PermitToTravel
But those are rules that you have to abide by, not us.
I am not debating what internal TOC rules state and I accept I am highly unlikely ever to be issued such an excess.We've had debates about what the new ticket actually is and, IIRC, the last time it came up some people, who don't do the job, disagreed with those who do, but what is not in dispute is that the rules say you cannot excess a TOC specific ticket to use another TOC.
NRCoC Condition 10 said:10. Tickets valid only in trains of particular Train Companies
The validity of a ticket may:
a) be restricted to; or
b) prohibit
travel in the trains of a particular Train Company or Train Companies. Any such restriction
or prohibition will be shown on the ticket. If you travel in a train with a ticket that is not
valid, Condition 2 or 4 will apply. If you are unable to use a ticket or any part of it, you may
be able to claim a refund under Condition 26 or Condition 36. For other restrictions on use
of tickets, see Condition 11 below.
You are bound by Condition 10 though, you can't simply ignore that because it doesn't fit your argument.
If any of this matters, would "Not underground" be considered a route or operator restriction? LU is listed as a TOC on the NR website but I'd argue that "Underground" should reasonably be considered a route...
But the ticket is converted into one without such a restriction shown. If I was ever sold such an excess and it was convenient to ignore the TOC restriction that has been excessed away then I would
I am not ignoring this. An excess would override any such restriction in the same way an excess overrides any C12 restrictions. By your argument you should not be able to excess an off peak ticket to an anytime one which is quite clearly incorrect....
....But the main point of my argument is that contractually speaking C10 is irrelevant anyway because the TOC restriction is clearly defined as the route....
....The restriction does not apply in any other way to the ticket's validity. Perhaps I'm reading my contact/ticket wrong, so if you can show me how the TOC restriction applies beyond the route then I will bow to superior knowledge. If the TOC is unhappy with this then they should not define the restriction as a route in the contact. It's a simple solution really![]()
This makes no sense to me. Are you saying thatr I were to get an excess from an off-peak ticket to an anytime one, I would still not be allowed to travel anytime, as the original ticket names the ticket type as "off-peak" and thus the off-peak restrictions remain in force, regardless of the excess?The excess is only valid with an unused original ticket numbered appropriately. If the original ticket is TOC restricted then it would only be valid on those TOCs named upon it and thus the excess would only be valid on them. If you want to try it, go ahead, I won't lose any sleep over it.
Accepted, and this would be the case if the TOC restriction was not purely routing based, which it is (see below). Although condition 2 and 4 have absolutely nothing to do with restricting my ability to get an excess so are irrelevant to this discussion. They only apply would only apply if I chose to travel on a ticket that wasn't valid. The whole purpose of me asking if there was an excess available (which in the end I never even sought) was to avoid this situation.Conditions 12 and 13 mention the ability to get an excess fare to change the terms of the contract, Condition 10 does not. Condition 10 is quite specific in mentioning Conditions 2 and 4 if Condition 10 is not adhered to.
All train tickets are issued subject to the NRCoC. Condition 1 states that my ticket is evidence of the contract between the train company and me. Under this contract the TOC restriction is routing based, as evidenced on the ticket which states quite clearly "Route: VTWC TRAINS ONLY" (here is another example coutesy of the wonderful ticket gallery). To suggest this is not a route is incorrect - the contract clearly states it is regardless of what any TOC rules and so on state. Thus I would argue that C13 does apply as it is a matter of routing, and this explicitly permits changes to a route following the payment of an appropriate excess fare.I disagree. Condition 13 makes no reference to TOC restrictions. Condition 10 is not irrelevant.
If the TOC restriction was routeing based then it would be included in Condition 13. It isn't, it has it's own condition, Condition 10.
Not valid on trains timed to depart after 04:29 and before 09:30.
(The only exception to this rule is that passengers travelling from Coulsdon South may use an Off-Peak One Day Travel Card after 09:15. Please see Restriction Code B2 for more details)
If the TOC restrictions were included under the validity field then there would be no problem here. I am even happy to accept looking this up when I am advised to "SEE RESTRICTNS B1" or whatever code is deemed necessary. There is nothing to stop TOCs doing this, and absolutely no reason why they have not done so to date, other than the explanation that the restriction is indeed a matter of routing hence why it is placed in the routing field. As it stands, I have gone to the effort of looking up the relevant restrictions and these do not include any TOC-specific restriction, other than that defined as the Route, which Condition 13 clearly states can be excessed.If they were not to put the TOC restriction in the route field, where would you suggest they put it?
Yes - this is what happened to me. I was in a rush and unintentionally purchased the VT only fare, rather than the any permitted.I'm fed up with these restrictive tickets. They cause so many problems and Virgin are able to get away with listing them at the top of their Piccadilly TVMs which leads to genuine mistakes for which the customer is penalised.
Yes, I no doubt am!The only solution will be to have them withdrawn, and everyone ending up with the more expensive Any Permitted fares.
The number of passengers affected is likely to be small, not that I am denying the fact that it is inflexible, but you are blowing things out of all proportion.
Yes, I no doubt am!![]()
If you mean "...by withdrawing TOC specific tickets, so everyone pays more" I disagree....The industry should be working to simplify fares.....
A little over the top.Tracky said:I firmly believe Virgin introduced the TOC specific fares - and retail them as they do not to offer 'their customers great value' but to abstract revenue from the lead operator on the route - and in doing so CON RAIL USERS.
Completely agree.Where sold I believe the TOC should make the restrictions absolutely clear.
Why not? Under this logic, you'd be against a Merseyrail Only ticket from Chester to Southport because ME don't operate any direct services - but Northern Rail do - so a Northern Rail Only ticket would be better?Tracky said:I don't believe they should be available on a route where the TOC has no direct services.
I disagree. Sunday services are infrequent no matter whereabouts in the country you're travelling. If one is able to pick a definite departure time then TOC Only tickets are useful - you can set your plan accordingly. For example, there is a four hour gap between VT services Chester - Llandudno Junction in the early morning. So you wouldn't buy a VT Only ticket anyway unless you knew you would be travelling on one.Tracky said:I don't believe they should be available on a route where the TOC has such poor Sunday journey options.
Yes, they are quite different. Do you believe the £32 LM Only return from Liverpool to London should be withdrawn because it's too restrictive?Tracky said:In this case I don't believe the tickets offer 'good value for money' as they are just too restrictive. Value for money and Cheap are quite different.
If that was a desired outcome I suspect it might be cheaper to write off the differences than to pay for software changes. It's essentially a zero-sum game anyway.Surely it's not beyond the ability of the poor souls who have to code the ORCATs distribution software to modify it so that, when a ticket is excessed:
- the revenue distribution from the original ticket is completely cancelled;
- the revenue distribution is re-done from the full excessed ticket.
Were that done, then the TOCs could be a little more passenger-focused and allow an excess that changes the revenue distribution.
On a related issue, what is the official reason why a railcard discounted fare can't be excessed to a non-discounted fare in advance of travel? That doesn't affect revenue distribution, and would be mighty useful where Two-Together passengers find they are no longer able to travel at the same time.
