Class 484 replacing class 483 on the island line: progress updates
61653 HTAFC
18 Dec 2012
Just posting this from Railwaygazzette.com for amusement
GERMANY: The first Class 483/484 EMUs for the Berlin S-Bahn network began running on route S47 in the early hours of January 1, as the route became the first in the city to be operated under a tendered contract.
Wow... Those units really do have a face only a mother could love!
spark001uk
20 Aug 2010
I actually came across these on YouTube a while back whilst looking for 484 vids.!
Peter Sarf
Croydon
Oh come on, surely these re-purposed Tyne and Wear units look better than a 484 <D.
Mikey C
11 Feb 2013
Weird that those Berlin trains are built by a consortium of Siemens and Stadler
ivzem
15 Aug 2019
Potsdam, Germany
Hey, at least those actually entered service on time, with the exact service that was agreed upon more than a year ago, and have apparently done pretty well since.
Peter Sarf
Croydon
It's true. Looks are not everything. Reliability, comfort and function should trump cosmetics. [/off-topic].
And we can be sure that the 484s are an improvement on the much older 483s whatever they look like.
Chris125
12 Nov 2009
Oh dear.
I'm sure it's marginal, perhaps the conversion from D78 to 484 had more impact on gauging than expected, but still rather embarrassing for Vivarail.
...there were no initial plans to do this but after further investigation there may be a necessity to lower the track to give enough room for the new units to get through the tunnel
spark001uk
20 Aug 2010
I can almost hear the hordes now, "see, I told you they wouldn't fit.!!"
ABB125
23 Jul 2016
University of Birmingham
Has one actually been through the tunnel yet? If not, surely the best way to see if it fits is to send it through slowly: if it fits it fits, if it doesn't... :D
Journeyman
16 Apr 2014
Well, the tunnel was deemed sufficiently big enough for the proposed use of class 503s in the 80s. According to Wikipedia, these were 3.48m high, and the D Stock is 3.62m. Maybe that extra 14cm is a problem.
spark001uk
20 Aug 2010
They should nip down the local pound shop for a handful of laser pointers, tape them to the roof, drive up to the entrance and see where the dots are (or aren't). :D
northernbelle
10 Oct 2018
The tunnel has had significant alterations since then. I remember reading that the bigger constraint was the curvature at the Shanklin end of the tunnel limiting the length of vehicles.
Sadly it's consistent with other comments in recent weeks, one by Mike Hart in particular, and a conspicuous lack of testing through the tunnel.
It's always the way. I remember being told absolutely categorically that IETs were too long for the curves on the Royal Albert Bridge. When I highlighted that several had already been to Cornwall on test, they still refused to acknowledge the duff gen.
Gloster
4 Sep 2020
Up the creek
I heard that the problem was a risk that the top corners of the vehicles would be foul. I can’t remember where I heard it or how reliable the source was.
py_megapixel
5 Nov 2018
Northern England
It's only the train roof, it's not like it's an important part of the train! All it does is stop the passengers getting wet; no need to repair it!
I mean, it does also keep water from getting into the electrics, but what does that matter? It's not like no lighting, heating, doors, or ability to safely control the train would affect the service at all! :D
But no, in all seriousness, it will be very embarrassing to both SWR and Vivarail if it does indeed turn out that they won't fit. Cries of "Told you so!" from lots of members of the public...
MotCO
25 Aug 2014
Are there other solutions if the tunnel is too small? E.g. can the suspension be lowered, fit smaller wheels etc? Is it the case that the trains will physically fit, but will not allow for any lateral movement, e.g. over track joints or going round corners?
D365
29 Jun 2012
I’d suggest you ask this under ”Speculative Ideas” as it’s not confirmed to be fact at this point.
Chris125
12 Nov 2009
The 503 proposal did involve single-tracking the tunnel and lowering through the single bores, at least in part to reduce maintenance costs and increase linespeed.
Height is just one factor - the tight reverse curves and arched roof make length and width just as important, especially at the cantrail where the middle and end of the carriages get closest to the arched roof.
I wouldn't say so - the covered way, re-roofed after privatisation, was not obviously more restrictive than the rest of the tunnel.
david1212
9 Apr 2020
Midlands
Over Christmas I read numerous website pages about the IOW railway. While a quick search now hasn't found it I saw a photo of a train with a gauging profile attached at a portal of one of the Ryde tunnels. This may have been for a previous idea. If so logic would say this should have been done again adjusted for planned track lowering and / or to determine the current limit and hence determine the adjustment required.
