How will the work then as it will be blocked in at Waverley went the locos come off and get stabled in the south loop siding.
I'm quite sure they will have thought of a way.
Not quite - they are both on the Highlander - 1S25
1S26 should be 90045.
And it was, with the battleship grey 90047 doing the Carstairs - Edinburgh portion
First time both locos on a sleeper move were required for me in ages. The Edinburgh seats was pretty much full that night, I counted 3 empty seats after Watford Junction, at least this time the heating stayed on all night
Glad to hear the 90's you got were required for traction though if it was me I'd consider it unlucky that neither of the two legs were class 92 hauled.
Aah that explains the delays they were causing at Euston due to the train being overlength. Presume whatever arrangements they’ve made before for a pair didnt work or the platforms were swapped over?90 016 with 90 047 DIT on 1M11
Better getting the 90s in the book when I still can , as IIRC when the Mk5s start operating it will solely be 92s?
The only delays I can see this morning at Euston are attributed to a trespass incident. 1M11/5M11 was in P1 - can't see anything it was blocking in or out of P2?Platform 1 and 15 should comfortably fit 2 x class 90s and a load 16. Problems may have arose when the drag back loco came down to couple on as it may have been sitting foul at the country end.
Fairly sure it was the 0820 Manchester blocked in that started the issue. Mate stuck outside hence had a look!The only delays I can see this morning at Euston are attributed to a trespass incident. 1M11/5M11 was in P1 - can't see anything it was blocking in or out of P2?
1H12 08:20 Euston to Manchester Picc departed 8L from P5 at 08:28 - 5M11 was still in P1 at that time (didn't leave until 08:47) so don't think it could have been blocking it in. 1H12 was formed by the 1R05 set that arrived from Liverpool 3E at 07:47 so doesn't seem like any issues caused with the incoming working either.Fairly sure it was the 0820 Manchester blocked in that started the issue. Mate stuck outside hence had a look!
The attribution clerks evidently disagreed!1H12 08:20 Euston to Manchester Picc departed 8L from P5 at 08:28 - 5M11 was still in P1 at that time (didn't leave until 08:47) so don't think it could have been blocking it in. 1H12 was formed by the 1R05 set that arrived from Liverpool 3E at 07:47 so doesn't seem like any issues caused with the incoming working either.
On the 24th April I travelled on the Glasgow to Euston sleeper and it arrived 3h20m late into Euston. So made a compensation claim.
Today I got a cheque for the full fare and a £5 gesture of goodwill.
Isn't it the fact that if it's over 2h late then you are meant to receive a higher refund?
As Sleeper tickets are only ever sold as singles, the max delay-repay (full refund) threshold is hit when the train is an hour late in arriving.On the 24th April I travelled on the Glasgow to Euston sleeper and it arrived 3h20m late into Euston. So made a compensation claim.
It’s all in the Guest Charter:As Sleeper tickets are only ever sold as singles, the max delay-repay (full refund) threshold is hit when the train is an hour late in arriving.
I think some other companies, ScotRail for instance, will refund the entirety of a return ticket rather than just the disrupted portion when you are two or more hours late but as you don't hold a return ticket (even if you have booked a return journey), this option isn't open.
Indeed, at Watford Jn.1S25 left Euston on time tonight, but then returned to platform 1 . Seems to be a person hit by train on WCML
S25 on its way now leaving Euston 85L.Indeed, at Watford Jn.
92010 wasn't hanging around up Camden Bank.
Lines are very congested after the incident. 1S25 currently has 6 trains (including stoppers/freights) immediately in front of it on the Down Slow (Down Fast still blocked by the looks of it). Being able to do 100 vs 87 would be of little benefit currently. Indeed a loco that can accelerate faster is arguably more useful.Shame it wasn't a 90 at front to get a bit of extra fast running to attempt to reduce the delay caused by the sad event at Watford.
