Thanks for the gross misrepresentation there. I don't recall saying there was "no point" in trying to hit those targets - just that there's no point holding the Wales and Borders network back waiting for an electrification that isn't going to happen. If we waited 10 years as you've suggested we'd be in the exact same mess we're in now, only without the benefits the big uniform fleet of 197s is going to bring. And the network has been waiting long enough as it is.
My appologies for the misrepresentation. However, I can't see how you saying that electrification "isn't going to happen" is any different to saying that Network Rail is going to miss its decarbonisation targets (
says here they are targeting 2050 in line with the UK commitment). Completing the TDNS recommendations by 2050 means getting rid of virtually all the CAF DMUs by 2050, that won't even give the 197s a 30 year life, let alone 35-40. Building a large number of new DMUs, as the UK has done with the CAF Civity classes 195-197, is something that one would only do if one had decided/accepted we are going to miss those targets. Unless of course there was a large amount of work for units which spend little or no time under-the-wires (so would
not use the OHLE for charging batteries etc.) in the decarbonisation plan, which there is not.
Waiting, and hanging onto 158s, until they can electrify some bits of their network and procure hydrogen/battery stock for the rest is exactly what ScotRail are doing...
I'm not some kind of caveman politician who doesn't care about the environment - far from it. I'm just a realist about the speed with which the British network is likely to be electrified, and I want to see the best possible improvements made within those constraints.
Unfortunately, when I look at the current suituation and say to myself 'how quickly are we likely to decarbonise' I come to the conclusion that we are going to miss the 2050 target. Being completely realistic about the
likely rate of electrification (given the Government/Treasury's apparent attitude and the existance of the 'class 195 blight') then I would agree that we are unlikely (on a GB-level) to get anywhere near the necessary electrification to eliminate the Civity DMUs by 2055.
Indeed, I suspect that was my view back in 2018 and my focus was probably more on the interior spec back then. Certainly there was a point when I wouldn't have been particularly worried about Wales introducing new straight-DMUs on
some routes, provided the 158s and/or 175s were kept and cascaded to the likes of HOWL and Conwy valley. This would have given somewhere the new fleet could be moved to in favour of new bi-modes once something high-priority like Cardiff-Swansea was wired.
However, the TDNS has now shown that, leaving aside the Government/Treasury issue, the electrification of much of the GB network (including the Welsh network minus stuff like the Cambrian and some shorter bits) by 2050
is a
realistic goal. Note the difference between likely and realistic, the former leads to dismay and large orders for new straight-DMUs. The latter is perfectly acheivable if we put our minds to it (or would have been without the CAF DMU fleets).
In this case, a brand new fleet of modern low emission diesels running an improved timetable that will transform the network and help get people out of their cars is likely to help a lot more than by dragging our heals for another 10 years patching things up where we can with a knackered fleet - only to be left in the same place we're in now. It should also be a lot cheaper in the long run, leaving more money to spend on other projects that should also help the environment.
At no point in the last 5 years (and quite possibly longer) have I thought that the Wales & Borders franchise should have simply carried on with the fleet inheritted from Arriva Trains Wales. Yes, I believed (and still do) that the class 158s and* 175s should be retained but they needed to be suplemented by new diesel or bi-mode units** and the Pacers and Class 150s clearly had to go and be replaced by an electric fleet for the SE Wales Metro.
The fact is, by waiting 10 years (as, again, ScotRail is doing) before replacing the fleet we would get to benefit from the development of hydrogen and battery technology. You get
another 10 years of burning diesel***
followed by a 'decarbonised solution', instead of another 30-40 years of burning diesel in a Civity before you can do anything significant.
