krus_aragon
That's a decade ago, though: they won't be "current" on them any more.Some will already have been trained from when they used to crew them in FNW days.
In that case, you'd need to train the Victoria (Northern?) crew on the use of 175s instead of training TfW crews on the Stalybridge route. I don't think that'd be much of a gain.
Is a platform 7 at Victoria physically possible? Some sources say it is but I've no idea what's behind the wall adjoining platform 6. Even if just a bay platform is achievable it could be used for the Preston stopper, also the Liverpool stopper if plans to split the Liverpool -Man Airport - Crewe service go ahead.
Yep, after a cursory glance at Google Maps, and a wander around the station, I reckon you could add at least two, maybe three, west-facing bays at Victoria by extending out over the Irwell / Victoria Street. Problem is, of course, that it should have been done before electrification, as to do it now means moving all that gubbins as well.The old "platform 11" into Exchange is still there with a stabling siding. Plenty of room for at least one bay (and level access as well !)
The other option that always jumps out at me is adding a platform 6 at Oxford Road. There's space for another line, and a platform, north of platform 5... provided whatever is underneath is/can be made strong enough.
Additionally, reading the previous to last edition of Rail Magazine, it seems that NR have reported that an additional two tracks between Victoria and Salford Crescent would be beneficial. There seems to be plenty of land for this , as the route appears to have been quadrouple in the past.
Is that really necessary? From the looks of it that line has 9tph, all of similar performance (or at least they can all achieve any speed you can get up along there, the acceleration of some of the current stock might be awful) and identical stopping pattern on that section. How many other short stretches of two track railway support that level of traffic around the country? If it needs extra tracks just to queue up more trains waiting for platforms that seems a lot of money to spend to not really solve anything.
That would help massively, if the timetabling could be tweaked to allow it to be used to the full.The report itself suggests splitting the Victoria platforms in two with signals.
This suggestion is going to go down like cold sick but here goes...
Would it be *that* tight? And yes, I know it might only be able to fit 3 cars, but every little helps.The turnout into platform 6 would be incredibly tight and the platform would be short - not really that helpful.
You'd still need to provide a fast commuter service from Wigan though. It would help, maybe, by not running through to the airport. But still have to find west-facing capacity at Manchester somehow.Remove a service from an established IC market entirely in order to put it across to a city that will have lower demand and has no established market? Yeah, great idea.
You could send the Barrow/Windermere to Liverpool but it'd be easier just to lop it at Preston.
Doesn't need to run via Parkside, I agree. But it is needed. The loadings on that service are bonkers, even off peak.No, you don't. They never had one before, it's a recent thing and it only exists because of trains being sent there for reasons of operational convenience prior to the completion of electrification via Bolton.
You certainly don't need one all day. If the commuters shout too much, you could have a single EMU train pair Wigan NW-Victoria, out in the morning peak, back in the evening.
It could return once the capacity work was completed.
There is now no reason to be running anything via Parkside.
At commuter times the trains are standing room only to/from Wigan.I can't speak for commuter times, but I have used the Barrows via Wigan a number of times over the past few months, and mostly hardly anybody boarded at Wigan, they mostly got on at Preston. So at the moment it's a TPE capacity relief that once the 397s are all in use is probably not needed (there are also plenty of other Preston-Manchester services).
No, a Platform 6 at Oxford Road would not help, it would probably make congestion worse. The last thing the corridor needs is additional little 3-car trains weaving across the station throat, blocking all other services in both directions.Would it be *that* tight? And yes, I know it might only be able to fit 3 cars, but every little helps.
https://cdn.networkrail.co.uk/wp-co...-Corridor-congested-infrastructure-report.pdfTrains departing platform 5 at Manchester Oxford road must cross Up direction trains as well as have a gap between down direction trains. This is a difficult move to plan and reduces capacity in the rest of Central Manchester. Provision of a centre-turnback, that allows a non-conflicting arrival and departure would eliminate this conflict entirely. Trains would only need to be planned on headway and the opposite direction services are no longer a factor.
Impact: High
I may have missed it in all the posts to date, but haven't we an example of what can be done in a city not 50 miles from Manchester? Dare I suggest looking at Liverpool and thinking what could be done to get these lines below ground where they can arrange grade separated crossovers.
Newcastle and Gateshead put the Metro under buildings. Trying to cram more trains through a congested city on the surface is wasting time, effort and expense on plans that won't be a long term solution.
I was reminded of that today when passing through from Sheffield to Liverpool. Seeing the cranes and tower blocks all around it's clear that even a subway solution will be difficult due to the need to avoid their deep foundations. Squeezing more tracks and platforms alongside the old would create a legacy of continuing chaos.
Ooh, cutting.
Ooh, cutting.
You are talking to someone here who advocates the Merseyrail underground being replaced with street tramway, because we don't want Liverpolitans having anything which might be better than anywhere else
Realistic. I've got no issues with the additional Liverpools being put on, and maybe those will make it to hourly eventually. But removing the service from Manchester would be absolutely nuts - "M62 envy" would be the only possible grounds for it. Moving it to Victoria may make sense, but not lopping it. The case for the Barrow/Windermere is far, far lower.
Can you quote the post where I suggested that?
Though TBH I consider the two yellow metro systems at opposite ends of the M62 pretty equivalent, TBH. Each has up and downsides. One big downside of Merseyrail is the highest operating subsidy per passenger mile in the country outside of Island Line when you consider that the operating subsidy of Metrolink is £0.
It's depressing how some people attempt to undermine any attempt by anyone in Liverpool to suggest that anything in the city should be improved by suggesting that it is somehow down to negative character traits among the locals.
I seem to remember that you used subsidies as a reason to close Merseyrail on that occasion too. I mean, we can't possibly spend money on anything in Liverpool, not when there's not a single other railway service in the country which relies heavily on subsidy.
Maybe you could go back through your previous posts and flag up a single post where you have ever been in favour of any improvement to anything in Liverpool (your surprising concession that it should have additional services to Scotland notwithstanding)
