James Kevill
- Joined
- 27 May 2019
- Messages
- 179
I think it's after when they are replaced by Class 802/3s from Hull Trains then yes.Did the corrosion of the unit with 4 coaches happen before or after the transfer to EMR?
Not confirmed yet realistically you only need to shorten two services in the morning and two in the evening. During the day the loss of the 09:45 STP-MMO and the 14:35 MMO-STP will certainly help, plus the 10:02 STP-SHF and 12:37 SHF-STP is a lightly loaded 10 car so I wouldn’t be surprised to see that shortened. I also reckon the 222s will see Cricklewood a bit less during the dayAre there any timetable reductions as a result of this, or will the difference be made up simply by running fewer double sets?
I was told that it should be back as a 5 car “very soon”, and that it’s either in Doncaster now or will go imminently, but don’t quote me on that!!Did the corrosion of the unit with 4 coaches happen before or after the transfer to EMR?
Wilkinson Sword. They've always been junk, now they are heavily corroded junk.Or indeed the plan for the Adelantes themselves?
I agree, however weekdays can be less busy so maybe diagram more then? For example the 17.35 St Pancras to Nott on weekdays is a double 222 (I'm on it now) and it's never too busy as I get it every Friday Kett to Leicester, easily can go 5 cars). 16.35 from St Pancras to Nott is the same. Sundays might be fun as 3 180s are usually diagrammed (2 been a double set). Cutting the Melton service makes sense as few passengers travel north of Corby and its not much slower for Melton or Oakham passengers to travel via Leicester and change there.Overcrowding is going to be horrendous on the MML at weekends.
It’s already bad as it is now…
As per message #57 in this thread, the Melton service is needed for diversionary route knowledge.Cutting the Melton service makes sense as few passengers travel north of Corby and its not much slower for Melton or Oakham passengers to travel via Leicester and change there.
I am led to believe that EMR are considering running a unit round ECS for route retention. Not sure of the details though.
Yes of course we need a few to go this way but main point was weekdays many 10 car 222 can be 5 so eliminate 180s. Let's see what happens in the coming weeks and months...As per message #57 in this thread, the Melton service is needed for diversionary route knowledge.
Well this is it, there is so much uncertainty that the lesson is not to believe something until we actually see it!Let's see what happens in the coming weeks and months...
I'm puzzled, because most days there's a 5M17 08.39 (ish) St Pancras to Cricklewood A to F which spends the day shuttling via Melton to Leicester and back, and on slow lines on all the 4 track sections twice and I thought this was for route retention.As per message #57 in this thread, the Melton service is needed for diversionary route knowledge.
This is because the metallic film in the windows block all sorts of RF out - from 87.5MHz (FM) all the way up to 3500MHz (5G) and beyond.Whilst more crowded trains isn’t ideal, one good thing about EMR is that they do seem willing to declassify the first class section in coach D which does help things somewhat.
The worst thing about the 180s going is that you can’t get a decent phone signal on the 222s and the wifi is awful
Even without the impending 180 withdrawal, the 222 fleet is far larger. Note how LNER got rid of the 90s as soon as the 800s came in.IMO the 222s should go before the 180s. But that's just my opinion.
The 222s are not, and never have been, unreliable old junk likely to catch fire at any moment, from the day that they entered service.This is because the metallic film in the windows block all sorts of RF out - from 87.5MHz (FM) all the way up to 3500MHz (5G) and beyond.
As such, the Wi-Fi gets very overloaded very quickly because everyone has to use the Wi-Fi, due to not being able to get a decent phone signal.
The HSTs used to be fine, before they were scrapped. The 360s are also fine. The 222s are not.
IMO the 222s should go before the 180s. But that's just my opinion. Hopefully the 810s won't have this sort of issue.
Because older corroding units should take prevalence over newer not corroding units? Without wanting to sound demanding, why do you think this?IMO the 222s should go before the 180s. But that's just my opinion.
Edited to add: I forgot the junkheaps severe corrosion issues. The scrapman is calling....
The 222s have, however, needed their panes of glass smashing out and replacing with standard, non metallic glass. The same can be said for CrossCountry's 220/221 and Avanti's 221.The 222s are not, and never have been, unreliable old junk likely to catch fire at any moment, from the day that they entered service.
Acceleration and phone signal quality are unfortunately not worthy reasons to keep them in serviceI once managed to get a 180 and the acceleration actually felt better than a 222, it also didn't have the design flaw with the windows that the 222s have. I don't like their squeaky brakes though, why the brakes make so much noise when entering a station (not noticeable with any other type of train) I do not know!
The HSTs were also way past it. The ex LNER ones had to be shortened to 6 coaches when they moved to EMR as too many coaches were in such bad condition that they couldn’t be fully formed, and that’s without addressing the elephant in the room, the disability discrimination laws. Slam door stock couldn’t stay beyond May 2021. However I’ll admit that those particular HSTs were so much nicer as a passenger (even compared to 222s)And if the 180s really are as bad as you say they are, then why did we get those added to the fleet and the HSTs removed? Surely someone thought they were fit for purpose?
Sintered brake pads.I don't like their squeaky brakes though, why the brakes make so much noise when entering a station (not noticeable with any other type of train) I do not know!
Brake pads of which the biting surface is comprised of 18 large copper "nuts", that give you a phenominally good braking performance at all speeds, even if they are a tad squealy.Sintered brake pads.
Same, I'd love to see real photos/examples showing just how unserviceable these 180s are (except for one of the coaches of 110, I know that's been out of service for ages).I would love to see a photo of the corrosion.
I don't think you're the first on here to say this, although in practical terms there difference is pretty small. I don't think the timetable performance would change noticeably if somebody was able to conjure 27 or more additional Class 180s from somewhere and bin the 222s.I once managed to get a 180 and the acceleration actually felt better than a 222
LNER only finished with them in December 2019 and they were all gone from EMR by the end of 2021. Not disagreeing about the condition - I've no knowledge. However, the pandemic must have influenced decisions about if, and how quickly, to bring them up to standard, and whether to keep them serviceable.The ex LNER ones had to be shortened to 6 coaches when they moved to EMR as too many coaches were in such bad condition that they couldn’t be fully formed
Were these always a feature of Cl180s? My recollection from other threads is that the 180s had hydrodynamic brakes in the transmission, which weren't up to the job, so were locked out or removed. If so, then were these installed to give the disc brakes a bit more stopability?Brake pads of which the biting surface is comprised of 18 large copper "nuts", that give you a phenominally good braking performance at all speeds
What’s the design flaw with the windows you go on about? I understand these windows are designed to ensure passengers are not ejected from a train in the unlikely event of a collision.
Surely a far bigger design flaw is the horrendous corrosion the 180s are suffering, so much so one of the vehicles in a set has had to be taken out of traffic. That sounds like a big flaw.
I think you'd be better off asking "Does anyone know if we expect to see the missing carriage out of 180 110 put back into service?". If they're being withdrawn soon with no future home, you can see why the owner wouldn't be overly keen on putting a vehicle through expensive works...Does anyone know when we expect to see the missing carriage out of 180 110 put back into service?
It shouldn’t be too long. It’s back at Etches Park now fully formedDoes anyone know when we expect to see the missing carriage out of 180 110 put back into service?
I'm pretty sure they would have to be returned to the rosco the same as they were received.I think you'd be better off asking "Does anyone know if we expect to see the missing carriage out of 180 110 put back into service?". If they're being withdrawn soon with no future home, you can see why the owner wouldn't be overly keen on putting a vehicle through expensive works...
