Class 377 Reformation - 377 442 becomes 377 342
4-COR 3142
27 Nov 2013
Following the damage sustained in a fire in Eastbourne last November Class 377, 377 442 has been reduced to a 3 coach unit and returned to traffic numbered 377 342.
Having tried the search function on this forum to find out more - but to no avail - I am interested to know a few things?
Is this a temporary measure? or will the damaged coach be repaired?
Also is it being used on specific (3-car) diagrams only?
Is there any easy way to try and find where it is on a specific day or not if I was trying to see it?
The only photo I've seen so far is inside Selhurst depot on the excellent 'Rail Thing - Electrics and Diesels on Southern Metals' Facebook page.
Fincra5
6 Jun 2009
I believe it is being used on 3 car diagrams in the "common pool" out of Selhurst. Unit 377211 back from TLK is being used on rotation instead of 7442.
No idea what the cost would be or if it can be repaired. I think they're still trying to finalise what caused the fire.
4-COR 3142
27 Nov 2013
Did you search for 377 442 or 377442? Problem is that unnecessary space throws the search, because no-one usually posts like that.
The earlier thread is here:
http://www.railforums.co.uk/showthread.php?t=138517&highlight=377442
(Apologies I got the 'cut and paste' wrong with the first attempt.)
Thanks to you both most helpfull.........but lets see if we can keep my Luddite tendancies with search engines quiet!:lol:
Class455
19 May 2016
Has the unit re-entered traffic yet? Havent seen any pictures apart from one of the unit in Selhurst when it was first reformed.
jopsuk
13 May 2008
presumably it was the MOSL that was damaged? Even for a DC unit I'd guess there's too much power control equipment in the PTOSL for the unit to be viable without it.
Roast Veg
28 Oct 2016
Also that would technically make it a class 4xx unit.
aleggatta
28 Sep 2015
The main ball ache would be temporarily relocating the compressor and associated control equipment to the MOSL in that situation, or having a permanently coupled unit which would be slightly unfavourable.
physics34
1 Dec 2013
Drove 377211 earlier today.
Had the southern.paint patch up job.
Kite159
27 Jan 2014
West of Andover
One of the first class areas appears to have been declassified from the outside (the yellow has been removed), probably to bring it in line with the other 377/3s with FC at one end.
(A little bonus if anybody happens to have a long trip, as it has plug sockets ;))
Starmill
18 May 2012
Bolton
Is 377 442 still running around as a 3 car? Is there any progress on returning it to 4 car or is it going to remain like that?
Class455
19 May 2016
Yes, have seen it today. I hope it should not be too long now until it’s a 4 car again, but was 78842 written off?
aleggatta
28 Sep 2015
The last I heard from a Bombardier engineer was that it was in the process of being repaired (at Wolverton I believe) but that the damaged coach might have come back with a 387 style interior as the drawings for the damaged components had been lost (server farm fire from what some of the other guys on depot were telling me). That was a little while ago, so the position may well have changed.
Edit: Just to add, that the coach specifically was not considered a write off and quite salvageable
