Carmarthenshire and Pembrokeshire frequency and electrification
higthomas
27 Nov 2012
I do hope that that's the plan, no reason why it shouldn't be but A boards aren't that common, or are they? First I heard of them was Birmingham New St.
They have - incidents more than accidents - it takes a degree of skill to have an accident with a train that's blown its horn and is accelerating from stop. One incident saw a bin lorry reversed whilst the train was stopped, with its banksman waving the bin lorry back (Llanion Crossing, 200 yds from Pembroke Dock) as if the train was letting it go.
An actual accident had a taxi slam in to the rear bogie of a 153 at the Beavers Hill crossing (for points not prison, nor lost licence). The taxi driver said he had misjudged the speed of the train (presumably thought it was going faster than it actually was) - https://www.bbc.co.uk/news/uk-wales-45260451
They had a rather expensive plan to close Llanion Crossing, diverting paths, building footpaths, acquiring land (see plan at https://www.networkrail.co.uk/wp-co...-routes-east-and-west-of-Llanion-Cottages.pdf) in 2020. The new idea sounds much more cost effective, and presumably the other idea dropped.
Maybe I'm just too naïve about costs of things, but surely just installing "normal" crossings with gates would be much the easiest solution and shouldn't cost a crazy amount?
anthony263
19 Aug 2008
South Wales
That will be a big improvement.
The other problem is the Maestegs that stop between Bridgend and Cardiff.
Whenever I have cause to track a GWR into Cardiff it is the Swanline getting held up by an ex-Maesteg in front of that one. Letting the GWR catch up with the Maesteg will be a bit better though.
I was also looped at Margam on a train to Manchester pre-Covid. No problem for me as I was going to Manchester, less good for all those going to Cardiff/Newport/Bristol who crowded onto the 175/1 when the GWR they really wanted sailed past.
Swanline been timed to provide a 2nd stopping service between Bridgend and Cardiff Central.
since they are on narrow roads even an 'Automatic Half Barrier' would presumably block the whole road, avoiding the AHB problem of dangerous driving by motorists zig-zagging through the 'open' half of the crossing
Because AHBs are unsupervised, there must be a escape route for people / vehicles trapped. Hence the half barriers.
A normal crossing - full barriers - needs full signalling on approach. Just converting these three would cost well north of £10m, probably twice that.
Caaardiff
9 Jun 2019
It is drifting a little, but the obvious sections that require an overtaking option for the GWR are between Bridgend and Cardiff, where loops do exist, and between Port Talbot and Swansea, where I do not think there is any option. For the latter Britton Ferry could be given a loop (I think).
The UP section of the district line that joins at Britton Ferry is next to the platform but doesn't actually have a platform joined. With some remodelling it could be the ideal place to put in a loop off the mainline while also being able to platform the Swanlines off the mainline too.
If Swanlines are being timed to leave Swansea 5 mins after a GWR, all it takes is a slight delay to GWR to either get stuck behind the swanline until Port Talbot or TFW having to wait for the GWR.
A loop at Britton Ferry could allow TFW to depart and the GWR to catch up and pass at Britton Ferry.
Meerkat
14 Jul 2018
While the new proposal sounds like it could be cheaper, but it isn't clear what the relative benefits could be. Presumably there still won't be wig-wag lights for the open crossings and, if there will be, why will the trains be limited to just 5mph?
5mph is barely moving, so the trains can stop quickly, but is moving - so drivers will hopefully stay out the way. The stop and hoot method has always seemed dangerous to me, inevitably leading to drivers thinking the train has stopped to let them drive across first.
BenBracken
16 Oct 2023
Pembrokeshire
Going slightly off topic, does anyone know how to get a run on the SDL these days? Which services take that route. Last few times I’ve taken a Fishguard or Milford service that is advertised as direct from Port Talbot to Llanelli it’s taken the line behind Landore. Any reason they do that over the SDL?
Dai Corner
20 Jul 2015
According to the excellent Passenger Train Services over Unusual Lines publication the following are booked via the Swansea District Line in the current timetable
Briton Ferry, Court Sart Junction/Up Flying Loop Junction - Morlais Junction (Swansea
District line) (126) PB09
Mondays to Fridays:
1V95 1040 Holyhead – Newport - Llanelli
1B62 2218 MTWThO Cardiff Central – Carmarthen
1B97 1250 Fishguard Harbour - Cardiff Central
fishwomp
5 Jan 2020
milton keynes
Note it is 5mph on approach. Presumably there will be “A” boards that enable the train to accelerate immediately after the front cab is over the crossing.
These crossings have had numerous incidents at them in recent years.
Passed two of the crossings today. Would this A board be after the crossing? If so, they are not there.. I also didn't notice anything unusual about the new 5mph sign.
BenBracken
16 Oct 2023
Pembrokeshire
TfW have launched a timetable review for December 2024, with the following proposals:
  • Additional calls to/from Milford Haven and Haverfordwest giving the towns 13 services per day in each direction
  • Extra services between Swansea and Tenby between May and September from 2025, subject to agreement with Network Rail
  • Amending four journeys to end at Carmarthen (instead of Cardiff Central as of today), though these will connect into GWR services Carmarthen <> London Paddington.(Connection times can be found in our timetables).
Would be interesting to know what the practicalities of these changes would be.
