Chiltern disruption, 11 October
ctyerkes
27 Nov 2009
Can anyone shed light on the disruption caused (I think) by a signal failure at Princes Risborough today? Pretty severe, including:
2A25 1159 Marylebone-Aylesbury arrived 272 late
1Y32 1111 Oxford-Marylebone 279 late at the time of writing
1R26 1142 Marylebone-Birmingham Moor St terminated at Princes Risborough at 1500
and dozens of cancellations.
_toommm_
8 Jul 2017
Station codes can be used, but you need to write the station out in full first before using the acronym. I’ve no idea where PRR is.
py_megapixel
5 Nov 2018
Northern England
Can you please replace the three-letter codes with full station names (at least the first time you use them)? I know where Oxford and Marylebone are, but not sure about the others.
CyrusWuff
20 May 2013
Looks to have been a complete loss of signalling affecting the entire Marylebone ASC (Area Signalling Centre) area, which is essentially Marylebone to Aylesbury Vale Parkway/Oxford Parkway/Aynho Junction.
This should be virtually impossible, given I'd hope there's at least a backup generator, if not a full secondary power supply, so I suspect someone may be in for a meeting with no tea and no biscuits.
cm39275
22 Dec 2011
bicester
I can confirm after reading internal rail systems that Marylebone signalling centre lost both its north and south panels at the same to which caused all signals south of Aynho junction and Wolvecote tunnel (Oxford) to revert and be held at red until network rail engineers managedto rectify the fault which lasted from about 1140ish this morning until roughly 1630 this evening. The fault also caused London Road level crossing at Bicester to fail with lights flashing but the barriers to stay in the up position leading to disruption to one of the major roads into and out of Bicester.
sammyg901
24 Mar 2009
They did a good job of being ready to go once the problem was resolved, the evening peak ran pretty well
ctyerkes
27 Nov 2009
Thanks for the information.
alexx
17 Sep 2015
The London Road Bicester crossing was up with no flashing lights but closed to traffic last night, photo attached. Not quite sure the state of the crossing last night but trains were still running and pedestrians were still able to cross. Seemed in the same state about 7.30am this morning.
