Class 93 Tri-mode Loco
ac6000cw
10 May 2014
Cambridge, UK
Surely a dynamometer car would still require a steep bit of railway to record the results for it's performance up a hill? I would hazard a guess that modern telemetry can be fitted to the units without needing a dedicated vehicle that the fragmented railway doesn't really have a good place for.
Modern traction control systems can measure/log tractive effort, power, speed and probably pretty much anything else you might want to know about how a loco is performing. so I doubt you need anything else.
If you wanted a variable test load, hauling a loco or two with decent capacity dynamic/rheostatic braking that can be used independently (i.e. not linked with the train or loco friction brake systems) could provide it. I don't know if any UK locos can do that (class 70s maybe - anyone know?).
47286Dan
27 Dec 2018
This mornings allocation.
93001 GROG WORKSP DY 260Q421F07 F CREWE SYD B
93007 GROG WORKSP DY 260Q421F07 F CREWE SYD B
Dan
hwl
5 Feb 2012
Agreed nothing else needed.
70, 88, 90 or 91 would be suitable. The resistors aren't that big (volume constrained) so you would need a few trailing locos to do this.
AndrewE
9 Nov 2015
what about drawbar pull? all of the above are very fine, but take no account of adhesion! The whole point of a dynomometer is that it measures the pull, which is otherwise missed completely.
