Chafford Hundred - via Upminster (Split Tickets)
BrianTheLion
14 Dec 2011
Port Glasgow
To avoid any potential issues with RPI's in the capital could someone clarify if the following is acceptable.
Im travelling to London in Feb in a party of 2AD/2CH. When Im there I will be using Day Travelcards, purchased with F&F Railcard discount, with the starting point as Wandsworth Town to London Zones 1-6.
Am I correct in thinking if I was to take a train from Fenchurch St to Chafford Hundred I could use my Travelcard as far as Uxbridge? so If I created a split ticket scenario and bought a ticket from Uxbridge to Chafford Hundred my full journey would be covered?
Apologies to Mike from OysterRail in advance because he did already reply to a pm regarding this for me but I want to be 100% certain because I dont fancy having to pay a fine for 4 people because i dont have the correct tickets.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
If you mean Upminster rather than Uxbridge, then yes this is fine as all trains call at Upminster. Alternatively you could purchase a Boundary Zone 6 - Chafford Hundred ticket, which is the same price. The advantage of Boundary Zone tickets is that there's no need for the train to stop (useful where there are trains not calling at a Z6 station), and the routeing is more flexible - you could go via Greys for instance (not that there's any advantage in doing so).
If you mean Uxbridge then I probably need to take more acid before looking at the network map.
greatkingrat
20 Jan 2011
I assume you mean Upminster, not Uxbridge! Yes, your travelcards will be valid as far as Upminster so you would only need to buy a ticket for the Upminster - Chafford Hundred section. I'm fairly sure all the trains to Chafford call at Upminster anyway so you don't need to worry about that.
BrianTheLion
14 Dec 2011
Port Glasgow
Thanks for the replies... and yeah I meant Upminster!! Im not actually sure where I got Uxbridge from in the first place... Think I must have just typed the first thing that popped into my head that began with a "U" - :oops:
