Why has it been closed?It's a huge shame this had to happen and they could not provide a temorary stop close-by. the neartest 46 stop is a 10-15 min walk. I wrote a complaint into TFL.
It's being rebuilt. Reopens Feb 2017Why has it been closed?
If you mean the 64 (the 46 would take even Mo Farah a couple of hours) I understand there is a stop 'round the corner' in Dingwall Road. On the other hand for 119, etc passengers there is a huge gap between stops and you are advised to use a tram in the first instance (bit tough if you're going for a 3 a.m. departure on the 119!)
Sorry I meant the 466, but also a few others such as the 199 you mentioned. Not great for people with disabilities.
I had wondered about that too. I would guess that it is more to do with the beaurocracy of stopping parking on a sufficient length of road to allow the bus to stop in such a way that the wheelchair ramp can be deployed if necessary.I agree with you absolutely. I don't understand why TfL no longer feel able to use temporary stops: if it's because of on-bus stop announcements being incorrect, then it's a case of the tail being allowed to wag the dog.
Just to be clear it's the 119 and 466 and there is nowhere suitable to put a temporary stop.
Maybe there isn't in this particular case, but the fact remains that TfL are markedly reluctant to provide 'temporary' stops. For instance a few years ago the outward trajectory of the 3 from Oxford Circus was altered so that it no longer traversed Oxford Street before turning right into Regent Street and picking up at the stop outside what was then Dickins and Jones department store, a stop it shared with the 159, so useful for a lot of people who could catch either bus. After the change the 3 picked up in Regent Street north of Oxford Circus and no longer served the D&J stop. OK, but then the 'new' stop was taken out of action for months for no apparent discernible reason. Logic would suggest that the 3 should then have reused the D&j stop for the duration, but, no, you had to go half way down that part of Regent Street to a request stop, so the 3 in effect no longer served Oxford Circus in one direction. I can quote other cases known to me personally where such inconvenience was caused for weeks, even months.
I don't doubt that at all and much of this is down to DDA legislation, years ago a temporary stop was placed at the nearest suitable location without any great problem but nowadays various assessments have to done regarding wheelchair access etc and its generally easier just to not provide a temporary stop.
On the subject of East Croydon the only option would be for the 119 and 466 to do a double run to the roundabout in Dingwall Road so they can serve the stop close to the station but obviously that would delay through passengers.
Thank you for supplying the info concerning the East Croydon situation, and I accept what you say about suitable sites for temporary stops, but in the case I cited (and many others too) all that had to happen was another existing stop be adapted to accept another route or two. It's all the next bus info gubbins etc that wouldn't work that seems to preclude it, to the disadvantage I would suggest of the majority of potential passengers.
As I've already said, the iBus system should not stop temporary stops being used - especially if they're existing stops which are already in the system.
In that case, I shall look forward to this happening in suitable cases, and if anyone on here can post when it occurs I'd be grateful.
Apologies, this is a technical issue. I've tried to remove E6 whilst highlighting the closed stops but it returns to default
Whose Twitter was this?According to twitter:
How are they actually going to improve East Croydon bus station? There is very little space to expand it and looking at it yesterday nothing much seems to be going on. Are they somehow going to try and incorporate buses in both directions stopping in the same area rather than having the Central Croydon bound buses stopping on the bridge?
It opened on Friday. Unfortunately it has not improved much. No indoor waiting faculties, not much more shelter from the elements, and no info screens at each island (only 1 at the entrance). It is also less safe as there are now no pedestrian barriers at each end of the islands. Very poor show by TFL.
I had a very brief look yesterday and I can't understand how it has taken so long to do so little. I thought the whole idea was to somehow combine bus stops in both directions within the same area but that seems not too have happened. They might as well have left it as it was and saved a lot of money and disruption to passengers.
All that has been done is resurfacing work, that needed doing, and a few cosmetic improvements, in fairness space is very limited so not much more could have been done, but how it's taken nearly six months and reportedly cost in excess of £5m I really don't know.
