Trainbike46
175 then definitely shouldn't be coming to East Anglia, as they are unsuitable for the routes thereNo. Can use MU and HST, which is all they needed at TfW, but not SP.
It maybe me, but I cannot see Chiltern taking the class 175 units due to the noise that they would be making in London Marylebone. Admittedly though, they would be quieter than class 68 hauled coaches.So we're speculating that Chiltern is their new home?
Are they any noisier than a 168? Its the 68s that are the issue.It maybe me, but I cannot see Chiltern taking the class 175 units due to the noise that they would be making in London Marylebone. Admittedly though, they would be quieter than class 68 hauled coaches.
I'd say they're second only to 185s in terms of DMU noise level, and the idle noise when stationary also carries a long way.Are they any noisier than a 168? Its the 68s that are the issue.
If this has any strength in it then Chiltern should either get mk5 sets or 170s from Crosscountry. But whatever happens it seems to be early stages at the moment"While it is thought a move to Chiltern Railways is currently the favoured option, replacing the Mk 3 loco-hauled coaches there, it is understood CrossCountry is considering taking on the fleet, which could be deployed on Nottingham to Cardiff services to provide an enhanced intercity-style offering on this important route"
(Photo of extract attached)
No. Irish Rail are in the process of extending some of their Rotem units, so don't need 175s.Assuming a successful adaptation to fit the different gauge, could they be a good fit for Irish Rail to replace the 2900s/any remaining diesel loco operations and run the long distance services alongside the similar Rotem 2200s?
From other threads, I believe that the Scotrail HST units are using the 125mph capability of the power car units, so if that is the case then the 175 units which only have 100mph max speed would not be able to keep to the times of the HST sets. There is also not enough class 175 units to replace the 25 HST sets with Scotrail.Alternatively, how about ScotRail to replace some of the HSTs?
I don't recall them being any noisier other than maybe the brakes which do squeal a bit.
Informed sources have confirmed that they aren't using the 125mph capability in this thread - https://www.railforums.co.uk/threads/class-175-future-speculation.218095/page-45#post-6408626From other threads, I believe that the Scotrail HST units are using the 125mph capability of the power car units
There is literally nowhere on the ScotRail network where HSTs run in service that has a linespeed higher than 100mph.From other threads, I believe that the Scotrail HST units are using the 125mph capability of the power car units, so if that is the case then the 175 units which only have 100mph max speed would not be able to keep to the times of the HST sets. There is also not enough class 175 units to replace the 25 HST sets with Scotrail.
That however does not make 175s suitable for Scotrail.
This thread does seem rather repetitive at times. No one is going to be able to come up with a credible possible use that hasn't already been speculated on, been discussed, and in most cases dismissed, in this thread.
Thanks Guys, I thought that it might be the case that the 125mph but was not sure. But even so, despite there not being enough class 175 units to replace the 25 HST sets, each of which is 4 to 5 coaches, I don't believe that the class 175 units could keep to the Scotrail HST times. To replace the Scotrail HST's you really need Hitachi AT300/AT200 Bi-mode or something similar. The only other option as has been discussed before, is the class 222 fleet with East Midlands after they are replaced by class 810 units.There is literally nowhere on the ScotRail network where HSTs run in service that has a linespeed higher than 100mph.
I believe that the HST do have better acceleration.Do the HST's have better acceleration maybe?
I think it would be better idea that they replace the 150's, 153's, 158's with TFW. However, there would only be enough class 175 units to replace the TFW class 158 units. I thought the idea of having 51 2-car and 26 3-car is that they would replace class 150, 153, 170 & 175 units? If that is the case, then surely the class 175 units would replace the class 158 units?I can't help but think that the best solution is that they stay with TFW for increased capacity and withdraw all the 150's, 153's, 158's and 170's leaving TFW with a fleet of 175's, 197's, 231's, 230's, 398's and 756's. Who knows maybe that is even the plan? Hand them all back to Angel trains then negotiate a better leasing deal on them? I can certainly believe that if Angel trains are given the choice between accepting less money or no money then they'd be more inclined to do a better value deal - they certainly by this point will have made there initial investment back several times over i'm sure!
Don’t forget that TFW are keeping some 153’s for HOW and they have 230’s for the Bidston line. Further to that the tram trains and FLIRTS will also be coming in which will take over some of the 150’s 170’s and 153’s work in the south.I think it would be better idea that they replace the 150's, 153's, 158's with TFW. However, there would only be enough class 175 units to replace the TFW class 158 units. I thought the idea of having 51 2-car and 26 3-car is that they would replace class 150, 153, 170 & 175 units? If that is the case, then surely the class 175 units would replace the class 158 units?
