CAF class 197 Civity for TfW: News and updates on introduction.
Neptune
29 May 2018
Almost everything emerging from Hitachi Newton Aycliffe and CAF Newport is imported (electrics, bogies, diesel power packs etc).
But the same is also true of output from Alstom Derby.
UK suppliers do supply various smaller parts to all the UK assembly plants, and bodyshell welding is available at Newton Aycliffe and Derby.
Hitachi and CAF can build you the same train in multiple locations (eg classes 802, 196).
The MTU power packs for class 80x bi-modes are made in Germany at a plant owned ultimately by Rolls-Royce.
It's a global world.
That’s my exact point. People get so hung up about these things on here as if it’s some sort of embarrassment, but the truth is that nobody really cares. Most people are just happy that people in the UK are employed to put trains together in a factory, they don’t care where the parts come from. Only rail enthusiasts seem to be bothered that the parts are built abroad.
Mordac
5 Mar 2016
And as @LNW-GW Joint alluded to, this would be true regardless of where it was built. It's an interconnected world, something as complex as a train is not going to be able to have every single part built in any one country.
Neptune
29 May 2018
I know. I’m ageeing with them. What I’m saying is that some people seem to get so hung up on the fact that not every part is built in Britain and saying that ‘Made in Wales’ is the wrong term and it should say ‘Assembled in Wales’ or whatever. It’s just good marketing.
I’m also saying that I along with 99.9% of people don’t care where parts come from and CAF putting ‘Made in Wales’ on the train doesn’t at all matter.
william.martin
18 Oct 2022
Telford
I thought the body shells came from CAF in Spain and that Llanwern just assembled all the components?
Surely Llanwern is the only train assembly plant in the world alongside the railway that sends completed trains out via road?
Interesting that it does actually say 'Made In Wales' even though that 'factory' is just an assembly plant - Hitachi with their similar plant in the north-east used the strapline 'Made Great In Britain' - a subtle difference.
Good luck finding a train on the whole of planet earth that all components are dug up from the ground, turned into a material, formed to make the part and is put together with all of the other parts in the same country it operates in.
The_Train
2 Jun 2018
New build I believe.
You'd think they'd check if a rail connection could be made before committing to the location, unless drags were never an option.
Is this site planned to remain beyond the build process as a maintenance facility or is it just temporary for the build process?
Anonymous10
19 Dec 2019
wales
Believe just build maintenance is planned at Chester and Machynlleth with light maintenance at Canton.
The Newport plant is also producing the class 196 fleet for WMT, and can bid for other orders.
CAF has actually increased its presence in the UK by adding a maintenance capability at Chester and at Longsight (Manchester).
These were not planned when Northern placed its 195/331 train order with CAF.
Anonymous10
19 Dec 2019
wales
Granted but the Newport facility has no rail connection and would be difficult to connect. So I doubt it'd be used but that's off topic
tomuk
15 May 2010
A connection was planned the factory is tantalisingly close to the goods loop that served Llanwern Steelworks. Unfortunately somebody at the Welsh Government didn't do their homework and realise there was a large gas main in the way and that to get around the gas main would need major work.
Envoy
29 Aug 2014
Surely, the gas main does not surround the whole site at Llanwern? You would think a solution could be found - even if it involves co-operation with the steel plant to the east?
I just don’t understand why these trains have to be taken all the way to Shropshire by road to be placed on the railway?
Dai Corner
20 Jul 2015
Here's an aerial view showing the gap of less than 20m between the CAF and Tata tracks.
Rhydgaled
25 Nov 2010
My point was more that Hitachi chose to be clever with the wording on their marketing materials 'Made Great In Britain' unlike CAF/TfW with the 'Made In Wales' claim.
Neptune
29 May 2018
Sorry I fail to see the difference which in your opinion makes Hitachi’s marketing clever and CAF’s not. Both are saying ‘made in….’ for assembling trains using parts from abroad.
Unless it’s your increasingly dull anti-CAF side clouding your opinion of each company’s marketing.
Topological
20 Feb 2023
Swansea
I had not thought about it, very subtle.
Hitachi are not saying their train was "Made in Britain", their wording allows the train to be made somewhere else and for the part that is in Britain to simply be what made the train "Great". Works because of "Great Britain" but does not actually make any claim that the train itself was made in Great Britain.
The Welsh on the other hand is very direct.
Apt I suppose.
Krokodil
23 Jan 2023
Wales
Look carefully at the wording and you'll see the pun.
Rhydgaled
25 Nov 2010
Exactly.
I'm not anti-CAF; while I am dead-against the class 195 and class 197 DMUs, I don't have the same hate for some of their other products. Indeed I think the TPE class 397 Civity units are in some respects closer to being a good train than the Hitachi class 800/802 units. If Hitachi were building DMUs to a similar spec as the 195s I would be against those units too.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
If we’re not let down by a driver that doesn’t sign, Cardiff should see its first 5 car working tomorrow on the 0624 from Holyhead. Plenty of room on that one for sure.
sd0733
7 Nov 2012
Unless everything has gone through very quickly over the last few days, that'll highly likely swap at Chester, only officially signed off 4 car max other than between Chester and Manchester Airport until the last lot of proving is rubber stamped.
As far as im aware the whole lot from the recent testing is all still awaiting finalising
197051 is a non-ETCS unit. ETCS ones are 003 and 022-042 inclusive
I was on 042 today between Crewe and Chester.
I think it had square wheels.
Easily the worst rider of CAF DMUs I have ridden, along with continuous knocks and bangs from underneath.
043 onwards from Chester was much better.
But neither of them was up to 158/175 standards of ride.
And can we get an "s" added to the English announcement "Thank you for travelling with Transport for Wale" (it's the same on the Mk4s too)?
