the formation.
I wonder if this is just miscommunication (the same information was put out early in the incident, maybe before the full facts were known), or is there another blockage, of a different type, elsewhere?
Loop & Link
22 Feb 2015
There aren't, any units that are trapped will require moving probably on a 'one journey only' basis to get them back to Newton Heath/Longsight for fuel.
palmersears
20 Sep 2011
When I arrived at Hazel Grove this morning I found the 06:44 TPE, which usually passes straight through, made, what appears from RTT, to be a scheduled stop. This is repeated for the next two xx:44 services as well.
Nice to see a bit of collaboration between Northern and TPE to help try and lessen the impact, particularly given a large number of folk will probably bail on the RRB at Hazel Grove instead of continuing to Stockport.
For those of us without knowlege of the area, why can't they? Is the track from Tunstead to Buxton nolonger there?
http://www.realtimetrains.co.uk/train/H32962/2016/06/12/advanced
Shows that the trains to Tunstead are still running
The route through peak forest to Buxton is there to my knowledge. If they can't operate over there I would assume it to be something to do with lack of route knowledge, or possibly deficient signalling at Buxton. Someone with more knowledge than me will probably be along to say.
3141
1 Apr 2012
Whitchurch, Hampshire
I've travelled last year from Buxton to Chinley via Peak Forest on a railtour. As an earlier post says, you have to reverse in the sidings at Buxton. Then there's a lot of single track, which may mean that the service frequency that can be provided would be less than normal. You'd probably need extra staff to supervise the reversing, and Northern drivers may not have the appropriate route knowledge. This might be worth sorting out if the blockage was going to last months, but for a week then replacement buses are the obvious answer.
Dr Hoo
10 Nov 2015
Hope Valley
There was an extra freight move from Heck to Dowlow the other week that ran via Peak Forest and the Buxton run-round. It had to wait at Earles Sidings loop (near Hope) for three and a half hours for its path forward.
That illustrates how little spare/diversionary capacity there is that way even before you start thinking about route knowledge.
A0
19 Jan 2008
Surprised they haven't also put road transport from Buxton - Macclesfield as well. That would at least give passengers for Stockport and Manchester a slightly better journey.
DarloRich
Fenny Stratford
What, a RRB over the Cat and Fiddle a better journey? Are you serious?
can we? ;) that WILL be fun coming down round those bends in a big double decker. It will like the Italian job
BTW was there not once a railway radio transmitter next to the cat and fiddle?
A0
19 Jan 2008
No reason why not - in fact didn't Virgin use to run a link bus from Buxton - Macclesfield providing through tickets to London? Saved travelling via Manchester to get to London. I assume that used the Cat & Fiddle - and it's not the middle of winter....
Philip C
21 Feb 2013
There is an hourly bus between Macclesfield and Buxton. Why does it have to be a double-decker anyway?
brompton rail
28 Oct 2009
Doncaster
There is an hourly bus service Buxton to Macclesfield- all that is needed is agreement between Virgin West Coast and High Peak Buses, tho' that could take longer than a week to arrange!
There's a service bus if people want to do that, isn't there? Though I don't believe it's frequent these days. Edit: it's actually hourly, so not too bad.
It is a very enjoyable ride in summer, though. I did it a couple of times in the days of the Virgin-Stagecoach RailLinks.
Haydn1971
11 Dec 2012
Sheffield
The EMT service to Liverpool that followed also stopped at Hazel Grove - we were a tad confused at Stockport looking different ! ;)
I may be being thick here but what reason is there to stop the TPE and EMT trains additionally, if the trains that are supposed to be going to Buxton are terminating at Hazel Grove, which therefore has a normal service towards Manchester?
