Cl158 AWS Sounds
Bizarre
21 Feb 2006
Grimsby, North East Lincolnshire
Can anybody help in diagnosing a problem I have with the 158? I have no AWS sounds when using the train, although the files are there in the train folder and are working (via WMP). Been stopped by the TPWS no end of times on NWM!
TIA :help:
Guinness
13 Jun 2005
Couple of questions:
1) Are you sure you have the BVE4 Class 158?
2) Which route are you using on NWM?
Guinness
13 Jun 2005
I've had a quick go on Network West Midlands (Not Maybank) and the AWS on the 158 works on both Rain and non-rain routes.
The only reasons I can think of for it not to be working are;
- Your not using the latest version of BVE4 (v4.2)
- You have pressed the Isolate Safety Systems Switch on the 158 during the simulation (Page Up/down)
- The Class 158 AWS Files have been altered
Try the 158 on another route and see if the AWS works then. :)
66526
9 Nov 2005
TIA :help:
To stop getting stopped by the TPWS it might help if you stick to speed limits and went over the AWS magnet at red signals at at least 15mph.
Guinness
13 Jun 2005
Could it be a problem with the uk_sprinter.DLL? I think it's linked into the TPWS and AWS some way.
Bizarre
21 Feb 2006
That's not really the issue: it's when the AWS warns of a signal at danger and I don't hear it so I don't cancel the warning. This then triggers the TPWS.
[EDIT]
Simming said:
Do You have your speakers turned on? :P
Helpful suggestion but as I indicated above, I can hear all the other sounds fine!
[EDIT]
EmergencyBrake said:
Nah, as he said "Been stopped by the TPWS no end of times on NWM!"
Correct, TPWS is not turned off, otherwise I couldn't be stopped by it!
:tongue3:
[EDIT]
Is that part of the Cl158 train file or elsewhere. I did try a fresh download and reinstalling but with no success.
Just off to try the 158 using Route Randomizer.
I'll be back...
:coffee2:
Guinness
13 Jun 2005
Try Pressing Up (To put the train into Forward) then press back (To put the train back into Neutral). The AWS should sound after a couple of seconds. Cancel it by pressing "Insert".
It's a standard proceedure in all UK trains so you might be starting the train straight away by pressing the "2 Key" without doing the AWS test. :)
Bizarre
21 Feb 2006
Sorry to be boring, and thanks for the suggestion, but I always start the train in the way you describe (Pressing Up (To put the train into Forward) then press back (To put the train back into Neutral)). I get the sunflower working but, again, no AWS sounds with the 158. Every other train is fine...
angry9:
Guinness
13 Jun 2005
Does the 158 AWS work on any other route.
(Can't check back in the thread as internet has gone dodgy!!)
Bizarre
21 Feb 2006
No it doesn't - tried it on Birmingham X City earlier and got every sound EXCEPT AWS!
And I also mentioned that I've tried a fresh download & install with no success...
:shaking2:
Guinness
13 Jun 2005
:shaking2:
Don't know what else it could be.
All I can suggest now is a re-install of BVE4. Worked for me when I couldn't get Door Interlock lights working.
9 Apr 2006
London, UK
Does the AWS sound work for other trains such as the class 323, class 66 etc...
If it does, try and copy the sound files over to the class 158 folder. Dunno if this will help at all, but its worth a try.
Muppet
7 Aug 2005
In a Box
Try downloading the train agian and then reinstalling it. make sure you remove the old copy before you re install
Simon_G
19 Mar 2006
I think you might be correct ;)
Just to check, the sound files you need for AWS are:
Code:
158_aws_bingling.wav    119K     11/12/2005
AWS.wav                  21K     21/02/2005
aws_bing.wav            119K     11/12/2005
(Guess which ones are John's rerecorded super-duper sounds eh :D)
The sound.cfg file should contain the section:
Code:
[Ats]
0 = Aws_bing.wav
1 = 158_aws_bingling.wav
2 = Aws.wav
Bizarre
21 Feb 2006
Code:
Yes, all present and correct.
Code:
[Ats]
0 = Aws_bing.wav
2 = Aws.wav
Again, that appears to be present. Here's the full file:
Code:
Version 1.0
[Run]
0 = Run0.wav
1 = Run1.wav
2 = Run2.wav
3 = Run3.wav
4 = Run4.wav
5 = Run5.wav
6 = Run6.wav
7 = Run7.wav
[Flange]
0 = Flange0.wav
[Motor]
0 = Motor0.wav
2 = Motor2.wav
5 = Motor5.wav
6 = Motor6.wav
[Switch]
0 = Point.wav
[Ats]
0 = Aws_bing.wav
2 = Aws.wav
3 = Eb.wav
4 = Buzzer.wav
5 = DrawFwd.wav
6 = SetBack.wav
7 = starterOn_lf.wav
8 = starterLoop.wav
9 = starterFade.wav
10 = engineFire.wav
11 = engineStall.wav
12 = loop.wav
13 = revvingup.wav
14 = revvingdown.wav
15 = engineStop.wav
16 = switchwiper.wav
17 = wetwipe.wav
18 = dryWipe.WAV
19 = raindrop.wav
20 = raindrop2.wav
21 = raindrop3.wav
22 = raindrop4.wav
22 = raindrop2.wav
24 = switch.wav
[Brake]
BC Release Full = AirZero.wav
Emergency = b_p.wav
[Brake Handle]
Min = b_m.wav
apply = b_p.wav
Release = b_m.wav
Max = b_p.wav
[Master Controller]
Max = p_m.wav
Min = p_e.wav
Up =  p_e.wav
Down = p_m.wav
[Reverser]
On = RevFwd.wav
Off = RevN.wav
[Compressor]
Release = CpEnd.wav
[Door]
Open Left = DoorOpn.wav
Open Right = DoorOpn.wav
Close Left = DoorCls.wav
Close Right = DoorCls.wav
[Horn]
Primary = Klaxon0.wav
Secondary = Klaxon1.wav
music = Klaxon2.wav
[Suspension]
left = springl.wav
right = springr.wav
[Pilot Lamp]
On = leave.wav
It's a mystery...
:pale:
[EDIT]
Well, there's a thing. I've copied over the 323 AWS files to the 158 train folder and now have working AWS sounds! Thanks EmergencyBrake - although not authentic sounds, I'm now managing to avoid TPWS delays! :toothy7:
Thanks for all your help folks.
:wav:
