GW43125
- Joined
- 8 Dec 2014
- Messages
- 2,194
I get the impression the 442s are turning into Trigger's Broom...
What are the chances that the 442s will be kept in pairs M-F, especially if they retain their bagpipes? It reduces the risks of a lone unit being stranded from a failure and also reduces the need for coupling/uncoupling.
If there is a need for a Thunderbird, well one of the Class 73s could be stabled at Woking again like SWT did in the latter years of pig operation. That, however, brings further need to train staff up to operate the 73. Hence why I think that unlikely.
So my gut feeling is refurbished units, with a new traction package and they run in pairs M-F and possibly weekends too.
It is inconceivable that they will run as single units. The line capacity problem doesn't really go away even running them in pairs. The existing services they will take over are already 10.444 or 12.450 after all.
Think the cab layout of a 73 very closely matches SR stock of its time apart from the obvious additional power handles and switches which makes traction training and therefore crewing much simpler. The cab of a 442 isnt much different from the REPs they replaced or the VEP/CIG/HAP/EPB etc they worked alongside. A CEP has been used to rescue a failed 442 before and all the former SR EMU and DEMU stock is theoretically fully compatible with each other and with 33/1 and 73. The only exception being 455/456 stock but again these were theoretically compatible with 210.
Plus the fact that single units struggle up the bank just after Haslemere. The general opinion seems to be that they're not heavy enough to deal with steep gradients or fine rain etc in 5 car configurations.
I'd assume there'd still only be 4/5 down trains an hour, and trains that are currently 12.450 will remain that way. After all, what's the point in having a 10 car train stopping at multiple 7 car platforms (therefore only opening 5) when you can have 8 cars released on 450 stock.
Their tractive effort per car will not change whether in five or ten car formations. There is only a tiny reduction in risk of a single unit's slipping being overcome with two units, as the railhead conditions are likely to be same over far longer stretches than a five or ten car train length. The way to overcome 'light-footedness' is to motor more axles per unit or increase the axle loading of the existing motored ones.
As we've not seen any confirmation about liveries for the new franchise, if they decided to stick with the existing liveries, would the 442s get painted back into their old SWTs livery?
There is also the question of where maintenance is done. Bournemouth has the historic knowledge but might Fratton actually be their new home?
Absolute nonsense. They run quite a few 5 car services on the Portsmouth Direct, our depot works several of them, so whether it be a 444 or 442, it won't make a jot of difference as they're both 5 cars.
Sorry, yes I should have been clearer.Ah, you didn't say peaks.
But we do run some 5 cars in the peaks 1715, 1719 ex PMH are booked 5 cars, although the latter regularly runs as 4v5 which is quite entertaining.
The Class 442s, like the 4REPs before them, use the sequential switching out of resistors to control the starting currents through the dc motors. The steps are quite coarse so control of wheel slip under marginal conditions is not very good. One assumes that the rebuild will see the replacement of the dc traction equipment with variable frequency 3-phase drives so motor control will be finer enabling much better performance on slippery rails with the same axle loading.
Power isn't everything, it's how you use it and how it's delivered is what counts.
You can have 10000 hp available, but that's no good if the wheels can't get any grip during leaf fall or in wet/drizzly conditions. I can remember doing a 100 mph wheelspin on quite a few occasions between Woking & Southampton in the past and none were deliberate either.
I'd have thought that, ... the ROSCO will be looking for 10 years of beneficial use to claw back the costs of the rebuild.
I guess this is the heart of the issue with the "retractioning" of the 442s - just how far are the driving carriages going to be rebuilt? I'd have thought that, in the same vein as the 319 Flex, the ROSCO will be looking for 10 years of beneficial use to claw back the costs of the rebuild.
The 442 is relatively unusual in having only the centre car of 5 powered. The 'driving carriages' are therefore both trailers, and in principle may have nothing to do with the retractioning, except for the cab equipment...
A good question to ask would be whether or not other more conventional traction layouts can be achieved by distributing traction packs and motored bogies under the whole of the unit.
My use of 'driving' is perhaps incorrect in this context, I was referring to the MLC carriage. I can't see how traction can be distributed across the unit - surely this isn't "retractioning"? You might as well buy new in this case!
Could the bogies adjacent to the MLC carriage accommodate a traction motor (size and weight)?
