Until any form of electrification is confirmed or even gets any sort of funding. DMU such as the 197s are the option we have in terms of modern DMU. This same electrification argument could be said about the 196s.
They are not the only option we have. Although I don't think FLIRTs would be ideal for the routes concerned, both 755s and 231s would have been a better choice from a decarbonisation perspective than 197s assuming the 231 is as easy to convert to bi-mode as I believe it will be. There's also the possibility of a bi-mode Aventra and I think CAF's website offers a bi-mode Civity although it's not clear whether they can do one to UK loading guage. Diesel-only trains should be ruled out; indeed the TDNS strongly advises against procurement of new diesel-only stock. As for the 196s the difference is they are only a small fleet that could easily be cascaded to replace 150s.
I agree the 197s may not be ideal for people (especially considering the trains they are replacing) but
their definitely is time for them to be improved in terms of layout and seating.
They could improve the interiors at a refurbishment yes, but they cannot hope to match the trains they are replacing with that bodyshell. To be suitable for long-distances they need an extra toilet and the space for that has to come from somewhere and the 197 bodyshell wastes space by having wide doors.
Hopefully TfW will come to their senses and try a bi mode conversion for the 197 fleet at some point? Surely that will have more chance at getting funding than electrification schemes?
I suspect that if that had been the only problem they would have added cables. It's not exactly a difficult problem. Crikey, Pendolinos have a 25kV bus bar along most of the roofline, and this would be low(er) voltage. There were lots of issues with Project Thor which meant that building new Class 80x make more sense than doing it.
It may not be the ONLY reason Project Thor wasn't a goer, but it was a contributing factor apparently. As a mechanical unit rather than a DEMU, a bi-mode class 197 would appear an even greater challange than e-Voyager. If e-Voyager ended up in the 'too difficult' bin I suspect the same will happen with the 197s. It would certainly be harder than buying a new bi-mode to replace a practically life-expired 158 in 2030.
The only place I hear backlash against ironing board seats is on here, particularly given that the variant they used has a different (thicker and contoured) seat base and is thus nothing like the Thameslink one (say). It's actually a very comfortable seat (by modern standards) that by its simplicity suits people of lots of different shapes and sizes. To me it's vastly better than a Sophia (which is why I think TfW made the wrong choice there) though that's my opinion and not everyone agrees.
I've not used either seat enough to form an opinion on which is worse, but I dislike both.
The longest routes these operate on are the Barrows and Windermeres, but most people aren't using them end to end.
Really? I thought something like Leeds-Chester or Blackpool-York would be longer. Maybe Northern's regional routes weren't as long as I thought they were.
Rhydgaled said:
If you ask me the 195s are even worse than 197s, if it wasn't for the embedded carbon instead of saying cancel the 197s I would be saying send them to Northern and scrap the 195s. If people actually want to use 195s then maybe car makers should start putting blocks of wood in instead of padded seats.
It would be madness to scrap the 195s. While I would still describe them as "poor man's Turbostars" they are a vast improvement on just about everything else Northern have other than 158s, and they are much more suited to busy services than end-doored units.
Yes, it would be madness to scrap the 195s - my suggestion that they should be scrapped had an IF in it - note the "if it wasn't for the embedded carbon" bit. Maybe I should have been clearer that that is a very big IF.
However, I disagree with the rest. The only things they are a 'vast improvement' on are 150s and Pacers. With 153s (in pairs), 155s and 156s there's not much in it, there are pros and cons to each type.
Emptying out a full-and-standing 158 takes well upwards of 5 minutes, it's like emptying out a full single-door double decker bus. Whereas a 195 loads and empties in seconds
The problem there is the 158 is full and standing. Any regional service should not be full and standing, rolling stock needs to be matched to the route it works. A stopping commuter service needs something like a 196 or 197, a regional express needs something like a 158.
They'll be about 35 years old by then. No need to get hung up on "oh, but a train has to last 50 years" like people were with say the HEx units - it doesn't, 35 is perfectly respectable.
I wasn't suggesting they would last more than 35 years. I was suggesting that:
- if we didn't have 77 class 197s, there could be a small amount of electrification (eg. Cardiff-Swansea) between now and 2042 and
- if we didn't have 77 class 197s, there could be quite a bit more electrification between 2042 and 2057
However, in 2042 the class 197s will only be 20 years old, which works against electrification of Cardiff-Swansea for example. Similarly, any electrification that might have taken place between 2042 and 2050 may be delayed until after 2057 to await replacement for the class 197s.
I've heard quite few very positive comments about them. I can't recall them all, but I've certainly heard "wow, this is much nicer than the London train" from someone changing onto one at Lancaster - yes, comparing a cheapo DMU with a rather more expensive Pendolino.
Have any of these positive comments compared them to a car? Maybe most people don't share my dislike of hard seats and a view of a window pillar.
Do any 3-car UK trains have one toilet per carriage? I can't think of any. 2 in the unit is most common, one big and one small.
43096 said:
Ummm, what about the very trains the 197s are replacing - don't the 3-car 175s have one toilet per car?
I can't remember now. I think it's two per unit (one big, one small) but I could be wrong.
The 175/1s and 3-car 170s are listed as having three toilets on TfW's stock specification spreadsheets -
see here for example. While I think most 170s only have two toilets, the 3-car units TfW have are an exception I believe.
Those wide doors will be an advantage on busy trains, particularly on the Cambrian Coast in summer.
Double-edged sword. At the same time as getting passengers on and off faster they mean less space for tables (which may loose some repeat business from passengers hoping for a scenic journey) and all those passengers forming a queue for the one and only loo. If you fit a second loo, you further reduce the seating capacity.
Rhydgaled said:
It doesn't matter where electrification happens first, and I agree most of Wales will be a way down the list. The fact is 161 Civity DMUs is a barrier to completing Network Rail's recommended electrification programme by 2050.
That is not a fact, it's your opinion, and with respect I completely disagree with it.
Fact: 161 Civity DMUs have been ordered. Fact: given a 35 year life, they will still be running in the early 2050s. Fact: they are not bi-mode, so they don't contribute to the business case for electrification. Fact: the TDNS recomends widespread electrification.
I'll accept that my statement may have been partly opinion-based, but
under 130 self-powered trains (most of them bi-mode) are needed if the TDNS is implemented in full. So forgive me for struggling to see how having 161 straight DMUs still running in 2050 is in any way compatible with getting to that stage by then.
