Clarendon Update on TSC
Jim
11 Jun 2005
Wick
There has been 1 new scnerio added to Clarendon, along with all the night stuff added on TSC (previousally available on Dennis' site)
The new run, was made by James (66526) with the appropriate loco (526) on the front. James created this run.
Enjoy playing
jim
Edited (by doublepost prevention system):
http://www.trainsimcentral.co.uk/clarendon.htm
9 Apr 2006
London, UK
Just downloaded it and gave it a run. I found it quite enjoyable. However the night light level is very poor, I can hardly see anything until I adjusted the .ambientlighting command.
Dennis
8 Aug 2005
Trowbridge
The night lighting levels are very much a matter of personal taste and will also depend on monitor settings and how light the room is. I'm therefore not at all surprised that you felt the need to adjust the .ambientlight settings. I find that somewhere in the region of 25,25,25 is great when driving in a dark room (at night, lights out) but on a bright day, something much higher is needed (eg 200,200,200). It must however be rememebered that at night, not much will actually be visible outside the range of the train lights.
One drawback with changing the ambient light settings is that it will affect the glow of some of the illuminated objects. This is a particular problem with some of the lighter coloured platform walls which have been coded to glow to simulate reflected light.
It is also worth noting that development of the night route was performed using a flat panel display - I have yet to see it on a CRT but can imagine it looks a lot better as it will be less sensitive to viewing angle.
A final issue regarding the night routes is dial illumination in the cab - not sure how to change this so that the dials shine brightly.
Personally, I am looking forward to more night routes - if properly done (which does take a lot of effort) they will add a whole new dimension to BVE.
9 Apr 2006
London, UK
One thing I noticed-
I was driving the cl170 route and upon arriving at Birkley Point, I got tripped by the TPWS for no apparant reason. My speed was around 20mph when approaching the station so I wasnt overspeeding as the speed limit was 25mph.
Any ideas or have I discovered a bug ???
ikar
20 Oct 2005
Europe (Rijeka, Croatia)
20mph is a little fast when aproaching a bay, isn't it.
Dennis
8 Aug 2005
Trowbridge
10MPH is indeed the limit when at a terminal platform. It was 5MPH for a short while a few years back but this speed was found to be unrealistically low (with a couple of minutes being needed to traverse the platform length). The actual limit is have set is a little bit higher than 10MPH (knowing how BVE trains tend to be driven :mad: ).
ChrisCooper
7 Sep 2005
Loughborough
The 5mph limit was actually only brought in since when TPWS was fitted on the approach to terminal platforms, trains were often being tripped at less than 10mph, so it was decided to lower the speed to 5mph until the problem could be sorted. It was due to the grids being so close together that the signals from them were interfearing to give the effect of another grid inbetween, and since the space between the grids effects the tripping speed, trains were being tripped at half the speed the grids were set at. The solution was to fit a different style of TPWS grid which are about 1/3 of the size of normal ones, and this allowed the appoach speed to be raised to 10mph again. I have heard that they can still be a bit hit and miss though, and some will still trip out below 10mph, although at least drivers are aware so usually slow down enough.
Dennis
8 Aug 2005
Trowbridge
Thanks for clearing that up I couldn't recall if 5MPH was introduced in response to a specific incident.
I remember travelling to places like Waterloo soon after TPWS fitment and the 5MPH restriction was is place - took absolutely ages to pull into the platforms, on slam door stock it was quicker to jump out at the first opportunity and walk!!
