coppercapped
Rather than derail the Class 800 thread in the Traction and Rolling Stock Forum any further I thought I'd start this new thread to continue the discussions on connections and traffic at Reading and leave the Class 800 thread to concentrate on the hardware.
We have had this debate about HEx before and i cannot understand your dislike of it. I think that it is an excellent service and it fulfils a market need for fast and comfortable links between the middle of London and its main airport. I have lived and worked in both Paris and Munich and using the airport rail links in both cities is a pain - they stop frequently and are not really designed to cope with air travellers' luggage. When I was in Paris the RER station was /between/ Aerogare 1 and Aerogare 2 and from either terminal it was necessary to take a bus first. In Munich it used to take me more than an hour to reach my local station of Pasing by S-Bahn, regardless of which of the two routes I took. This was about the same length of time as the flight from London... Getting off the last flight on Sunday night I frequently took a taxi from the airport although it cost five times as much but I could be back at my flat in 30 minutes.
Stopping trains to airports are BAD NEWS.
As to the waste of paths. As long as the service pays its way then there can be no objection to the service continuing - with the possible proviso that the opportunity costs of another (longer distance) service using the paths to and from Airport Junction generates more income for Network Rail. However the presence of the HEx trains means that Slough (all day) and Maidenhead, and to a lesser extent Twyford, can be served by fast trains from Paddington without holding up the train immediately behind. One could argue that with the advent of Crossrail these stops are a luxury which can be given up - but all that would do is ensure that even more people from these areas have to suffer slower journeys.
Why is it a given that the needs of people travelling further should outweigh those of shorter distance passengers?
All three routes serve the same end points but have different frequencies, intermediate calling points and connection patterns.
Changing at Reading off eastbound trains will link to local services to Didcot and Oxford, Cross-Country services to Oxford, Banbury, Leamington (avoiding a doubling back from Birmingham New Street), quite large and busy towns such as Maidenhead, Slough, Wokingham, Bracknell, Staines and stations on the Guildford route serving the huge area of business and housing around Blackwater and Camberley as well as the Railair coach service to Heathrow. Getting to the housing and industrial areas south of Heathrow at Staines, Ashford and Feltham off the ex-LSWR route if coming from the West Country is a non-trivial exercise - it's much easier from Reading.
If one is travelling to Gatwick alone with just an overnight bag, then the Paddington - Circle Line - Victoria route is acceptable. Using this route with two or more people and bags is a pain in the proverbial, have you tried getting bags down the narrow stairway to the Circle Line station in Praed Street? The same journey is much easier with one change at Reading with lifts to all platforms. Horses for courses.
The same thing happens in the reverse direction.
So 'where?' is quite big.
I apologise for the slight, it wasn't intended.I'm not a "train spotter", or at least I haven't stood on a platform with a book since I was aged under 10! Your posts are normally so well informed (even if I don't agree with your very strongly pro-commercial perspective nor about Reading), so this bit of childishness is unwelcome.
The reason I dislike HEx is that it is a waste of paths that could be used to far better ends once Crossrail becomes more convenient for everyone, as it likely will.
This I don't understand, 'where?' is a big place. I have assumed that the reference to 'West of England' trains referred to those from (points west of) Exeter using the Berks and Hants to Reading and London, not those routed via Bristol or the slower Southern services from Exeter via Salisbury and Basingstoke to Waterloo.But he does have a point. Continue their journeys to where? There isn`t anywhere that couldn`t be served from other stations from the West except maybe Oxford. The Gatwick GWR trains are so slow you`d be better off going to Paddington Victoria anyway.
'Cannot be bothered', why be so dismissive about people trying to earn a living and get home at the end of the day? Are you clear that 'the other services available' take twice as long to reach the destination than the one you are trying to cram in to and will similarly be crammed by the time they reach their destination? In both cases people will be crammed in for 20 minutes or so, but using the fast train they will have reached their destination in that time.Say that when the so and so`s cram into already packed trains from the West because they cannot be bothered using the other services available.
I agree there should be longer trains West of Reading.
This is about class 800`s.
