Chiltern Class 165/168 compatibility
nctd2306
2 Jan 2024
Berkshire
Apologies if it has been answered elsewhere (I know DMU compatibility has come up before in other threads) but I just noted this formation showing on Real Time Trains and simply cannot remember if such a pairing is possible in passenger service or if this can only be an error due to a set swap
chungusgoat1
10 Mar 2023
telford
it is possible and does happen a fair bit
12LDA28C
14 Oct 2022
The back of beyond
Yes of course. Why wouldn't it be possible? It happens regularly. Of course if the 168 is leading the driver just needs to remember there's a 165 on the rear!
Class172
Quizmaster
20 Mar 2011
West Country
I would say that it is a very reasonable question to ask, since 168s are very similar units to 170s (with some converted from these), but it is known that the latter cannot operate in multiple with the Networker Turbo 165/166s.
12LDA28C
14 Oct 2022
The back of beyond
The Class 168/0s were the first new passenger trains ordered after privatisation and were delivered in 1998. Chiltern would've been pretty stupid to specify units that couldn't be coupled to the existing fleet.
nctd2306
2 Jan 2024
Berkshire
Thanks all, I knew there was one Turbostar that couldn't couple to the 165s, just couldn't remember which one! If it happens regularly then fair enough, I don't live that far away from Chiltern land but haven't yet had the chance to explore their network, so I rarely check their allocations on RTT which is why this one took me by surprise a bit :D
Nippy
13 Aug 2013
I don’t know, I’m pretty sure there will be plenty of TOCs with new trains that aren’t compatible with existing fleets. I wouldn’t have thought the 730s and 350s with LNR are compatible.
12LDA28C
14 Oct 2022
The back of beyond
The point is that back in 1997-98 there were no other units being built and the likes of CAF, Stadler, Bombardier etc weren't supplying units to the UK market at that time. So there wasn't the wide variety of units with varying specs that we have now, over a quarter of a century later. Things were rather simpler then.
BanburyBlue
18 May 2015
Again, apologies for ignorance, but aren't 168/0's beefed up 165s, whereas the 168/1 and above are Turbostars?
150219
24 Nov 2009
The 0's (Clubmans) were designed to follow the Networker family, so an updated version of the engineering. By the time the main production line had started, the design had morphed into the Turbostars.
hexagon789
2 Sep 2016
Mechanically they are all 'Turbostars' though those built as 168s were branded 'Clubmans'.
The originals have a Networker-style cab, but still have the MTU engines and 100mph-transmission of the later 168s and 170/171s.
I suppose it depends how how you choose which similarities are more significant. Personally I would say the original 168/0s are closer to Turbostars than Networker Turbos.
Neptune
29 May 2018
Absolutely. The only real difference with 168/0’s and Turbostars is the cab. The body is definitely the same as a 170.
warwickshire
6 Feb 2020
leamingtonspa
Happens all the time, 165 is far better for a ride, especially for Nostalgia, only drawback if 165 is attached to a 168 on any of the services on the mainline, particularly on the Birmingham/Oxford to London Marylebones, the services are limited to 75 Mph due to the 165 only capable of achieving this speed. Resulting in a few minutes late on some of these services when it happens as a result.
What a Pity at the time, when the 165s on Chiltern was made at York, maybe at least they should have been allowed and designed to go faster.
BanburyBlue
18 May 2015
Surprisingly, we had a 165 on my morning journey to Birmingham Snow Hill the other day, instead of the usual 168. I was expecting to be late, but actually arrived into Snow Hill more or less on time.
AJDesiro
10 May 2019
Rugby
It's helpful that Chiltern services tend to have have very generous allowances, and that the 165s have superior acceleration to the 168s.
(Image shows 13:40 Birmingham Moor Street to London Marylebone on Real Time Trains, departing on 3rd March 2024.)
12LDA28C
14 Oct 2022
The back of beyond
Reminds me that when the 3-car 165s were first delivered, the centre cars had no speed limiters and so very high speeds were achieved.
How would that possibly work, given that the Chiltern 165s were max speed 75mph? The driving vehicles would have been limited to 75mph which would have prevented the middle cars exceeding that.
Most Oxford services now have sufficient recovery time built into the schedule so if a 165 is substituted for a 168 or coupled to one, the train can still run with no loss of time.
LowLevel
26 Oct 2013
The Great Western 165/1s have yaw dampers on the bogies which is why they can do 90 and the Chiltern ones are only 75 - whether this was cost saving or simply the tripcock gear for running on the Met making it impossible to also fit yaw dampers to that bogie design I don't know.
12LDA28C
14 Oct 2022
The back of beyond
This is quite possible although when the Chiltern 168s were introduced they were fitted with yaw dampers and tripcocks so that issue has been overcome.
RPM
24 Sep 2009
Buckinghamshire
The Chiltern 165s have the requisite brackets on both the bogies and the bodies for yaw damper fitment. However, as I understand it, they would need to have their final drives changed if they were to be modified to run at 90. I don't think the tripcocks played any part in the original 75mph specification. There just wasn't any requirement at the time for faster units on the newly modernised Chiltern Lines.
hexagon789
2 Sep 2016
Wasn't the Chiltern Line 75 max south of Banbury when the 165s were introduced anyway?
RPM
24 Sep 2009
Buckinghamshire
Yes. The NSE Total Route Modernisation was based on a 75mph railway. It wasn't until the Shooter era that linespeeds started to increase.
