Class 745 Stadler FLIRTs
stonojnr
17 Apr 2019
Oh dear, that's a bit of bad luck. I suppose one of the new trains was bound to break down at some point. No doubt there will be a bit of a fuss in the local media.
a bit of bad luck ? A train gets stuck for 5hrs with passengers on board without lighting,heating,toilets or even hot drinks as they ran out, that they eventually decide to use ladders to get passengers off with because the rescue train coupling was broke, and thats just a bit of bad luck...:rolleyes: have they even tested a de-train properly because it sure didnt look like they did given how little anyone seemed to know about what to do next.
and when was the last time a 90+mk3 set did that ? the only one I can remember involving passengers de-training was on Liverpool Street approaches when a bit of the new overground bridge theyd put in decided to prove Newtons law of gravity, this is 86s & summer of 95-96ish territory when the trains used to just give up in the middle of Essex somewhere for no reason and youd lose hours cooking as the aircon packed up, but at least you could use the toilet if you could fight your way past people to get to them.
ic31420
23 Aug 2017
Like I said, 745's have no electrical connection box, so can only mechanically couple to anything else. No other reason than that I'm afraid, they simply were not designed to work in multiple at all.
So how does the rescue loco control the brakes, or at least get the brakes off?
dk1
2 Oct 2009
East Anglia
Oh I don't know. Last year when the 16:30 Lst-Nrw struck a car on the level crossing at Palgrave (Diss) it was nearly midnight before we where all evacuated. Another had an air leak at Cow Green a few months back on a Sunday afternoon. That too took hours & hours. So many over the years they just disappear from memory.
samuelmorris
18 Jul 2013
Brentwood, Essex
The only incident that sticks in my memory was an LHCS failing between Harold Wood and Brentwood and me being on the 12-car 321 behind which was evacuated at Harold Wood, despite being longer than the platform. We were about 90 late as a result from switching to the TfL side but I don't recall how late the Norwich passengers ultimately were. I think they too were evacuated. Having just looked it up this was 17-Nov-16.
dk1
2 Oct 2009
East Anglia
Gosh I've had some classics myself with some very severe delays. Twice in snow sat down around the Flordon area, another at Brentwood. These are pure failures. I think we all look back fondly at the 90/DVTs & 86/DBSOs before them but some impressive incidents have occurred over the years.
trebor79
8 Mar 2018
It's not the first time people have been detrained via ladders and it won't be the last. So one train broke down, it's not really that big a deal is it? It happens.
Unlucky that there was some issue with coupling to the rescue loco. So the.n it becomes a detrain. That's going to take time to organise - people to assist, people to supervise, a train to evacuate the passengers onto, track isolating and making safe.
You could practice a detrain a thousand times, but all of that stuff still needs doing for each individual situation. Risk assessments need to be done, identify the risks to people (beyond the obvious - ground conditions, what other hazards are at the site - cables, mechanical stuff feet could get trapped in etc etc. Is there a biological hazard from any turds in the 4 foot etc etc. Everybody involved needs to be briefed and understand what is required.
I'm not a railwayman, bar messing about with tank engines in a minor heritage line in my youth, but even I can appreciate significant time will elapse between a decision to detrain being made and it actually happening.
So bad luck on the breakdown, bad luck that the rescue loco didn't work out. Everybody was safe and nobody injured or worse, which might not have been the case if people rushed to detrain.
Reports from those on the train don't paint the picture you do. Toilets were working bar a short period and the staff kept people informed as best they could.
Astro_Orbiter
8 Nov 2019
Probably with a main res pipe to release the brakes, and perhaps a brake pipe? Not familiAr with the specific ins and outs but there will be a way to do this.
rdlover777
4 Feb 2014
Kent
Looking at this picture of the 745, it has two holes on the coupler ringed with what looks like an air tight seal, maybe its similar to how Aventra's can be dragged by a loco since they dont have any electrical boxes on there couplers too.
eastdyke
25 Jan 2010
East Midlands
So, if I understand correctly, the big beasty Hares can only be rescued by Thunderbird?
In which case how is it proposed to cover the 20 units spread over the GEML and Stansteds with the depot in Norwich?
Clearly total failures would be expected at very few in number but the disruption for each event could be at a cost 4-6 hours (or more) of good service on the route affected.
superjohn
11 Mar 2011
There is a photo on the Friends of Mid Norfolk Railway Facebook page that shows a class 755 hauling a 745. Sorry for the huge link but it works for me!
https://m.facebook.com/photo.php?fb...er.GroupStoriesByActivityEntQuery&__tn__=EH-R
So it would seem they can be coupled even if it is just for a low speed line clearing move. If the class 37 can do the same we could perhaps quietly hope the class 720 will also be able to as well. As mentioned above, there is no electrical connection on a 745 coupler so it only needs a mechanical connection and a means to release the brakes.
