Change from Kilometers to Miles on BVE4
E.G.E.Bakker
27 Nov 2008
Bendigo,Victoria,Australia
[BHello Everyone ,[/B]
Is it possible to change from Kilometers ( on the left bottom portion of the screen to Miles ?
If that is the case, can I make the change myself ?
regards,
Ed Bakker
E.G.E.Bakker
27 Nov 2008
Quite Simply,
Its Impossible due to the way the programme was made.
thanks for the response, very helpful. In a way a pity, because I prefer to run BVE4 on a smaller screen and when you for instance do the Tyne valley route with an HST 125, you can hardly read the speedometer in miles.
Cheers from
Oxford
New Zealand
Ed Bakker
Darandio
24 Feb 2007
Originally when this bugged me, I just wrote down a little chart with the mph and kmh equivalents, it was ok, but I still prefer to work from the speedo.
E.G.E.Bakker
27 Nov 2008
Hello,
Yes ended up with a little chart as well, but like you prefer to use the
spedometer. It depends very much too which train you use on a small screen, with some of them you can actually read the speed on the meter.
Cheers,
Ed Bakker
skydo
15 Jan 2009
What does it mean to own a million numbers?
