Class 810 for East Midlands Railway Construction/Introduction Updates
Domh245
6 Apr 2013
nowhere
I do not understand this argument at all. Flirts have dual (or more) transformers precisely to add redundancy - even though a lot of units may only have a single pantograph. You'd think any unit should do this. To be fair, this may be less critical for bi-modes - but still nice to have the redundancy.
There's a tradeoff to be had. Transformers aren't light, and you don't tend to get many failures. Certainly in the UK at least most multiple transformer units are there because a single transformer wouldn't be powerful enough
The 22x traction curve was downgraded deliberately to reduce fuel consumption and engine life etc. But i've not heard anything about engines being deliberately shut down for that purpose. And they don't have the same engine optimisation system as the Class 185's either that will shut down an engine when not required. That is a novelty - maintaining 100mph across the York plain with one of the engines deliberately shutting down. I understand they can't be restarted until the unit comes to a stand though.
They were fitted with an energy saving mode similar to the 185s: https://www.breakingtravelnews.com/...s-the-carbon-cutter-for-east-midlands-trains/
The introduction of this system allows the number of diesel engines on the train to be matched to the duty required to reduce diesel consumption, noise, emissions and maintenance costs. It is believed to be the first retrospective application of this type of technology in the UK.
No idea if it is still active.
LowLevel
26 Oct 2013
Kneedown
29 Dec 2007
Nottinghamshire
It's the reason you see so many complaints about passengers sitting with just emergency lighting, no plug sockets and no air con in summer if the driver forgets to disable it, even worse if the vehicle gets stuck in energy saving mode for the trip.
Perfectly possible to start a 222's engines on the move. If one is out for a journey it's either isolated, poorly, or the TMS is glitching.
NewSt
24 May 2019
A Class 172
D365
29 Jun 2012
Wish I knew what the reason for total reclassification was...
“Total reclassification”? Clearly any number in the range 803 - 899 could be chosen, noting the way other class numbers have been allocated completely out of logical sequence for quite a few years now...
Meerkat
14 Jul 2018
Seems sensible to leave 80x numbers free for 26m variants and start 81x for the 24m ones?
Ethano92
26 Jun 2017
That tweet would also suggest they'll have plug doors sitting flush with the bodyside as opposed to the original concept art for the units which had the standard sliding doors. A welcome change IMO
37057
3 Jul 2009
Nor sure what units you mean but just to clarify a few things about the 185s here...
The 110v DC battery output circuits on each vehicle are connected together, so lighting won't be affected if an engine is not running. Emergency lighting operates when there are no engines or no shore supply and the unit goes into a load-shedding state.
The plug socket supply is derived from the 400v AC 3-phase system so this won't be affected as contactors close to allow crossfeeding from an adjacent vehicle's alternator. Same goes for some of the equipment in the toilets (hand dryer etc).
The HVACs also run off the 400v AC 3-phase system. They do run when there's an engine not running but they operate in redundancy mode when being cross-fed, meaning only one cooling circuit per end of the saloon and only one third of roof heaters per end of the saloon (no bodyside convection heaters either), both modes run with supply air fans on low speed.
I don't know the driving policies or how often this is done but ECO mode can be disabled easily enough.
YorksLad12
5 Feb 2020
I agree to an extent, but the Old Oak Common Name won't be meaningless to many people who worked on or used HSTs. I definitely agree that the IET name can be confusing, seeing as some people think it's actually an IEP because of the Intercity Express Programme.
Whilst Gary would be a fun name, it wouldn't have meaning unless your name is Gary. Most names are for marketing purposes.
Having said that, I doubt the 804s will have a name, they don't really need one as they are going to be working under a branded service of EMR Intercity, so why confuse things more?
Speaking as a Gary, this is a dreadful idea. I don't want all the complaints when there's a no-show - I don't have the patience of John Lewis ;)
Nym
2 Mar 2007
Somewhere, not in London
They're actually not all IEPs, only the 800s and 801s are IEPs, the 802's equivilant to IEP is WoE, all of them are IETs.
Intercity Express Train
West of England
greatvoyager
15 Aug 2019
Exeter
West of England
I was referring to the fact that some people I know have referred to these EMR units as IEPs.
Aren't they all SETs (Super Express Trains) also? And AT200s?
Only a matter of time before someone starts complaining we are using the three-letter station codes without explaining them.
Domh245
6 Apr 2013
nowhere
They're all AT300s, AT200 is the class 385 family. I was under the impression that SET was the name of hitachi's first proposal for IEP (the version with power cars) but it seems like this name was being used until the operators introduced their own names
Inthewest
12 Feb 2020
The West
I wonder if the new front end design will look a bit like this:
I guess there's been nothing else about the design so far?
Domh245
6 Apr 2013
nowhere
Except that we've had two renderings of the units revealed, and they don't look much like that. They look like pretty much all other 80x to date with a slightly shorter/stubbier nose
It'll no doubt be somewhere between the two of those - possibly a bit more like the latter than the former, but I can be pretty confident it won't be like those in that image, which seem to be distinctly 395 based
24 Jun 2014
Derby
On the lower of the two images shown, the front passenger door seems to be further forward than on the upper one.
IEPs (and presumably their direct derivatives in class 802) were designed for a maximum speed of 140mph, whereas I guess those being built for EMR will only be for a maximum of 125mph; does this mean that the unusable passenger space in cab-ended vehicles can be reduced in length?
samuelmorris
18 Jul 2013
Brentwood, Essex
I don't think it's anything to do with that, I think it's because the vehicles are 24m in length rather than 26m.
