Class 701 'Aventra' trains for South Western Railway
Nicholas Lewis
9 Aug 2019
They don’t sway as much as the BREL stuff but the ride isn’t bad.
Sway gives you a softer suspension but comes from an era where keeping absolutely within the kinematic envelope was less of a requirement. Now we want trains that maximises internal space but the penalty is stiff suspension so you don't infringe KE. Of course seats with a bit of give would help alleviate some of the harsh ride.
Goldfish62
14 Feb 2010
The FLEXX-Eco bogie, which all Aventras use (hence all have the same ride quality) is billed as being 30% lighter than previous designs and also reduces track wear and damage.
D365
29 Jun 2012
And we [the railway industry] also now have software that can model this.
444045
25 Apr 2020
Dorset
Anyone know what services will have 701s tomorrow on the Windsor/Reading/Woking branch?
Should be a Class 701 working :
2U91 1025 Wloo to Windsor
2U92 1130 Windsor to Wloo
2U93 1253 Wloo to Windsor
2U94 1400 Windsor to Wloo
Today its U.701043 doing the honours.
Hope this helps you.
2 Jun 2023
Richmond
Why was 100mph chosen on these units? As they're traveling and metro and commuter routes, surely it would have been better to stick with 75mph and dedicated more of that gearing towards acceleration. The 701s have the slowest acceleration in the Aventra family to my knowledge (0.7m/s^2 compared to 0.8m/s^2 on the 720s, 1m/s^2 on the 345s, and similar on the 710s), which doesn't make much sense considering a lot of the routes they travel on.
Energy
29 Dec 2018
720s and 345s are AC, 710s are AC and DC. DC units tend to perform worse. The 345s are still 90mph units so I'm not convinced the gearing would make them that much faster.
A decent comparison would be the 710s on DC as they are geared for 75mph.
25 Oct 2020
Epsom Downs
701s already accelerate very well for a DC unit. Comparing it to AC isn’t a level playing field. I’d say they are quicker off the blocks than a 707.
SWR have stated that they are deliberately "go-anywhere" units, have been cleared across the entire electrified network and could in future be used on services beyond the suburban network.
Although there is very little on SWR network above 90mph.
But it's valid question, why 100mph, and not say 85 or 90mph which would have kept time on about 99% of services across whole SWR network.
43096
23 Nov 2015
To give the trains' owner the maximum residual value - a 100mph unit is going to have potential for re-leasing than an 80mph units.
Residual value for the lease company. 100mph is very useful elsewhere, given their AC compatibility (with some parts added).
73128
8 Dec 2019
Reading
701037 looking very clean and tidy, and a sunny day. Our driver is the lady who drove the first public service.
hwl
5 Feb 2012
Yeah that's fair enough. Always forget how limited 750v DC is in that department.
Figure wise the 707 is supposed to be capable of 0.85m/s^2
That is a maximum acceleration rate, the acceleration rate is non linear and varies with speed (two separate V^2 components involved in the non-linearity). The shape of the whole curve across the relevant speed range is what matters not the gradient of the steepest bit of the curve alone and the aventra curves is slightly flatter than others so while the peak value may not be as high the average is better.
With well designed modern 3phase traction motors & traction electronics and decent number of motored axles, gearing makes very little difference for max 75mph with gearing optimised for 75mph or 100mph and the excellent Aventra traction motor cooling really helps here.
Goldfish62
14 Feb 2010
Not surprising - it's been nearly a month since it last had a run, so plenty of time to spruce it up after all those muddy feet last time.
Last time it was out it would have been salty soles due to the freezing weather at the time.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
To be honest, I've always found the FLEXX-Eco to be a terrible riding bogie (though it doesn't knock as badly as the CAF version). The best of those lightweight ones are the Siemens version under the 700s. At least neither oscillate as badly as the Hitachi version though.
