D365
- Joined
- 29 Jun 2012
- Messages
- 11,461
Ah yes, those horrid diesel loco hauled 365s with compartments and slam doors...
Now that would be something I’d pay to see!
gn 387 driver forgot to open walkthrough?on train from cambs to kingsx. Can only get off the train if you are on the first 3 carriages for 2 stations but there is a 'no public access' door at carriage 5. Only announced on pulling away.
No the driver/platform staff didn't forget, since the timetable change they are kept shut. As expected this hasn't gone down well with passengers but it's the current situation - not sure how long this will last or if it will be permanent though.
I'd heard that it was semi-permanent, which if true is bizarre?How long will this be for? Presumably there's an aspiration to check over the coupling and be assured they can open the gangway doors again.
I know safety is key, but if 387s are considered unsafe for allowing passengers to walk through, who gets the blame? Bombardier? The ROSCO?
They might as well get
What a farce. They might as well use 365s for the additional comfort and use unit deselect the rear unit at the stations requiring SDO. Seems as though unit deselect is effectively what’s in place.
That'll be an issue when the peak King's Lynn call at Ashwell & Morden from May 2018. Unit deselect won't work at all for this first/last station before London, with passengers 'trapped' on the wrong unit.
I'm still at a loss with this thread as to why bringing back 365s in place of 387s/700s is percieved as some sort of silver bullet...
But haven’t we effectively got unit deselect with the 387s given that you can’t walk through from one unit to another.
Unit deselect involves an entire unit's doors not opening at a station. So long as even a singular carriage's doors in the rear unit can open at a station, then they are providing a considerable capacity uplift. As far as I'm aware, 365s don't have unit deselect - they can be locked out by use of a driver's key but they can't then carry passengers, unless I've incorrectly remembered the facts.
The twitter post linked to above says you had to be in the front 3 coaches to alight at certain stations. If this is correct then if you’re in coach 4 then you can walk through but if you’re in coaches 5-8 then you can’t get off as you can’t walk through from the rear unit to the front.
Fair enough, hadn't seen that. That's pretty shameful then, although I would hope that even so there would still be announcements on the platform to the effect of "Passengers for x must travel in the front 3 coaches of the train" - perhaps there needs to be some modifications to the TMS software to announce short platforms at the last place where people can change units then, or GN drop their aversion to having the interconnecting doors closed - after all, the Southern and GatEx divisions of the company seem to be fine with near identical units.
If theirs is consistent with the SE Networkers, then it is possible to open all doors except the frontmost/rearmost only.It was the 317s which had until unit deselect. To my knowledge 365s have never used any form of SDO whilst on GN.
I agree with this, the walkthrough is there for a reason,to allow flexiblity @ short stations &sdo.Fair enough, hadn't seen that. That's pretty shameful then, although I would hope that even so there would still be announcements on the platform to the effect of "Passengers for x must travel in the front 3 coaches of the train" - perhaps there needs to be some modifications to the TMS software to announce short platforms at the last place where people can change units then, or GN drop their aversion to having the interconnecting doors closed - after all, the Southern and GatEx divisions of the company seem to be fine with near identical units.
Do any 379s divide en-route? If yes, is it frequent?They were blocking walkthrough on the 379s by means of locking the gangways between units at least two years ago, so it's not something they have just suddenly started doing.
This wouldn't ordinarily happen, so possibly the doors were locked out due to a fault, or the units were connected in haste. Aside from the aforementioned Cambridge splitters, multiple 379s operate with the connecting doors correctly in use.It was Stansted Express services on which I found the walk through locked... Those don't divide.
Ummm... it was multiple trips where I found I couldn't walk though. Haven't been for a while though as I got all the haulages back then...
The real silver bullet is that the handful of platforms involved should simply be extended.
Absolutely. Peak time trains from Cambridge to Kings Lynn have been packed to the rafters for years and platform extensions should have been done by now. IMO this relatively simple job should have been prioritised over the Cambridge North station.
I believe now that platform extensions will go ahead at Waterbeach next year to allow eight-car trains. Can anyone confirm this?
I think there may be an option to use SDO at Littleport and Watlington?
SDO at Littleport on the Up involves sitting over the barrow crossing, which is the only access on/off the Up platform.
The "simple job" also requires power supply upgrade, which is less simple.