Can 170s keep to those times when they (frequently) deputise for HSTs? If so, 175s would do as well. They have better acceleration than 170s, I don't believe that the class 175 units could keep to the Scotrail HST times. To
There's already going to be a massive increase of capacity at TfW even without the expense and hassle of keeping the 175s.I think it would be better idea that they replace the 150's, 153's, 158's with TFW. However, there would only be enough class 175 units to replace the TFW class 158 units. I thought the idea of having 51 2-car and 26 3-car is that they would replace class 150, 153, 170 & 175 units? If that is the case, then surely the class 175 units would replace the class 158 units?
What station is that?Don’t forget that TFW are keeping some 153’s for HOW and they have 230’s for the Bidston line. Further to that the tram trains and FLIRTS will also be coming in which will take over some of the 150’s 170’s and 153’s work in the south.
158’s have always planned to be replaced by 197’s.
Even if not, to keep the 175’s in place of 158’s would mean (a very costly) retro-fitting of ETCS equipment as 158’s are the only units that can work the Cambrian.
Which is just almost certainly not going to happen.
I keep hearing about TFW keeping 158’s for just the Cambrian instead of 197’s but millions and millions of pounds have been and continue to be spent in preparation for their arrival.
I just don’t see TFW or NR being willing to ‘throw’ that money away.
Some examples are:
1) extension of the maintenance shed at Mach to fit 197’s
2) upgrade ETCS system for comparability with 197’s
3) alterations of platforms to accommodate 197’s. (They’re even thinking about closing 1 station all together because of them).
Tygwyn.What station is that?
If that's true it seems rather an indictment against the 197s. Trains should be built to suit the routes they're used on, not the other way around!
I'm not against closure of stations which really should be (not 'rail for rail's sake'), but the type of unit used should not factor.Though the station is beyond useless, it basically serves nothing. BR proposed to close it and probably should have gone through with it.
The type of train selected to operate throughout much of Wales should be dictated by the needs of the couple of hundred passengers a year who used a station which should probably have been closed years ago?I'm not against closure of stations which really should be (not 'rail for rail's sake'), but the type of unit used should not factor.
I can tell you don’t know the station, and that’s ok as it’s quite unique. But any new rolling stock with and end gangway would be an issue as it’s due to sighting.I'm not against closure of stations which really should be (not 'rail for rail's sake'), but the type of unit used should not factor.
Ultimately, yes.Because of the level crossing ?
Tygwyn or no Tygwyn, both 197s and 175s are less-suited to the Camrbian than the 158s currently used, for different reasons. The ideal units would probably be a lighter-weight bi-mode version of the 175s with end-gangways.If that's true it seems rather an indictment against the 197s. Trains should be built to suit the routes they're used on, not the other way around!
I completely disagree - 170s would be far from perfect. The lack of end gangways for starters - the working of through services between Pwllheli/Aberystwyth and Birmingham as portions of the same train is a major plus point of the current timetable and would be rather less seamless if guards didn't have the ability to simply tell passengers who happen to be in the wrong portion to walk through to the correct part of the train.For the Cambrian, and indeed almost everything else operated by TfW, doors at quarters/thirds are more suitable. 170s would be perfect
Fast regional stuff it may be, but it still shouldn't be seen as a suburban metro style service with passengers being expected to stand. The doors on a class 170 are not just at thirds/quarters - they are significantly wider than those on 158s/175s. That means more standing room at the expense of space for anything else. If you ask me, it is the narrower doors found on the likes of 175s and 397s that should be standard for ALL UK stock outside suburban/metro type services where passengers standing for up to 5 minutes at peak-times is pretty much unavoidable.To be honest, having just fought my way off a crowded Pendolino, I'm starting to think doors at quarters/thirds would be better for ALL UK stock. The majority of what we call InterCity is just fast regional stuff with significant short distance traffic and passenger turnover.
Central Trains tried the 170s on the Cambrian and swiftly got rid of them again. They've always been somewhat prone to overheating in the summer in general and the long climbs on the mainline part between Shrewsbury and Mach coupled with all the rural detritus getting into the radiators killed them off far too regularly. The 158s are a bit more robust in that regard.For the Cambrian, and indeed almost everything else operated by TfW, doors at quarters/thirds are more suitable. 170s would be perfect, and had the route stayed with Central Trains I suspect we would have seen them there in time.
