voyagerdude220
- Joined
- 13 Oct 2005
- Messages
- 3,277
It seems like this evening's 17:30 London Paddington to Taunton encountered a technical fault in the Slough area. It's terminating at Bristol Temple Meads tonight.
If you don't like opinions on a forum, you know what to do.......Yes, hysteria is overblown. The same few posters keep trolling out the same tired arguments and adopt the same repetitive finger pointing exercise, demonstrating little understanding of how this situation has actually come about nor how it can be resolved.
How many WoE services ran 5 vice 10 today? I know there were 5 sets short formed across the 800/802 fleet today - I saw a good number of the WoE diagrams go past me during the day and they all seemed to be 9 or 10 car sets barring one up working this morning (suitable for a 5 car anyway).
I am one of those who have travelled on far too many 5 vice 10 IETs recently and realise that big efforts need to be made to sort it out, but post after post of 'WorstGroup did this' and '(s)Hitachi did that' is frankly dull, often wide of the mark and actually doesn't give the detail of what's going on, which I'm sure is actually what most of us are interested in.
Agreed. Customers on so called intercity routes should have the highest expectations , and as an industry we should be aiming to meet them.If you don't like opinions on a forum, you know what to do.......
There are far too many people tolerating a lowering of standards and expectations. I actually believe we should have an expectation that things improve rather the just having to accept whatever dross is foisted on us ("just be glad you get a seat" and all that). In this case we've gone backwards.
Iwest country trains (remember it's only an hourly service)
Yes but these services cater mainly for the likes of Newbury pewsey etc and are dead beyond Westbury . They are not comparable to a London to Penzance express.Can you at least get basic facts right?
Or don't the various departures to Taunton, Exeter or Paignton (most leaving Paddington at xx.33) count as West Country services in your mind?
The current service pattern provides a half-hourly frequency from Paddington as far as Exeter from 16.03 to 19.03.
In addition to the ones that run all year, there is also a 14.33 extra to Exeter on summer Fridays and the 18.33 is extended from Exeter to Plymouth on summer Fridays as well. There will be a regular semi-fast Exeter or Paignton departure every two hours year-round with the new timetable, never mind any summer extras/alterations.
I was thinking about that point - With the late notice amendment for the Cl.800 to run further and longer on Diesel (vice Electric), Hitachi uprated the engines to the Cl.802 spec - correct? (Please correct, if not).
Did Hitatchi miss a step or two, in considering the impact of the higher workload on the spec for initially running on Electric with short distance / contingency Diesel?
I may (and probably am) talking rubbish - but the need to uprate the original engines beyond design could lead to the current overheating issues (if the spec is slightly different between the 800 and 802.
Plus 1a77 is 15 odd late due to technical problems. One really does wonder what hope we have of the December timetable improvements actually happening.Some cosy ones today
5.29 Plymouth to London and 0748 paignton to Paddington via bristol both formed 5 vice 9 or 10.
Yes it has Clarence Yard has just confirmed it in post above yours(for the 10th time Id say)Class 800 fuel tanks had a capacity of 1300 litres, 802’s have 1550 litres
Class 800’s we’re going to be retrofitted with 1550 litre tanks but I don’t know if this has happened
I’m not so sure that what Clarence Yard is saying is correct though.
At a guess the original plan might have been for 800s to have 1,300L tanks but the probably spec got changed when electrification got delayed /deferred /cancelled to match the 802sI’m not so sure that what Clarence Yard is saying is correct though.
The 800 and 802 sets have the same 1550L capacity fuel tanks and have had since entering passenger service.
We're they designed / originally spec'd that way?Nope, because the powerpacks in the 800s are identical to the 802s.
The 802s only have different software, plus a bigger fuel tank and a bigger bank of resistors for the rheostatic brakes.
Thanks - that's what I was looking for.The 800 fleet was originally spec'd to be 565kw with 1350L tanks. When the chaos of the GWML electrification finally was recognized by the DfT, they authorized 700kw and 1550L tanks for the 800 fleet under VN0024, issued in early-ish 2017. The first one to be fitted with a 1550L tank, irrc, was 800004 which was the one that I used for the 800 fuel tests, to obtain the real (as opposed to contracted) fuel range.
Three engines out on a unit less than a year old.. It's impressive the service was able to run to any reasonable timescale with only 1880hp but I can't say it's pleasing to hear about!Today's 10.00 Penzance - Paddington was 802 112 and I noticed on Real Time Trains that it was gradually losing time from Cambourne onwards until it was 24 late around Pewsey but then pulled back three minutes from Savernake ( well, it's all downhill from there! ) and only stabilised from Newbury onwards; when I boarded it at Reading I asked one of the staff if it had an engine out and the answer was, surprisingly, it had three engines failed so only two working.
So, with only 40% power it only lost 21 minutes overall between Cambourne and Newbury. That strikes me as quite a creditable performance in the circumstances?
At what point does just running slower than usual count as a TIN? How much slower does the run have to be? In any event, while you are absolutely right about unit reliability, beating the GWR HSTs with the fault-prone ATP kit is a null challenge. The 80x fleet are just about managing 10k MTIN so far, compare that to 20k for Pendolinos and 40k for 222s and it's distinctly underwhelming. It's also lower than LNER and EMT's HSTs. There is a lot of work still to be done. Just because the reliability of the fleet they replaced was appalling and the 800s are providing a big improvement in MTIN figures doesn't mean they are performing satisfactorily yet.It seems like some people on this website have been crying since June when we lost the HSTs and are isolated from the fact that there were actually delays, cancellations and faults on the Great Western Mainline like currently, and to the same level. Infact, the 800s mile per technical incident is lower than that of a HST.
So to summarise, yesterday on the wofe route alone,It seems like some people on this website have been crying since June when we lost the HSTs and are isolated from the fact that there were actually delays, cancellations and faults on the Great Western Mainline like currently, and to the same level. Infact, the 800s mile per technical incident is lower than that of a HST.
Your last sentence is contradictory to the rest of your post.It seems like some people on this website have been crying since June when we lost the HSTs and are isolated from the fact that there were actually delays, cancellations and faults on the Great Western Mainline like currently, and to the same level. Infact, the 800s mile per technical incident is lower than that of a HST.
0529 ply to padd 5 vice 10
0748 paignton to padd 5 vice 9
0555 pz to padd delayed by door problems in Cornwall and near London
1000 pz to padd 20 odd down with engines out
1204 pz to padd cancelled at truro failed.
I would estimate that is nearly a third of wofe diagrams in an absolute state and you see that as acceptable ? HSTs where never this bad....
