Clayton CBD90 - Battery+diesel shunter - now BR Class 18
Rhysdabeast
10 Apr 2020
Crewe
Was there on 27/03/2025 and i feel for quite a while before.
I recall it being said that they are all grounded.
I heard the same thing, something about the position of the battery and being close to the cab, can't remember what the reason was but it was something along those lines.
Peter Sarf
Croydon
As in they are electrically earthed or they aren't to be moved?
I think it was because the fuel tank is close to the cab door and could cause the driver to be trapped if it caught fire. So staff are not using them.
cj_1985
6 Mar 2010
Last i heard, the ACTUAL reason they weren't being used on NR yards was a union concern issue barring their use. I forget the specific concern/s
Roger B
16 Jun 2018
Gatley
18004 (nearest the camera), 18011, 18001
Seen in this Youtube video:
Wowzers, many thanks DBS92042 - and Peter Sarf for the additional notes.
Really helps me to get a netter understanding of the layout.
Looks like I'll be visiting the Kia dealership and LIDL periodically over the next few months, but not the canal path until the leaves come down again in the autumn.
And I too won't shed any tears if that "small pesky brick building" is removed - by any means fair or foul.
Peter Sarf
Croydon
I am wondering about vegetation. The main culprit seems to be Ivy maybe - which is evergreen. So its not worth worrying about seasons just the onward march of the stuff year-on-year,
trent129
4 Mar 2024
derby
I took a drive to Wolverton today, 18001, 4 and 11 are visible from aldi. I took a walk from the abandoned works gate and saw the single loco between the works buildings. Any idea which one this is? Didn’t see the other 4 together in the line. Cheers
Peter Sarf
Croydon
Gosh, what sort of lens are you using to get all three from ALDI ?.
Or have they moved from adjacent to that low brick outhouse ?.
Otherwise I usually get one or two of those three from behind the car dealership.
This abandoned works gate - where ?.
The other four are barely visible from the canal towpath. I have been wondering if a step ladder would help there ?.
On my previous visits there have maybe only been three, two, one or none there.
trent129
4 Mar 2024
derby
I used the Wolverton drone footage on YouTube for the IDs. The 3 in view from Adli he zooms in so the numbers can be seen. The 4 in the canal line are 5, 10, 13 but can’t id the 4th From the footage. If you could the one on its own will be known. There‘s an old gate next to quick fit. seems abandoned
Also I went to Eastleigh and the two are still visible with binoculars
Peter Sarf
Croydon
Ah.
Be very careful.
They seem to move the class 18s around in Wolverton.
For example back on 21/01/2025, when I visited, I could see no 18s were over by the canal. Also the 18001 in the video (25/03/2025) and seen by me on 24/03/2025 was in the space occupied by 18010 back on 21/01/2025.
That was two months apart with changes both sides. So now, two months later again, I would expect things to have changed again.
trent129
4 Mar 2024
derby
Ah.
Be very careful.
I know what you’re saying. There’s another drone video from 2 days ago Which is the day I went. You can compare between the two Videos. There are small differences between locos. 5 has a missing beacon logo from the black sole bar and locos have different sticker positioning on fuel tanks etc. 001 has different increments on the fuel tank altogether. I’m confident that at least the 3 visible are the same.
Peter Sarf
Croydon
Can you provide a link to the latest video ?.
You certainly have been watching out for detail differences that are useful.
BTW - where did you view the pair of 18s at Eastleigh from ?.
Some seem to view a long way off from the road bridge but I feel there might be a view from behind the houses at more or less right angles to the 18s.
trent129
4 Mar 2024
derby
. Hope the link works. If it doesn’t search Wolverton class 18. I viewed the 2 Eastleigh ones from the bridge. Was in a rush so didn’t try the houses.
