arabianights
- Joined
- 1 Jun 2011
- Messages
- 150
Edit: Quick answer is that experimentation proves that you can use a CPAP on the Caledonian Sleeper, so long as you use an adaptor for a shaver socket - but it isn't particularly advisable
The internet is pretty ambiguous on whether you can use a CPAP (a device that keeps your airway at a continuous pressure essentially by pumping air down it, most commonly used as medical treatment for sleep apenea) in a sleeper coach; there is no power outlet apart from the shaving socket, which may be unreliable and prone to surges in both directions, but of course adapters are available.
Therefore I propose to answer this question for the sake of future googlers, at least for a Res Med s9 series (which I use), tomorrow, by a process of experimentation, tonight, as I travel.
But in the meantime and this is why I'm starting the thread early - is there any reason I shouldn't do this?