Astro_Orbiter
8 Nov 2019
Yeah no doubt its possible to couple a 755 to a 745, but they cannot be worked normally in service, it would be purely for rescue only, and I'd assume that a thunderbird loco would be just as easy and likely more practical than using a 755. From what I've heard there's going to be a standby loco dossing about the place to cover for failures, because like you say, if a 745 fails at say Harlow, then its a bloomin long way back to Norwich!
trebor79
8 Mar 2018
Have they given up with passenger information systems? Was on the 745 today and they were turned off and yesterday the same on the 755.
I've just passed another 755 where it was also off.
Was working on the 755 I was on this morning. Can't remember if the auto announcements were on, I tune them out anyway.
Alfie1014
27 Jun 2012
Essex
And last week when the 16:30 LST-NOR hit a deer near Clayton (pair of 321s) but pax from the front unit had to be de-trained and walked back to the rear unit which was able to return to Ipswich. Difficult situation not least as it had to be done in the dark.
306024
23 Jan 2013
East Anglia
Software update on Monday night caused lots of issues with it.
Familiar story the world over, in all industries. Just that the production line for the railway is pretty much there for all to see, 24/7, so most issues are immediately visible.
LAX54
15 Jan 2008
From what we heard, they coupled up, and found an air leak in the emergency coupling, so took it off, and used the second one that was on the loco, only to find it was not compatible/broken, after that of course, it means it will be a long job ! They did locate another coupler, but that was quite a distance away. I am assuming they then did the risk assessment process to detrain, and that is never a 5 min process !
With hindsight, which is a wonderful thing, and I am not sure why the Railway does not have it, the Public seems to think it does ! Maybe it could have been done a different way, but it was the first major 745 failure, and a steep learning curve for everyone, no doubt lessons learnt, and rescues will be revised? Up to now the 745's have been good, with only the odd niggly issue.
LAX54
15 Jan 2008
Not sure of the issue at the moment, but there is a 'bar' on assistance generally, but 755's have been rescued by another 755, albeit at 5mph, I assume at some point the restriction will be removed, but if you have to rescue a 12 car 321 or a 360, there are similar assistance problems !
LAX54
15 Jan 2008
After the Stadler update problem was discovered, didn't they roll back to a previous version to 'solve' it, the 755's seemed a bit better later in the morning, well a little better :)
Southern Dvr
13 Oct 2010
Because nobody self detrained it’s unlikely the RAIB will be too fussed.
The GOBLIN diverts made things much complicated because they could only reach the NLL by going bi-di along the Down Main. Threading them around the already FUBAR state of the line must have been a massive headache.
The poor reliability of Stadler and Azuma units is a disgrace and somebody needs to own it and deal with it.
20atthemagnet
1 Feb 2019
England
Quite simply, it doesn’t :D
depending on the type of failure you either:
1. isolate all the brakes on the 745 unit.. the loco then drags it freely.
2. if you have no main res air isolate the parking brake, and again drag it freely.
Both at a maximum of 5 mph due to there being no brake continuity through the whole movement. Having done it myself it’s not something you want to get wrong, and why this is often a last last last resort.
Have to say though great door to choose next to an AWS magnet :lol:
bahnause
30 Dec 2016
bülach (switzerland)
Both at a maximum of 5 mph due to there being no brake continuity through the whole movement. Having done it myself it’s not something you want to get wrong.
That's very different to every other Stadler product I know. Actually to every train I know...
trebor79
8 Mar 2018
It must be possible to control the brakes from the loco, they weren't hauled at 5mph all the way from Switzerland/Poland to Crown Point. Plenty of videos of them hammering along the GEML behind a 37.
Dave1987
20 Oct 2012
This is simply not the case with these Stadlers! They have a brake reservoir pipe going the length of the train from the coupler. So a suitably equipped loco or other Stadler can attach and operate the brakes on the failed train so it can be dragged at full line speed.
samuelmorris
18 Jul 2013
Brentwood, Essex
Not really for this thread but there is worse new stock than the Azumas. For what it's worth they are the most reliable 80x fleets currently. Reliability of the 755s is admittedly poor thus far, hopefully it will improve.
LAX54
15 Jan 2008
If TBIRD Driver came onto the Siggie here and said, all attached but no brakes on 755/745 etc, and will run at 5mph, think he would be told, that he would be going nowhere at all !
dk1
2 Oct 2009
East Anglia
Exactly mate. Front/rear must have a working brake or it goes nowhere unless I think its bar coupled.
47421
7 Feb 2012
london
Ian Prosser has tweeted that they will be meeting GA and Stadler on Thursday.
yep, was only a matter of luck that this happened morning peak/daylight hours, if had been evening/in darkness much more likely passengers would have taken things into own hands to get home and situation would have been much more messy