* at times this has been and/or
** at times, this has been new units and/or more 158s
*** and 158s are lightweight units which perform very well in terms of fuel economy
holding back ordering new stock in the hope of a mass electrification of the Welsh network in 10 years is madness
Where did I suggest
Welsh network in
10 years? Right now, the most-optimistic scenario I can dream of for TfW would see only Cardiff-Swansea, Wolverhampton-Shrewsbury and perhaps some Metro extensions actually completed within 10 years. One point is that if the entire fleet is incompatible with OHLE than you cannot even do a little bit of electrification. By the time the class 197s actually enter service it will be less than 10 years before we could have had 40% of the route between Swansea and Manchester wired. Another point is that it also rules out electrification in the 10-35 year timeframe as well.
also worth noting that even a diesel train is far more environmentally friendly than all those cars the passengers could be driving but thats off topic
That's true at the moment (provided those passengers would otherwise be driving and are not just abstracted from buses). However, Graham Parkhurst, Professor of sustainable mobility and director of the centre for transport and society at University Of The West Of England had this to say on the subject:
“my biggest concern is the rise of the electric car. Possibly energy coming from somebody’s home PV panel system. So, in effect they’re using a vehicle which they regard as completely clean, completely green; and public transport really must then decarbonise if it is going to be able to compete in that psychological battle. That, if I have an electric car, I might feel I’ve done my part, I’ve done my decarbonisation why on earth should I ever use a bus or train again if they’re still supplied by diesel?”
(Quote is from:
http://www.senedd.tv/Meeting/Clip/4...9ec8f46ba2?inPoint=00:00:00&outPoint=04:04:31 - fast forward to 00:15:30)
Returning to the question of whether passengers would actually be won out of their cars, the complete replacement of 158s and 175s at TfW with 77x class 197 would:
- increase some overcrowded services from 2 or 3 coaches to 4 or 5 (a very big PLUS to the 197s)
- reduce the provision of toilets, to less than that recommended by the Rail Delivery Group's best practice document (MINUS point to the 197s)
- reduce the provision of bay seating in each unit (MINUS point)
- result in an inferior product for scenic lines, due to poor window alignment (MINUS)
- reduce the legroom in airline-style seating compared to a 175 (and the number of seats in a 2-car unit compared to a 158), while increasing standing capacity (MINUS)
- remove enclosed vestibules (a MINUS in terms of the passenger experence, for at least two reasons)
- reduce the space for large luggage that cannot fit in the overhead racks (MINUS)
- increase the capacity of the overhead racks, allowing larger items of luggage to fit (unconfirmed, but beleived to be true; a PLUS to the 197s if it is)
- downgrade to Fainsa seats (a very big MINUS)
- eliminate the problem of the 175s not having unit end gangways (a PLUS to the 197s)
Feel free to add to this list, I'm sure I've missed some (on both sides of the argument, but particularly on the plus side).
Similarly I'd love to have a Mercedes sitting on the driveway of my mansion, and to be flying business class to Australia for my holidays this year. Sadly magic money trees only exist in the gardens of members of the Cabinet.
And for the people who can afford the Mercedes (or any halfway modern car for that matter) (let's ignore the bit about the mansion), are they really going to give that up for the above?
Perhaps the underlying reason I've been on this crusade against the 197s since the first renders appeared was that they crushed my dreams of a really attractive service that would take on the car on the M4 head-on by trying to provide a fast and pleasant experience.
Nowt wrong with doors at thirds for regional expresses. Nobody would be saying 170s were wrong for it.
You could say that, and you would be wrong. There absolutely
are people who say that 170s are wrong for trying to be regional express units. I'm one of them, but since the opinion of obsessive enthusiasts such as myself seems to hold little weight in these arguments I offer my brother as another example. We once (many years ago) sent him on a Cardiff-Nottingham train and afterwards he told me ‘the doors were in the wrong place’ (he wouldn’t have been able to identify what type of train it was and I wasn’t there to see it, so I cannot swear 100% that it was definitely a 170 but has anything else worked that route in years?).
The UK has limited electrification resources, its much better to focus them on electrifying other lines (like the Chiltern mainline/Snow Hill lines, MML, ECML branches, some of GWML) would be a better use of resources than a lot of Wales.
In the short-term yes; but a new train fleet is a long-term decision. Once the big-ticket stuff is done (perhaps late 2030s, early 2040s, if we get a Government who is serious about decarbonisation) electrification needs to roll on to routes like the Welsh Marches, but it cannot now we are plauged by all those CAF DMUs. Based on how things are going with the Sprinters, in 2045 the class 196s and 197s will have another 12-17 years life left in them. If we hadn't built all those DMUs, we could be wiring up more routes then.
