Class 360/2s as 350s
Doomotron
25 Jun 2018
Kent
Technically they were built as class 350s.
There were a number of pictures of at least one of them at Northam Depot. From memory the pictured example was all white with the only yellow being cab front connecting door/s
In the ROG Class 360 thread, it was mentioned that most of the 360/2s were rebuilt from 350s into 360s, and that there were photographs of them. Does anybody have more information on them, like what their use was? Or crucially, some photos?
The rebuilding was during their manufacturer, they had their gangways removed during fabrication, so were never actually in use as 350s . I’m pretty sure there‘s either photos or a link to photos in one of the earlier threads about 360s. Will try and find them...
here you go, the weld lines are the give away: https://www.railforums.co.uk/thread...r-heathrow-connect.122798/page-2#post-2353626
greatvoyager
15 Aug 2019
Exeter
37057
3 Jul 2009
The front end of the bodyshell is constructed using the two cornered panels that meet a centre section, so those weld lines are there regardless (even on units that were never destined to have gangways). I don't know the history of these units so can't confirm or deny - but that photo doesn't tell the story.
greatvoyager
15 Aug 2019
Exeter
Never knew that.
Interesting point about two panels, so that photo‘s been wrongly explained many times?
37057
3 Jul 2009
Quite possibly.
I've seen a few of these corner sections arrive on pallets when front end repairs are carried out (one as recent as a few weeks ago for a 185!) and they're consistent with the drawings that I've studied.
I could even debunk it a little further and say that the windscreen portal on a non-gangway unit forms one open portal between all three sections (two corners & one centre as can be traced in the photo), whereas (IIRC from the 350403 v horses incident), a gangway unit has individual 'closed' windscreen portals in each corner section. So I doubt it would even be possible to simply 'chop' the gangway out without changing the entire front end.
greatvoyager
15 Aug 2019
Exeter
Quite possibly.
This is fascinating, thanks for the explanation.
