Correct procedure when travelling on outside Oyster validity.
tom73
24 Apr 2018
Example:
Purchasing a Feltham-Staines ticket at Waterloo to board a train for Staines.
Touch in at Waterloo. Feltham is the Oyster border hence the additional ticket.
Is one supposed to leave the train at Feltham to touch out or simply carry on.
I am thinking of difficulty using the Oyster on first touch in back in London.
It's unclear what you are using the Oyster medium for; therefore it's not possible to answer the question without clarifying this.
If you are using Oyster PAYG then the answer is that you must tap in and out; if you were to carry on then you will be charged a maximum fare. In the reverse direction you will be liable for a Penalty Fare or prosecution.
If you are using a Travelcard, then regardless of the medium in which it is held, there is no requirement for the train to call at any intermediate station and no requirement to tap out.
tom73
24 Apr 2018
Using the Oyster for travel between Waterloo and the Zone 6 boundary (Feltham) plus a Feltham-Staines return ticket. No Travelcard.
In that case see my paragraph above relating to PAYG.
This isn't an Oyster issue per se; it applies equally to the use of Contactless for PAYG journeys.
Oyster is just a medium, not a product in itself
In the case of Feltham, there are (or certainly were) readers on the platforms which you could use. These are at the 'night gates', ie about the middle of a westbound train and back of an eastbound train. You may have time to get off, touch out / in and continue your journey.
Hadders
27 Apr 2011
I’m not familiar with Feltham station but if the readers are by the night gates they might not be operational when the night gates are shut.
I don't think that any Oyster readers located on platforms get switched off at any time. I think they remain live at all times.
Do you know of a counter-example?
Kite159
27 Jan 2014
West of Andover
The readers at the bottom of the stairs at either Alexandra Palace are turned off when the main entrance is manned
Hadders
27 Apr 2011
At Highbury & Islington the platform validators on the Victoria Line are turned off when the Northern City Line isn’t operating. This is rare these days but used to be every weekday after 21:00 and all day at weekends.
MikeWh
15 Jun 2010
Crayford
I can confirm this, and it did cause some confusion the last time I was there.
