Can a single 153 be called a train?
AndrewE
9 Nov 2015
It's only just occurred to me, but my dictionary says a train is "a number of things in a string... as... railway carriages or wagons."
Maybe that's why a trip from Crewe to Derby doesn't seem like a train ride any more!
Perhaps part of the fun is being part of the train!
A
HMS Ark Royal
2 Sep 2015
Hull
A
Yes, yes it can...
The same as a locomotive hauling a single truck or tank is hauling a train
Jona26
2 Jan 2013
West Sussex
A train was originally a 'train of carriages'. Should a 153 technically be described as a railcar or something similar?
AndrewE
9 Nov 2015
Maybe, but if ORR calls a 153 a train in their reports, thats what I go by
If you rely on our Civil Service's use of English as the way you understand the world then you will have a very lopsided view!
"Yes Minister!"
A train wa originally a 'train of carriages'. Should a 153 technically be described as a railcar or something similar?
Absolutely.
A
HMS Ark Royal
2 Sep 2015
Hull
There is a piece of string, and there is a string of things. A "train" implies the latter.
Just a late-night musing.
I am not sure what you have consumed, Andrew, but you might need to put it down
The whole thread is invalid as a simple search of the forum would tell you that we all call a 153 a train
RichmondCommu
23 Feb 2010
Richmond, London
I disagree...
Single car units have formed trains before and continue to do so.
Your argument is, therefore, invalid
I concur. The GWR did it with steam rail motors (there's one preserved at Didcot) and later on the GWR designed and built diesel rail cars (also known as Flying Bananas). From memory more were built to the same design after WW2.
HMS Ark Royal
2 Sep 2015
Hull
Thank you, Richmond... I suspect the OP has not seen any trip reports where we call 153s trains
Lou92
8 Feb 2014
Carlisle
It's only just occurred to me, but my dictionary says a train is "a number of things in a string... as... railway carriages or wagons."!
Operationally speaking, a train is just something that is used to work diagrams - the railway does not care about dictionary definitions. :p
Railsigns
15 Feb 2010
According to the Rule Book, the term train includes a "light locomotive, self-propelled rail vehicle or road-rail vehicle in rail mode".
HMS Ark Royal
2 Sep 2015
Hull
Well that clears that up! Mods to lock thread then? :D :D :D
I did not know that train covered a light movement
KeithP
26 Apr 2007
Which is probably how they get away with using the word diagrams. :D
AndrewE
9 Nov 2015
That clinches it. A specialised railway useage, but not the normal use of the word.
I must re-read my old rule-book. In my day a Diagram used to be one day's set of workings for a set (or sub-set) of stock, which actually did include single motor parcels vans, bubble cars etc. (besides "each" loco.)
507021
19 Feb 2015
Chester
I think a Class 153 can definitely be called a train, but I personally think the 153s are railcars rather than units, but that's just my personal opinion.
Railsigns
15 Feb 2010
The Rule Book definition of train has to be all-inclusive, otherwise the rules and regulations would be littered with multiple references to "train or light engine or single-car unit or permanent way machine, etc..." Once a "train" is occupying the running line, its composition becomes largely irrelevant - the signalling system can't tell one type from the other and, by and large, the same operating rules are applicable to all.
Harbornite
7 May 2016
I used to associate a train with being multiple vehicles, so a light engine or railcar on its own wouldn't count. Having just read those definitions, I've changed my mind. At least we can all agree that 153s aren't multiple units when working on their own!
Ah, but they are capable of working in multiple. That makes them multiple units in my book, and indeed in the spotter book too.
A 153 on its own is a single multiple unit!
Johncleesefan
4 Sep 2013
Yes a single 153 is definitely a train and a multiple unit even when working solo. Why overcomplicate something that is simple. (I do however say I'm driving me bus when working the single shuttles) :)
Condor7
13 Jul 2012
Penrith
I actually think Andrew is technically correct.
Of course it is not going to change (nor should it) but just because a rule book calls it something or because it is in common usage does not mean it is correct.
For instance throughout the world we talk about the sunrise in the morning, and nothing will ever change that, but of course it is not technically correct as it is in fact the earth setting.
LowLevel
26 Oct 2013
The rule book definition is correct in terms of railways because at least as a railwayman, in terms of railways that's all I'm bothered about.
It isn't incorrect in that the railway has it's own distinct terminology in order to ensure safe and consistent operations, some of which like other industries may appear odd to outsiders.
On the other hand I'll quite happily agree that a 153 in and of itself doesn't really satisfy the dictionary definition of a train, but as it is an operational vehicle operating on a railway for the purpose of the railways it most definitely is a train.
I've had dopes before come up to me with the 'Ahh, but a 153 can't be a train' thing and I've usually made an excuse to leave as from a railwayman's perspective it's a daft debate to have.
jopsuk
13 May 2008
a single carriage train is called a train because it would be madness and confusing in day to day operation to call it anything else.
Mutant Lemming
8 Aug 2011
It is the opposite for a tram. A single tram is called a tram and when operating in multiple it is still called a tram.
pdq
7 Oct 2010
On a quiz show recently there was a question along the lines of 'what type of vehicle is the Flying Scotsman?' The contestant didn't know the answer (and guessed aeroplane) so the answer was given as 'train'. My wife and I shouted at the television that it's a locomotive not a train. But were we right?
