Calculating Ballast Resistance
t o m
7 Feb 2011
Ballast resistance is the total resistance between the rails due to the ballast, sleepers, point fittings etc.
It can affect track circuits. As you may know a current flows through the rails to form a track circuit but if there is low ballast resistance, due to wet weather for example, it can shunt some of the current away before it gets to the relay end and cause the relay to drop, thus showing the track as being occupied.
NLC1072
17 May 2010
Ireland/London
Got it! :D
John Webb
5 Jun 2010
St Albans
The ISRE (Institution of Railway Signal Engineers) 'Green Book' No. 9 deals in broad terms with track circuits. It says that the ballast resistance can vary from 1 ohm to 30ohm per 1000 feet of track depending on the type of track and particularly the weather! Voltages are kept as low as possible to minimise losses in the ballast resistance.
Unfortunately the book does not describe the usual method of measuring the ballast resistance, but it would presumeably involve precise measurement of an input voltage and the resultant current; specialist equipment would be needed to do this.
The Snap
10 Jun 2005
We use the Megger equipment at work. See here: http://www.tklink.co.uk/products/megger.aspx
This allows us to test for continuity and stray current in the rails.
Don't ask me how they work or the principles of measurement though, as I don't know! ;)
John Webb
5 Jun 2010
St Albans
Is it the DLRO10 low resistance ohmmeter tester you use? (Pardon the question but I spent 30 years mostly measuring things!)
